37" tires = RE-GEAR
Discussion in 'Wheels & Tires' started by JTP, Jun 2, 2017.
  1. Jun 12, 2017 at 5:47 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
  2. Jun 12, 2017 at 5:53 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I called Auburn Gears to ask this exact question. The simple explanation is that the stock rear diff puts the power transfer to the driver rear driver tire when it slips. When you install the automatic Auburn LSD it will transfer the power to both rear tires instead of just one tire. This is a big advantage for loose conditions like dirt, sand and snow. If you already doing a gear swap it doesn't cost much for the labor mainly just the LSD parts. So around $500-$600 more for LSD.
  3. Jun 12, 2017 at 6:21 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I agree,
    Buy once cry once
    papasmurf and Dustydirt19 like this.
  4. Jun 12, 2017 at 7:12 PM
    FLTrucks
    FLTrucks New Member
    12" lift on 38's and tow a 5000# TT. I do have a lot of lost power when ascending hills and the transmission goes through shifts a lot on inclines. A re-gear is absolutely necessary when when running my setup and will be getting. As for those who are one 35's it may not be required but will be worth a look at doing.
  5. Jun 13, 2017 at 8:01 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    Not on this blue truck. This truck was built way before the bump stops were released.
  6. Jun 13, 2017 at 8:45 AM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    Any link to that build?? If not, what kind of numbers did you get with the SC with methanol injection and custom tune??
  7. Jun 13, 2017 at 9:24 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    Im doing 4.88 this fall, ill be doing nitro gears.. ive been on 37's for a year and before that I was always on 35's Ive never driver a stock tuindra so im not sure what factory gearing and tire size feels like, so im sure it will be a major improvement for me.. should be interesting.
  8. Jun 13, 2017 at 9:26 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Usually makes me see fantastic colors. :p
  9. Jun 13, 2017 at 9:55 AM
    sdhq_offroad
    GILBERT, AZ
  10. Jun 13, 2017 at 2:15 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Makes me follow Alice places I shouldn't
    joonbug[QUOTED] likes this.
  11. Oct 8, 2020 at 12:14 PM
    LA184
    LA184 Living the Dream
    2014 4x4, 4.6L Radiant Red Tundra
    4 in lift, 35s, Black Rhino Armory Wheels, Custom Rock Sliders, SDHQ ABS Guards, Warn Winch Bumper, Warn Evo VR 12-S Winch, 4.88 Re-Gear, Rear E-Locker.
    How has your Tundra been holding up these past few years with 4.88s and 37s? I have 4.88s and have thought about 37s in the future.
  12. Oct 9, 2020 at 6:56 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    great!! no issues what so ever, although I kinda wanna go 5.29's but that is for other reasons
    osidepunker and LA184[QUOTED] like this.
  13. Oct 13, 2020 at 10:26 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    same here. 488 and 37s been working very well. 529 would be better I think, but at the time they weren't proven. Ill probably switch in the next year or two
    LA184[QUOTED] and papasmurf like this.
  14. Oct 13, 2020 at 2:46 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    :anonymous::spending::welder:
    osidepunker[QUOTED] likes this.
  15. Oct 28, 2021 at 4:52 PM
    Corr2626
    Corr2626 New Member
    Corey
    2014 Tundra Limited
    Currently on 35's in my stock 4.10's '14 and thinking of going 4.88 or even 5.29. Have you made the switch yet? I also pull heavy toy hauler and thinking the 5.29's might be a better choice but I'm certainly no expert on the subject.
  16. Dec 12, 2021 at 9:54 PM
    brandonf
    brandonf New Member
    37's with 5.29's here. My personal experience from re-gearing vehicles has been to go lower than the numbers and calculated RPM's may suggest. Since the 5.7 Tundra's all have 4.30's to begin with, I would recommend going straight to 5.29 for anyone considering a re-gear. I would not bother with the 13% change of going from 4.30 to 4.88 now that 5.29's are available for these trucks.
    AstroDude and TravisJr like this.
