Discussion in 'Detailing' started by War Machine, Jan 10, 2019.
  1. Jan 12, 2019 at 3:50 AM
    War Machine
    War Machine [OP] SSEM # 5 3MW
    By polish in that case, they mean part of the paint correction. It’s absolutely necessary. Just ask them not to put any wax or sealant on after that.
    You’ll still need to do a strip wash or use something like Carpro Eraser before coating.
    Maybe you can get them to apply CQuartz for you pretty cheap.
    dmiller[QUOTED] likes this.
  2. Jan 12, 2019 at 5:24 AM
    usmchawk
    usmchawk New Member
    Jack
    Maryland
    2018 Tundra Double Cab Limited TRD Off Road - Super White
    TRD Rear Sway Bar Red Interior LEDs Console Safe Victory Rock Sliders Pop n Lock BakFlip4 Bed Mat Led reverse lights Fumoto valve
    I place an order. I've been on the fence with ceramic coating and this seems to bridge that gap between waxing and ceramic coating.
    War Machine[OP] likes this.
  3. Jan 14, 2019 at 3:49 AM
    War Machine
    I got it in. I tested a little spot on my bed cover yesterday. Here’s a pic this morning. It certainly made the spot more hydrophobic.
  4. Jan 14, 2019 at 3:51 AM
    War Machine
    I highly recommend using a respirator with this. I caught a whiff when using it, and this stuff could probably do some damage to your lungs.
    OCxCEMENT likes this.
  5. Jan 14, 2019 at 4:29 AM
    Mnorris1206
    08 tundra
    If its anything like top coat f11 I'm in .That stuff made my 08 shine like crazy
  6. Jan 14, 2019 at 4:57 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Looks good.
    Did you do any special prep?
    Is it over previous wax?
  7. Jan 14, 2019 at 4:59 AM
    War Machine
    No sir, just cleaned it. Nothing was put on it when the truck was coated. I’ve tried several different things, but nothing has wanted to bond with the cover. It has all failed pretty quickly. Hoping this holds up.
  8. Jan 14, 2019 at 7:18 AM
    cjscinta
    cjscinta New Member
    Nashville TN
    I did find the statement about not smelling it a little odd. Must be some nasty stuff.
  9. Jan 14, 2019 at 8:24 AM
    War Machine
    Yeah, pretty harsh.
  10. Jan 14, 2019 at 8:27 AM
    Fishman57
    Wayne
    Bucks County, PA
  11. Jan 15, 2019 at 4:10 PM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    I ordered mine few days ago, got the shampoo, the foam cannon and a note that the spray is on backorder
  12. Jan 16, 2019 at 1:54 AM
    War Machine
    Wow, that didn’t take long.
  13. Jan 21, 2019 at 4:24 AM
    War Machine
    I applied it on my wife’s Sequoia yesterday. I washed, used Iron-X, and Carpro Eraser, and washed again first. I didn’t do any paint correction. It’s MGM, so isn’t showing any swirls, and parts of it need to be repainted anyway. (You can see on the hood there are some bad chips, and the front grill and bumper need replaced.)
    We’ll see how it performs, but application was incredibly easy. Sprayed onto a towel, and wiped on each panel. It flashed really fast. It calls for 1-2 minutes, but flashed much quicker than that. Then wiped it again. That easy. I did use some really cheap towels, since they really aren’t going to be usable again after having ceramic on them. I used the towels that had product on them to wipe the Bakflip cover on my Tundra, then threw them away.
    As usual, pics don’t do justice, but it looks really good. The product is supposed to look even better after the four hour cure time, but it was dark at that point so I’ll have to look again this afternoon.
    50D1AB01-9912-40A3-B1FC-ED745AF2AC79.jpg 65078E69-C678-4BE0-9CC2-A7CEA7BB9A52.jpg
    I tried to get some pics of it flashing, but it didn’t really show up on camera.
    I still had most of the bottle left after doing it. The Sequoia is a very large vehicle, and I feel like I even used more than necessary at points.
    Ultimately, if it performs well, and holds up at least six months, I’d definitely recommend this product to people. Especially those who are on the fence, and want to give ceramic coating a try.
    I’m thinking also that this may be a good topper for those who already have ceramic coating. It would be an easy way to add another sacrificial layer, and extend the life of their coating. (Not sure it would bond well with an existing coating like CQuartz though.)
    driverdog, don3032, Newm and 4 others like this.
  14. Jan 21, 2019 at 6:57 AM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    Interesting... can someone with experience (definitely NOT me) help put together a start to finish "kit" and procedure, assuming we're starting with a brand new truck? Here's my best guess:
    1) Rinse
    2) Wash
    -ADAM'S CAR WASH SHAMPOO 16OZ: https://adamspolishes.com/shop/exterior/carwashing/adam-s-new-car-wash-shampoo-16oz.html
    -ADAM'S 3.5 GALLON DETAILING BUCKET w/ GRIT GUARD: https://adamspolishes.com/adam-s-3-5-gallon-detailing-bucket.html
    -ADAM'S PREMIUM MICROFIBER WASH SPONGE: https://adamspolishes.com/adam-s-premium-microfiber-wash-sponge.html
    3) Rinse clean
    4) Prep for ceramic
    -CarPro Eraser: https://smile.amazon.com/CarPro-Era...?keywords=Carpro+Eraser&qid=1548080671&sr=8-6
    --Spray on, let sit, rinse off
    5) Dry
    -ADAM'S NEW JUMBO GRAY DOUBLE PLUSH DRYING TOWEL: https://adamspolishes.com/shop/acce...s-massive-gray-double-plush-drying-towel.html
    6) Ceramic coat
    -ADAM'S NEW CERAMIC SPRAY COATING 9H 16OZ KIT: https://adamspolishes.com/adam-s-ceramic-spray-coating-9h-16oz-kit.html
    --Follow the instructions
    Job done.
    Yes?
    driverdog likes this.
  15. Jan 21, 2019 at 7:14 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    There are several steps you could do for your paint including IronX, clay bar, polish. And I have always done the eraser as the last step before applying my sealant or wax, and I rub it onto the panel, not just spray and rinse.
    Cement[QUOTED] likes this.
  16. Jan 21, 2019 at 7:24 AM
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    Collinite super double coat last a full year in snow, salt and rain.
  17. Jan 21, 2019 at 7:51 AM
    War Machine
    I would add paint decontamination in there.
    1) Rinse
    2) Wash
    3) Chemical decontamination: Carpro Iron X Iron Remover 500 ml with Sprayer https://www.amazon.com/dp/B004UM6DLE/ref=cm_sw_r_cp_tai_8LErCb4NNAS0Y
    4) Claybar / mitt: Nanoskin (AS-016) AutoScrub Fine Grade Wash Mitt https://www.amazon.com/dp/B00DOS0LH2/ref=cm_sw_r_cp_tai_fNErCb1J97JH8
    5) Wash again
    6) Carpro Eraser
    7) Ceramic
    Most people do machine correction before applying ceramic, but I don’t feel it’s necessary with this product unless the paint is pretty bad or really dark colored.
    Cement[QUOTED] and Skippy like this.
  18. Jan 21, 2019 at 3:06 PM
    don3032
    don3032 New Member
    don
    Did you do rest of the bed cover. Got my order in few days after they sent me the IOU backorder, but too cold to do anything right now.
  19. Jan 21, 2019 at 3:41 PM
    #49
    War Machine
    Yes sir I did. We’ll have to see how it responds.
    don3032[QUOTED] likes this.
  20. Jan 23, 2019 at 5:24 AM
    #50
    War Machine
    I put this on my shower glass yesterday. I didn’t test it yet, letting it cure overnight. We’ll see how it does.
  21. Jan 23, 2019 at 5:50 AM
    #51
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Good place to test it.
  22. Jan 23, 2019 at 6:53 AM
    #52
    War Machine
    Definitely. It gets hit with hot water twice a day at least, so it should be a good test of longevity.
    I’ve used Hydro2 on them in the past.
    Boerseun[QUOTED], Pudge and T-Rex266 like this.
  23. Jan 24, 2019 at 5:16 AM
    #53
    War Machine
    In Adam’s FAQ on the product, they gave tips for applying this on top of an existing ceramic coating, but did not mention what would be gained by doing it.
    I contacted Adams, asking specifically if it would bond with CQuartz, and how it would benefit me to do so. I asked if it increased the longevity of your current ceramic coating. This is their reply:
    “Thank you for contacting us and thank you for your business! CSC does work with existing coatings and offers of course more protection and more shine. I have begun using it on vehicles I come in contact with both coated and not. So I would definitely recommend it for just about everything!”
    As you can see, the response is vague, and did not directly mention CQuartz. What I take from that is that in their opinion, the answers to my questions are “yes”, but they do not want to make specific claims that they could be held liable for. It seems like if I were off base, they’d have directly said no.
    I know some that some companies will hesitate to put something in writing, even if they believe it to be true. Specifically, Jeremy at Shine Supply has told me privately that something would work, but that he didn’t want to advertise it. He said “guys will have a tendency to have unreasonable expectations on the product”. Also, I’m sure there are legal issues if they advertise that something improves another company’s products.
    Anyway, in my opinion, it seems like Adams Spray Ceramic would be a good “refresher” on CQuartz. By adding it once or twice a year, I’d think it would extend the life of it. It would be a really strong sacrificial layer.
    Do you guys agree/disagree with my thoughts? @SouthBoundSteve @driverdog @Pudge
  24. Jan 24, 2019 at 6:24 AM
    #54
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Adams does have an Iron remover and clay bar to stick with all adams products
    https://adamspolishes.com/shop/exterior/carwashing/adam-s-contamination-removal-kit.html
    Also a strip wash
    https://adamspolishes.com/shop/exterior/carwashing/adam-s-strip-wash-16oz.html
    don3032, RoujePN and smslavin like this.
  25. Jan 24, 2019 at 8:24 AM
    #55
    War Machine
    I agree with everything you say. Surely not necessary, but I already have the spray, and it can’t really hurt. I know some people put multiple coats of CQuartz on, so I’d say it’s similar to that.
    And I’m a sucker just like you. My truck is coated, but no way am I not going to keep applying stuff to it. I enjoy it too much. It was a big reason I held back on ceramic to begin with. I didn’t want to stop doing all of that.
    I’ll probably end up stacking so much stuff on it that it will be bulletproof a year from now.
    Newm, driverdog, T-Rex266 and 4 others like this.
  26. Jan 28, 2019 at 11:46 AM
    #56
    War Machine
  27. Feb 16, 2019 at 11:04 AM
    #57
    Purchased this yesterday. Anything I need to do before hand other than wash?
    Do I need to buff it out hard or just spray and wipe down like I would be drying water?
  28. Feb 16, 2019 at 6:05 PM
    #58
    War Machine
    Yeah, like drying water. Maybe a little more. It comes off pretty easily.
    As for prep, it’s up to you. I used Carpro IronX and Eraser first, but I already had it on hand. Not sure it’s completely necessary since this isn’t a full on ceramic coating.
    Just don’t breathe it in. I caught a whiff and it’s pretty harsh.
  29. Feb 16, 2019 at 6:17 PM
    #59
    If I apply this then does it limit the vehicle waxes too or?
  30. Feb 18, 2019 at 10:29 AM
    #60
    War Machine
    As in does it need waxing, or should you?
    It won’t need it, but you can. Wax will make it shine more, but won’t really add protection.
