38 gal tank ( do you drive past 'empty' )
Discussion in 'General Tundra Discussion' started by Mostel, Feb 14, 2020.
  1. Oct 13, 2021 at 6:08 AM
    2mchfun
    Btw OP for range..Transfer flow makes a nice 46 gal replacement tank for our trucks.
  2. Oct 13, 2021 at 6:36 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    The 38 gallon tank does not read "empty" at 30 gallons. The low fuel light does come on at about 30 gallons, but the needle on the fuel gauge is still above the E.
    Why do so many people have this concept of a "reserve"? If there is fuel in the tank, you can use it (it is not like we are operating an airplane). There is no reason to maintain a minimum amount of fuel in the tank. The fuel pump does not need fuel around it for cooling. The only way to damage the fuel pump is to run it dry. See these posts:
    Ask the Toyota mechanic! | Page 41 | Toyota Tundra Forum (tundras.com)
    The low fuel light is there to inform you that you should start thinking about refueling the truck. The DTE display is just a gadget; it is an approximation of how far that you can go on your tank. The true estimated distance that you can go on a tank is by obtained by manually calculating your fuel mileage. I have done this with every vehicle that I have owned. For my tundra, I know that when the low fuel light comes on, I have about 112 miles left in the tank. I frequently drive about another 50 miles when the low fuel light comes on. The most that I have ever put in the tank is 35 gallons. Just be smart about when you refuel. Don't run your tank dry.
    Nm6300'asl, WVI, Kratos and 2 others like this.
  3. Oct 13, 2021 at 11:21 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    We don't have one? My wife's 2013 Corolla does... :facepalm:Thanks, Sweers.
    2mchfun likes this.
  4. Oct 13, 2021 at 11:23 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Thank you! The number of people who can't grasp this concept boggles my mind.
    2mchfun and Netmonkey[QUOTED] like this.
  5. Oct 18, 2021 at 12:42 PM
    Lightning_Lad
    Lightning_Lad New Member
    Tom
    Orange CA
    2017 Silver Sky Platinum Pro
    Line x Bed liner Trifold Tonneau cover TRD PRO Dual exhaust TRD PRO sway bar TRD PRO air intake TRD PRO suspension TRD PRO LED 2019 Headlight conversion TRD 2020 Wireless charging tray TRD shift knob TRD PRO Grille TRD red anodized dust caps (+25 hp per wheel) Matt black mirror caps and door handles Tesla style Headunit KTJO 4x4 tail gate pop n lock upgrade Driver side grab handle Viper Remote start Viper alarm system 18” Method NV’s 33.5” Toyo R/T ESP Long box underseat storage 3M ceramic tint
    OP,
    I'm that guy who runs his vehicles down to " ass cheeks fully clenched" levels. Usually with my work provided van... As for my Tundra I go by miles driven after the Distance to Empty light comes on. I figure 10mpg is fairly accurate given I have significantly modded my truck.
    Most I've filled up is 37 gallons. It just really, really hurts doing it all at once, like $183 worth of hurt! (Gas is $4.89/ gal in my neck of the woods)
    Plus most gas stations max out at $125 per fill up and its a PITA to do a 2nd fill up. Been doing this since I've owned my truck in January 2017. No issues so far.
    DIYDad and Cpl_Punishment like this.
  6. Oct 18, 2021 at 2:15 PM
    timsp8
    NY
    Ignore the crappy webpage I found it on, but it’s in the top left of page 92 in this picture. I’ve had it come on before.
  7. Oct 18, 2021 at 5:20 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    37 gallons? Nice.
    I fuel up depending on convenience and proximity to a reasonably priced station. Around here prices can vary by $.30-$.40 a gallon, so it pays to stop at the lower priced stations, or stretch your tank a bit to get to one.
    In my experience, my truck takes about 31 gallons just as the fuel light comes on. 35 is my personal best. so far. ;)
    If I recall correctly, my '00 tundra had a 26.4 gallon tank, and I routinely put about 24 in it. My best was 25.3.
