38 Gal tank experiences....
Discussion in '2.5 Gen Tundras (2014-2021)' started by KeithM, Mar 19, 2018.
  1. Jun 21, 2023 at 11:34 AM
    #721
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    If you just refill at a half tank then it will only be $75 :homer:
  2. Jun 21, 2023 at 12:38 PM
    #722
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    ¾ is a hundred…
    PomDad likes this.
  3. Jun 21, 2023 at 1:26 PM
    #723
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    Something about this math is off :boink:
  4. Jun 21, 2023 at 2:57 PM
    #724
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    I put 100 of my hard earned dollars in the tank yesterday and got 21 gallons out of the deal. Not a bargain by any definition but it is about 3/4 of a tank roughly. That's around $4.75 a gallon. I imagine it's about the same in "Da Bay Area" only with fewer homeless drug addicts shitting on the sidewalks. :eek2::poking:
    Tundrastruck91 likes this.
  5. Jul 2, 2023 at 9:23 AM
    #725
    XR5dude
    XR5dude New Member
    2021 Tundra
    I live in hurricane prone area where gas stations run out of gas for hundreds of miles during an evacuation so the extended range could be very useful, and if we get hit there could be gas shortage after returning.
    I can confirm for 2021, went down to 42 miles before empty, added about 28 gallons, so still had at least 8 in the tank. The computer range after filling up is about 450 miles with is great. This is all very good info.
    I didn't even know I had be bigger gas tank and 450 mile range is way more than any other vehicle I've had.
    WHAT and Johnmatrix like this.
  6. Jul 13, 2023 at 3:45 PM
    #726
    ShawnTRD
    ShawnTRD New Member
    Shawn
    Just got a new used 2020 Limited with the 38 gallon tank. Dealer filled it up I drove over 400 miles but I didn't reset the Trip A. I've always used Trip A for gas and Trip B for oil tracking. Just filled up with about 40 mile range left. It took 29 gallons. I was seeing 530+ mile range. System says I'm getting 16.9 MPG.
    bradleypc-12, _none_ and Mike59 like this.
  7. Jul 29, 2023 at 8:30 PM
    #727
    skniper
    skniper New Member
    Good idea with the trip meters, will borrow that idea. Most I’ve ever filled up is almost 33 gallons.
    I’ve always wanted to run the tundra out of gas just to see how far it would go and how much refill it would take. But then that takes some planning and the urban legend (?) of burning up the fuel pump.
  8. Jul 30, 2023 at 5:05 AM
    #728
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Half tank on gauge is 15 gallons used
    light comes on with 8 gallons remaining
    plan accordingly
    If you are boosted, please don’t let the light come on
    Cpl_Punishment likes this.
  9. Jul 30, 2023 at 3:21 PM
    #729
    7mag
    7mag New Member
    Hombre
    2021 Green Tundra TRD, 2013 Tacoma TXPro
    This thread would have NEVER happened if toyota would simply put a 38 gallon tank on their truck with 38 gallons of usable gas. After 46 years of buying Toyotas, my loyalty is waiving but at my age who gives a s***.
    Gene_in_FL likes this.
  10. Jul 30, 2023 at 4:43 PM
    #730
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Huh? who is stopping you from using all 38 of your gallons?
    GODZILLA, Jaypown and Cpl_Punishment like this.
  11. Jul 30, 2023 at 4:55 PM
    #731
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Can the dealership reprogram from 26 to 38?
  12. Jul 31, 2023 at 4:55 AM
    #732
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    All 38 gallons is usable. It's not hidden in some secret compartment that only Toyota has the keys for.
    It's called reserve. All vehicles have it. The only reason this thread exists is because the tank is large enough to make the reserve really noticeable. Other than that, we'd all be driving around using up 37.5 gallons of fuel at 15mpg and bitching about running out.
    WFD473, Lug Nut, GODZILLA and 7 others like this.
  13. Aug 2, 2023 at 2:20 PM
    #733
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    2020 Tundra Cement Grey TRD 4x4
    King lift,Leather seats,3m film wrap around,35's KO2 on FUEL Wheels,Line-X, backflip,Bam 10" exhaust with Toyota Black Chrome Exhaust tip,Amp research step,K&N air Filter,TRD air flow Accelerator
    So I just read a couple post on this thread and seems a lot of people go off the trucks computer to estimate MPG's. Does anyone use an app ? I use an app and my MPG's don't add up to what the trucks computer says. I'm at about 9.28 MPG (City driving) spending about $100 - $120 to fill up with a quarter of a tank left. Not complaining but wondering what it's going to be once I regear this hog.
  14. Aug 2, 2023 at 2:33 PM
    #734
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    you "should" get better MPG with gears...even better if you boost it...first 2 years you'll have worse, but after you're used to it, it'll buff out...I use Fuelly to track MPG and man oh man, I'm only 5-6mpg off from the computer
    J's 4x4 likes this.
  15. Aug 3, 2023 at 4:59 PM
    #735
    ShawnTRD
    ShawnTRD New Member
    Shawn
    Filled up today with 24 miles left. Looks like I had over 7 gallons left. That would have been 100+ miles. How much have you put in and how long have you pushed the Range?
    Mike59 likes this.
  16. Aug 4, 2023 at 4:00 AM
    #736
    nobodyintexas
    nobodyintexas What?
    South of Houston
    the 8 gallon reserve is to prevent fuel starvation...because our tank is long/flat-ish.
    don't let the fuel light come on.
    both of the dudes that tuned my truck said >>if you have a blower (and you know who you are) don't go below 1/4 tank.
    @ 1/2 tank - you have used 15 gallons. go fill up.
    This logic does not vary if you:
    use 10k oil change intervals
    have a trans cooler
    use 0w-20 oil
    use Amsoil
    have 35" tires
  17. Aug 14, 2023 at 9:04 AM
    #737
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    I filled mine up the other day. Put in 28 gallons, meaning I had 10 left. Miles remaining estimate was 53 miles, but I was only getting 7 mpg on that tank, so I probably had about 70 miles left in reality. Not too far off in this case.
    Mike59 likes this.
  18. Aug 15, 2023 at 5:18 AM
    #738
    Skaufma0
    Skaufma0 Just a little stitious.
    Rock Hill, SC
    2018 MBM Limited CM
    Filled up this morning. 407 miles on the Trip with 132 miles to empty, quarter tank left according to the dash.
  19. Aug 15, 2023 at 8:08 AM
    #739
    ShawnTRD
    ShawnTRD New Member
    Shawn
    7 mpg???
    Are you running 40" tires?
    JDR76[QUOTED] likes this.
  20. Aug 15, 2023 at 8:13 AM
    #740
    JDR76
    JDR76 New Member
    WA
    LOL...I was towing a 6500 lb brick, in high winds, over the mountain pass... :D
    WFD473, Mike59, HulkSmurf14 and 4 others like this.
  21. Aug 15, 2023 at 8:15 AM
    #741
    ShawnTRD
    ShawnTRD New Member
    Shawn
    Now that makes sense.
  22. Aug 15, 2023 at 8:16 AM
    #742
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I was in the 2 week trip with my family, drove wife's Sequoia with its tiny 24 gallon tank and gas appetite similar to Tundra's. It was very annoying filling it 2-3 times a day, because who knows when you'll see a gas station next time? 38 gallon tank definitely rules.
    JDR76 and ShawnTRD like this.
  23. Aug 15, 2023 at 8:34 AM
    #743
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I know it's an option for the tundra but can you do a 38 gallon swap in the Sequoia?
  24. Aug 15, 2023 at 8:36 AM
    #744
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    No. Sequoia's tank is as big as can be physically fit.
  25. Aug 15, 2023 at 8:46 AM
    #745
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    That's what I was afraid of because of the full cabin.
  26. Aug 15, 2023 at 8:50 AM
    #746
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    It mostly comes from the fact that Sequoia is generally shorter and also independent rear suspension takes more space than solid axle with leaf springs.
    V8 Sequoia updated to Tundra's 2014+ interior, +1-2 feet in trunk and accordingly bigger tank would be a killer vehicle.
    Oh, also a self-leveling rear suspension please, like Sachs/ZF Nivomats. Sturdy, comfortable and no compressor and air lines.
  27. Aug 15, 2023 at 8:58 AM
    #747
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    That would be a solid setup for sure. I'd be on board for that in a heart beat.
    vtl[QUOTED] likes this.
  28. Aug 15, 2023 at 9:03 AM
    #748
    18" TRD Off Road Wheels
    It's not a programming issue. It works as intended. The 38 gallon tank is about 6 feet long and fairly wide. If you are on an incline all the fuel goes to the low end. If you are below the reserve you risk tilting all the fuel away from the pump and have a fuel starvation issue.
    Tsm503[QUOTED] likes this.
  29. Aug 15, 2023 at 9:12 AM
    #749
    All this howling about "I can't use all my fuel!" is completely absurd to me. Am I the only person that grew up having it drilled into me to fill up at a half tank whenever possible and that I better never let it go below a quarter? Where does this obsession with running all the way down and then complaining that you didn't burn every drop come from?
  30. Aug 15, 2023 at 9:13 AM
    #750
    nobodyintexas
    nobodyintexas What?
    South of Houston
    say it again!...for the people in the back.
    BR73, QuikreteTundra, reywcms and 6 others like this.
