37's are on !!!!
Discussion in 'Wheels & Tires' started by CM-LENNY, Jan 28, 2017.
  1. Jan 28, 2017 at 6:41 PM
    CM-LENNY
    CM-LENNY [OP] No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    As you know if you've seen my build threads, I like to go outside the box. Not sure if I've ever seen this one done yet. Mounted 37 Nitto G2's on 18x8 60mm off-set OEM wheels, no wheel spacers, no body mount chop. Bought some next to new take off OEM UCA's and did some custom clearance mods to gain .21" clearance over stock. Pressed out the ball joint and had John over at Auto-Fab do some customizing to the outer edge. Still currently have Billy 5100 at top setting up front and custom rear suspension lowered 1-1/4" in the rear from stock. Did some testing with full stuff and droop and no rubbing issues front or rear. Figure with these 37's, I have about 2-1/2" more ground clearance at the diffs over stock. Still have some suspension mods in the works. More to come !!!!!
    Not real world stuff and droop testing, but best I could do in the city.
  2. Jan 28, 2017 at 6:58 PM
    That upper control arm is very scary to me. I would really consider and think twice before you drive it like that, especially with the added weight of 37" tires.
    I know it is expensive as hell for suspension mods, especially on a Toyota and one of the few reasons I do not run them for off-roading (at least the kind I like to do).
    Truck looks great though, and I give you mass kudos for the thought process.
  3. Jan 28, 2017 at 7:04 PM
    CM-LENNY
    San Diego, CA
    That picture is deceiving. It is rolled over at the edge just like the factory. The build shop that cut and welded it has been building and racing off-road trucks for over 40 years. I would not have installed it if I thought it would compromise any of the structural integrity or the safety of me or anyone one the road. I have been playing with cars and trucks way to long to pull a dumb move. Good eye though and appreciate the concern..........
  4. Jan 28, 2017 at 7:07 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Wow Lenny! That is pretty awesome! I love it.
    GodlessPro and AnonVet like this.
  5. Jan 28, 2017 at 7:07 PM
    So how is your alignment?
    040Tundra likes this.
  6. Jan 28, 2017 at 7:13 PM
    CM-LENNY
    San Diego, CA
    Alignment didn't change at all. Just a swap off OEM UCA for OEM UCA with slight mod. The ball joint is in the identical spot. Only reason it was pressed out was to do the welding. It returned to it's identical home. That's why I was saying the modded UCA just gave me .21" clearance gain. Nothing else changed. Sorry that wasn't clear at first.
  7. Jan 28, 2017 at 7:14 PM
    CM-LENNY
    San Diego, CA
    Thanks Joon. Your build is another one I always look for. Keep rockin !!!!
    joonbug[QUOTED] likes this.
  8. Jan 28, 2017 at 7:18 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    ^^^^^^This
  9. Jan 28, 2017 at 7:20 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Actually I'm pretty jelly you got 37's on there. I'm still running stock tires. I need to put a lift on first and even then I'm only going with 35's (I hope).
    37x12.50r20TundraDude and Law323 like this.
  10. Jan 28, 2017 at 7:25 PM
    CM-LENNY
    San Diego, CA
    I run around in the desert and have always been a fan of keeping it low, with as big off a tire you can stuff in there. Granted I have done the 4:88 gears upgrade, which is a must especially with 37's. Some trucks look good lifted too, but I prefer to drive on and off-road with something more stable. You will get more research off this forum then anywhere else. Good luck.........
  11. Jan 28, 2017 at 7:30 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Damn right! :D
  12. Jan 28, 2017 at 7:31 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Who did the bumper?
  13. Jan 28, 2017 at 7:32 PM
    CM-LENNY
    San Diego, CA
    Thanks to guys like Brian and so forth !!!!!!!
  14. Jan 28, 2017 at 7:32 PM
    csuviper
    Broomfield, CO
    Good looking truck. Awesome you fit 37s. Largest I will go is 35 because I'm not wanting to regear
    Medic343 likes this.
  15. Jan 28, 2017 at 7:33 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    This is some fine work bro! I agree 100% with keeping it as low as possible. Easier on slopes and less likely to roll, for sure.
  16. Jan 28, 2017 at 7:35 PM
    CM-LENNY
    San Diego, CA
    Most everything on my truck is homemade. Check my build thread. I just like to be creative and a little different. My wife says I'm different alright !
  17. Jan 28, 2017 at 7:43 PM
    CM-LENNY
    San Diego, CA
    Thanks Brian. I think so many people think our 5.7 can handle anything. With the transmissions designed the way they are today, Re-gear is a must especially at 37's. I always try to research and use common knowledge prior to making big changes. Are they always right ? No ..........but at least I thought about it first..........Thanks to this forum for LOTS of answers. Couldn't do it without this team !
    tundra_20 likes this.
  18. Jan 28, 2017 at 7:46 PM
    csuviper
    Broomfield, CO
    Yea the gearing chart should be examined for any vehicle if you want to jump up in size.
    Went with 4:56 gears in my Tacoma when I jumped up to 35s.
    ColoradoTJ and CM-LENNY[OP] like this.
  19. Jan 28, 2017 at 8:04 PM
    Oh, I see what they did now. Gotcha.
    Like I said before, nice looking rig, you did your research and went balls deep. I'm digging it.
  20. Jan 28, 2017 at 8:05 PM
    I run 5.39's and a 4.3:1 transfer case. When I go LS2, I may need to change the axles a bit so I don't break everything.
    smslavin likes this.
  21. Jan 28, 2017 at 8:06 PM
    CM-LENNY
    San Diego, CA
    Gino......You're on a 6" lift. 37's are just your calling. Hell........I'm at 2-3/8" lift up front and lowered in the rear. YOU CAN DOOOOOOOOOO IT.:bananadance:
    GNTundra and ColoradoTJ like this.
  22. Jan 28, 2017 at 8:18 PM
    CM-LENNY
    San Diego, CA
    That makes sense. Just in time for the first rotation. Just rotate 37's onto your rims, and your current tires rotate to the for sale forum. Makes perfect sense to me. :thumbsup:
  23. Mar 30, 2017 at 4:50 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I've been looking at 35 with 22's and 37 with 22's.. do we have to do a gear change or is it only for towing stuff??
  24. Mar 30, 2017 at 4:51 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I'm going 6 or 7 inch lift
  25. Mar 30, 2017 at 5:05 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You don't have to. But you should, at least for the 37's. Otherwise it'll feel sluggish and hunt for gears a lot.
    Jsena[QUOTED] likes this.
  26. Mar 30, 2017 at 5:19 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Duuuude that looks awesome! Pretty jealous. If my pockets were deep enough id give this a dabble. I only say that because I get a little wild and if I had your setup of drive it like pastrana drives trophy trucks lol. Nice job brotha.
  27. Mar 30, 2017 at 5:43 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    @CM-LENNY are you changing your gears now that's you've put 37's on
  28. Mar 30, 2017 at 5:50 PM
    CM-LENNY
    San Diego, CA
    4:88's are the only aftermarket gear choice at this time and I put them in right after I installed my 285/75R-18 G2s. That's equal to a 35" x 11.25 wide. Our 6 speed auto trans really likes re-gear for any tire over stock. Less heat on the trans and our motors like a little RPM. 37's = mandatory re-gear. Hope this helps.
    Watt maker, geno0506 and Jsena like this.
  29. Mar 30, 2017 at 6:13 PM
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    My truck will have 4.88's installed on Monday:D
    SoCal619 and CM-LENNY[OP] like this.
  30. Mar 30, 2017 at 6:24 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Dang! @CM-LENNY, you are the true definition of moding a vehicle. Congrats and great job!
    CM-LENNY[OP] likes this.
