37’s on 20” rims with 6” lift
Discussion in 'Wheels & Tires' started by Navygunner, May 19, 2020.
  1. May 19, 2020 at 3:28 PM
    Navygunner
    Navygunner [OP] New Member
    2020 tundra crewmax 4x4
    6 inch rough country lift, 35” pro comp tires, S&B cold air intake
    Does anyone know if 37” tires will fit on 20” rims with a 6” lift? Anyone also know if I run 37’s do I have to re gear my truck? I’m running 35’s now but they look really small with all the space in my wheel well.
  2. May 19, 2020 at 3:32 PM
    ChargedToyo
    ChargedToyo New Member
    Mario
    2010 Grey
    I’m on a 3 inch lift and 37s on 18s. You might want to look at the dirty sevens forum they might have more info for you.
  3. May 19, 2020 at 3:41 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I had 35’s on 20” Methods. Just switched to 17” Icons with the 37’s and I did do a body mount chop up front because of rubbing. And will likely be re-gearing in the future.
    37x12.50r20TundraDude likes this.
  4. May 28, 2020 at 2:53 PM
    37x12.50r20TundraDude 37x12.50r20TundraDude
    Tomas
    CORPU SCHRISTI , Texas
    2015 Tundra crewmax 4X4 5.7L FFV
    6in. Lift 37x12.50r20
    mine came like this 6" rough country lift and 37x12.50r20 rims are 20x9 BMF ET 12
    DevinH18Platinum likes this.
  5. May 28, 2020 at 2:57 PM
    DevinH18Platinum
    DevinH18Platinum New Member
    Devin
    2018 Platinum.
    4 inch lift on 33s
    Nice truck!
  6. May 28, 2020 at 2:57 PM
    DevinH18Platinum
    Devin
    2018 Platinum.
    4 inch lift on 33s
    Great looking truck!!
  7. May 28, 2020 at 3:04 PM
    Tomas
    Ty sir did you need to regear the front and back on your truck?
  8. May 28, 2020 at 3:20 PM
    DevinH18Platinum
    Devin
    2018 Platinum.
    4 inch lift on 33s
    No. I’m on a 4” lift and 33X12.5R22.
  9. Apr 26, 2024 at 10:48 PM
    WhiteDevil1978
    WhiteDevil1978 Ye Olde White Devil
    Dustin
    North Carolina, 'Murica
    2023 Tundra SR5 TRD Off-Road
    6 inch lift, 37 inch tires, Badlands Apex 12,000 lb winch, Fab Fours concealed winch mount with 30 inch LED, Prinsu roof rack with RC 40 inch LED and 10 inch RC LED's on sides, Auxbeam 12 switch controller, Heretic ditch lights, RetraxPro XR bed cover, Elevate bed crossbars with additional bar that connects them, Pedal Commander throttle control, overlanding solar array (2) LiTime 230ah batteries, Renogy 40 amp DC to DC charger, LiTime 60 amp MPPT, LiTime 40 amp LiFePO4 AC to DC charger, Renogy 400 watt suitcase panels
    I'm sure this was resolved long ago, but Tuesday I am having a 6 inch lift and 37x12.50r20 tires put on my factory 20 inch wheels. I bought the appropriate spacers to give me an offset of what the Suprrlift lift kit says is required, which is +18 to +20. Ain't but one way figure out if it will work or not, so here we go!
  10. May 9, 2024 at 4:53 PM
    longuyen88
    longuyen88 New Member
    37s on stock suspension and stock 20” wheels. No lift. Rubs swaybar in full lock going reverse. Otherwise no rubbing. It’s a huge misconception that higher lift = more clearance.
    b6graham likes this.
  11. May 9, 2024 at 6:12 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You should be regearing on 35s and 37s. Your truck will feel light years better with 5.29s
    TravisJr likes this.
  12. May 10, 2024 at 5:52 PM
    WhiteDevil1978
    Dustin
    This is the end result. 6" Superlift, 37" Nitto Ridge Grapplers, OEM 20" TRD Wheels, 1.5" wheel spacers. Minor trimming as stated required, absolutely zero rubbing anywhere, even off road.
    Racls6821 likes this.
  13. May 10, 2024 at 5:57 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I ran spacers on the rear of my long travel truck, i run them on all 4 corners of my current truck. Ive personally never seen an issue with them when installed properly. Guys jump long travel trucks with them in the rear all the time
  14. May 19, 2024 at 11:19 PM
    Racls6821
    Racls6821 New Member
    That looks really good!
    Does a lift kit need wheel spacers to clear rubbing issues? Find a blog talking about this.
    I'm a little confused, are offset rims better or spacers?
  15. May 19, 2024 at 11:30 PM
    WhiteDevil1978
    Dustin
    Thank you!
    For my exact application (20 inch factory TRD wheels, 6 inch Superlift kit and 37 inch tires), yes, the 1.5 inch wheel spacers are a must. You can go MORE than 1.5 inches, but not less (with those wheels). As far as ANY lift needing spacers, I do not know. I just know that Superlift says that at least 20 inch wheels are necessary for this lift. For 20x8 wheels, an offset of +18 to +20 is necessary. The offset for my factory 20 inch TRD wheels is +55, but a 1.5 inch spacer takes that down to +17, if my math is right.
    Something else worth noting is that contrary to what some people and companies say, 12.50 inch wide tires DO fit perfectly on an 8 inch wide wheel.
    As far as "Which is better?" on a spacer or a wheel, IMO it doesn't really matter. All that matters is getting the right offset for whatever lift kit you choose.
    Racls6821[QUOTED] likes this.
