35s on TRD rims
Discussion in 'Wheels & Tires' started by Elfine, Dec 1, 2019.
  1. Dec 1, 2019 at 1:48 PM
    Elfine
    Elfine [OP] Doing my best to break this beast
    Pensacola, FL
    2017 Quicksand Tundra TRD
    Datin Metal Fab 18" Bed Rack, ARB Diff Breather, SDHQ ABS Guards, RCI Engine/Transmission/Fuel Skid, ICON Stage 5, Rago Bed Stiffener/Ditch light brackets, ARB twin air compressor, 295/70R18 Cooper Evolution M/T, Spydertrax 1.25" spacers
    Good afternoon! I just purchased my new lift (Icon stage 5) and am looking at making the jump to 35s. Money is tight however so for the time being I am looking to try and use my stock TRD rims and put 295/70R18 STT pros on them. I know that I might have to do a BMC, but is there any glaring issue with this plan that I am missing? Thanks in advance.
  2. Dec 2, 2019 at 3:49 AM
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    Don’t think you’ll need the BMC with TRD wheels and stage 5 icon. Nice lift
    Elfine[OP] likes this.
  3. Dec 2, 2019 at 4:31 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    295's will not need a bmc on factory wheels for sure. Front wheel spats are the most that would have to come off, I was able to keep mine by adding a 3rd screw in middle of spat (there is a good 1/2" 'slack' in them the way they are oem mounted).
  4. Dec 2, 2019 at 5:01 AM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Also consider 295/75/r18 for stock wheels. This is what is on my radar. Slightly narrower, basically 35x11.
    Just saw you’re looking at a particular tire model. Don’t think they come in this size. It may be worth a look at other brands to get the size you want.
  5. Dec 2, 2019 at 5:57 AM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    I'm running 5100s at top setting and TRD wheels on 305/65/18R BFGs KO2 it it does not rub. I also added 1" Bora spacers.
  6. Dec 2, 2019 at 12:57 PM
    Elfine
    Pensacola, FL
    Awesome! Thank you everyone for the quick responses!
  7. Dec 4, 2019 at 8:20 AM
    MaxYota
    MaxYota GrilledCheese
    Murf
    MS Gulfcoast
    2019 TRD PRO VooDoo Blue
    Mighty Mouse suction cupped to the review 8 ball shifter. Driver side "Oh poop" handle. Smoked side window deflectors. ReadyLift TRD PRO +2 for front. 1.5" ProFormFab Shackles + 1" ToyTec block for rear. SDHQ Hidden winch mount with Badlands 9000 winch. 305/70r18 Cooper Discoverer STT PRO
    Do you have a pictures? With the Pro wheels being the same size and offset, I'm wanting to do the same tire/spacer as your set up. Just want to see how far it kicks it out. Not telling you to do a full photo shoot buuut some front, down the side and from the side shots would be great.
  8. Dec 4, 2019 at 8:24 AM
    619Tundra
  9. Dec 4, 2019 at 8:27 AM
    619Tundra
    D4x4TRD and MaxYota like this.
  10. Dec 4, 2019 at 8:28 AM
    619Tundra
    The second pic is without the spacers.
  11. Dec 4, 2019 at 12:48 PM
    MaxYota
    Murf
    MS Gulfcoast
    Awesome Thanks. That's a nice looking rig.
    619Tundra likes this.
  12. Dec 4, 2019 at 1:56 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I did 305 70 18s on my 2016 with 2" spacers, had to do the bmc, the rubbing wasn't bad at all, removed from mud flaps and pushed plastic forward, that was on 3" lift. Then I added a fab fours bumper, that helped alot for clearance
    D4x4TRD likes this.
  13. Dec 4, 2019 at 4:53 PM
    mundra
    mundra New Member
    2019 platinum 4x4
    D5EBFD24-3A95-4D89-AF03-86CB33B8FFFE.jpg Just put on 315/70/17 Nitto ridge grapplers on rock warrior wheels, 2019 platinum stock height and remove mud flaps. No rubbing at all. Surprised it worked... sort of since this forum helped so much.
    Iowa12tundra and D4x4TRD like this.
