35s on my 17 Pro
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by jmevis, Dec 25, 2018.
  1. Dec 25, 2018 at 8:29 AM
    jmevis
    jmevis [OP] New Member
    Nashville TN
    2017 Tundra Trd Pro
    Kilos and Hammerhead like this.
  2. Dec 25, 2018 at 9:21 AM
    Pics when done
    porkitt likes this.
  3. Dec 25, 2018 at 10:50 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    Pics before too???
    ackthresher, Ostrich, lionix and 5 others like this.
  4. Dec 28, 2018 at 8:25 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    Well went ahead and ordered the CB Pro Kit and Bora 1.25 Spacers.
    Cemented likes this.
  5. Dec 28, 2018 at 8:56 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Are you doing a body mount chop? I didn’t think you could fit 35s without doing that.
  6. Dec 28, 2018 at 12:30 PM
    209TRDPRO
    209TRDPRO New Member
    2016 Tundra TRD PRO
    Just lights for now
    I didn't. I remove front mud guard. I should have use heat to push it in but removed. Also depends on tire manf. I got Nitto Terra G2 and they fit like a glove.
    JH5370[QUOTED] likes this.
  7. Dec 28, 2018 at 1:15 PM
    RoninPro
    RoninPro Abecedarian BASTRD
    East Bay
    17 CM TRD Pro
    17 CM Pro with 3” coachbuilder, 1.25” spacers, bmc & 35x12.5xR18 KO2’s.
    OR18TRD, sr5shark, driverdog and 2 others like this.
  8. Dec 29, 2018 at 10:33 PM
    Cemented
    Cemented Function over Form
    Manuel
    2017 Cement TRD Pro
    I think you’ll be happy. Same set up I have except with spidertrax 1.25”
    jmevis[QUOTED][OP] likes this.
  9. Jan 2, 2019 at 8:53 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    Beautiful... This is exactly what I want to do. But you had to do the BMC?
  10. Jan 2, 2019 at 9:27 AM
    Cemented
    Manuel
    2017 Cement TRD Pro
    Not sure for @RoninPro but i was able to fit mine fine without BMC needed -- with the stock pro wheels and 1.25" spacers. I ended up doing a BMC later just in case I ever want different wheels and need it, but I never rubbed with that setup.
    sr5shark and jmevis[QUOTED][OP] like this.
  11. Jan 3, 2019 at 12:09 AM
    RoninPro
    East Bay
    17 CM TRD Pro
    @Cemented, I was definitely rubbing in the front and the back. I think it depends on the types of tires you pick also. I wanted the BFG's so their pattern caused them to rub. With the bmc you know it won't rub.
    sr5shark likes this.
  12. Jan 3, 2019 at 5:07 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    Alight cool. I was planning on installing the CB kit my self, but I have never done any grinding or cutting. So I'll have to find a local shop to do that.
  13. Jan 3, 2019 at 10:49 AM
    Cemented
    Manuel
    2017 Cement TRD Pro
    Interesting because we have the same exact tires -- I ran my BFG KO2 35x12.5 for 15k miles before doing my BMC and wasn't ever rubbing in the back, just did it because I had the plates and figured may as well. I did have to remove the mudflaps in back and obviously had to make clearance in the front but the BMC wasn't necessary. I can imagine slight variations from truck to truck may cause that.
    jmevis[OP] likes this.
