38 Gal tank experiences....
Discussion in '2.5 Gen Tundras (2014-2021)' started by KeithM, Mar 19, 2018.
  1. Jan 19, 2021 at 2:32 PM
    #331
    Grizzly660
    Grizzly660 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    Just got my 21' sport with 38 gal tank. Fuel range stated 4 miles but no low fuel light or chimes. Filled up and put 31.2 gallons in. Is there no low fuel light? My 2015 would light up with 30 miles left then still put in 6-8 gallons with 26 gallon tank.
  2. Jan 19, 2021 at 3:04 PM
    #332
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I thought I read here that the low fuel light comes on when you hit 0 miles to empty.
  3. Jan 19, 2021 at 3:27 PM
    #333
    2mchfun
    You are working your fuel pump hard and it may burn up prematurely from lack of fluid cooling it.
  4. Jan 21, 2021 at 6:27 AM
    #334
    fasteddie565
    fasteddie565 New Member
    None, yet.
    You are all very brave souls. I break out in hives when my gas gauge goes below 3/4 of a tank. I was amazed that at 3/4 it takes 9 gallons of fuel.
    FlyingWolfe likes this.
  5. Jan 21, 2021 at 6:30 AM
    #335
    2mchfun
    After they buy a fuel pump or 2, just maybe it will sink in.
    fasteddie565[QUOTED] likes this.
  6. Jan 21, 2021 at 6:32 AM
    #336
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    Paranoia is a hell of a drug...
    Minarets and Cpl_Punishment like this.
  7. Jan 21, 2021 at 6:33 AM
    #337
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    You do it right, fuel economy is always better when you keep it full.
    Granted we drive tundras and we shouldn't even try to act TOO concerned about fuel economy haha
  8. Jan 21, 2021 at 6:33 AM
    #338
    Pine Tree State
    Pine Tree State New Member
    2021 SR5 TRD Sport CM
    I fill up once per week, which usually means half a tank. Whats the point of waiting til filling up 30+ gallons every time? If you were towing and pushing it on distance to save time, Id understand.
  9. Jan 21, 2021 at 6:34 AM
    #339
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Paranoia will distroya..
  10. Jan 21, 2021 at 6:36 AM
    #340
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    You're thinking of 1/4 of a tank as where you shouldnt run below to save the fuel pump.
    Wouldn't it be worse because you're hauling all that extra weight around?
  11. Jan 21, 2021 at 6:38 AM
    #341
    andnyleswillriot
    Breckenridge, CO
    nope. more air space in the tank means more fuel evaporation.
  12. Jan 21, 2021 at 6:40 AM
    #342
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    That's got to be negligible.
  13. Jan 21, 2021 at 6:41 AM
    #343
    2mchfun
    I am just reminding those who are running it low on purpose as they tinker around. Just keep messing around and one day soon they will be needing a new pump due to running hot.
  14. Jan 21, 2021 at 6:41 AM
    #344
    Badknees
    Badknees New Member
    South Carolina
    Why go to the gas station twice as often? I'm too lazy.:D
    Cpl_Punishment likes this.
  15. Jan 21, 2021 at 6:42 AM
    #345
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    My 38gal experience is that its way better than the 26gal I had in my 2nd gen!
    stuckinohio, GODZILLA and 2mchfun like this.
  16. Jan 21, 2021 at 6:42 AM
    #346
    I_Am_Thee_Walrus
    Sure, but it’s something like 1 gallon a year for the average driver.
  17. Jan 21, 2021 at 6:48 AM
    #347
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    FWIW, I've always been told and it makes sense to me, you should not run your tank to empty because you are basically sucking all the sediment into the engine. As a rule I always fill up when at 1/4 tank. YMMV :)
  18. Jan 21, 2021 at 7:01 AM
    #348
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    Board name and message do not equate.
  19. Jan 21, 2021 at 7:02 AM
    #349
    Badknees
    Badknees New Member
    South Carolina
    That's what fuel filters are made for. :) Just joking. I know depending where you are and fill-up, there's sometimes water, debris, and a bunch of other crap coming out of those gas pumps.
  20. Jan 21, 2021 at 7:04 AM
    #350
    2mchfun
    First off there is a screen on the pump intake. Secondly, a filter up the line too, so no sediment. I always buy gas at newer stations because logic says less trash in newer storage tanks. Now filling before low, running low makes the pump run hot due to lack of liquid cooling effect provided by the presence of the gas. So, 1/3 fill up at a newer station and add 2 cans of Berrymans injector cleaner every 3rd oil change. You guys and gals will be pretty happy with your fuel systems health.
  21. Jan 21, 2021 at 7:17 AM
    #351
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Why did you quote me? I was talking about evaporation, not sediment.
  22. Jan 21, 2021 at 7:31 AM
    #352
    2mchfun
    Not sure what happened there! Quoted tchase. My apologies!
  23. Jan 21, 2021 at 7:54 AM
    #353
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    In my own defense I only read the OP post and then posted :) So I'm not sure what you got going on.
    2018TundraLimited likes this.
  24. Jan 21, 2021 at 8:02 AM
    #354
    2mchfun
    Just assuring you that there are ways to deal with the sediment you mentioned.
  25. Jan 21, 2021 at 8:22 AM
    #355
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Absolutely, and one of the easiest ways is filling up at 1/4 tank, I was just sharing information. Like I said YMMV.....
  26. Jan 24, 2021 at 6:08 AM
    #356
    Infernotundra17
    Infernotundra17 2017 Inferno SR5 Crew Max
    Martin
    Las Vegas, Nevada
    2017 Tundra Inferno orange
    Black Rhino 20" Go Rhino RB20 steps Magnaflow muffler
    I with V10ace,had the gen 2 now a gen 3 .Would not have bought it without the 38 gal. tank
    V10Ace likes this.
  27. Jan 25, 2021 at 4:11 PM
    #357
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    I thought the fuel going into the line is always coming from the bottom of the tank, regardless of how full the tank is.
  28. Jan 25, 2021 at 4:19 PM
    #358
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Might be, I know from running fish tanks the poop always stayed to the bottom until the tank gets low an sloshes around :)
  29. Jan 25, 2021 at 5:03 PM
    #359
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
    I put 38.1 gallons in my truck yesterday. 85 miles after it read zero. Love the big tank.
  30. Jan 25, 2021 at 8:05 PM
    #360
    The_Geologist
    The_Geologist I reject your reality and substitute my own!
    Flathead Valley, MT
    2019 Tundra Limited CM Cavalry Blue TRD OR
    Line-X bedliner Century Ultra Topper Thule Rack
    Ok, I'll be honest. When I first ran across this thread I had no clue what folks were talking about.
    Now that I've filled up the tank a couple of times, I understand! The dang fuel gauge is just odd to me. The first time, I thought I was on empty and put in 26 gallons, so I thought I had a 26 gallon tank. The second time, I went a bit further and put in 32 gallons...so I had to rethink my tank's volume...
    Definitely different than filling up my old Silverado. I think that one was around 23 or 24 gallons, and you knew when it was time to fill up.
    The fun things we learn about new vehicles...
