35's no regear - Any regrets?
Discussion in 'Performance and Tuning' started by UTAHRTK, Jan 29, 2025.
  1. Feb 7, 2025 at 4:03 PM
    #121
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    yeah well im not shelling out 2k for a gear change thats for sure
  2. Feb 7, 2025 at 8:52 PM
    #122
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    That’s no problem! You’ve chosen cheap, now you get one more choice. Fast, or right?
    The fun part is that all three of the attributes in my smartass post are absolutely subjective.
    I didn’t pay $2K, but it also took most of a week to get it done. You could say I chose cheap and right. Still didn’t feel cheap! Definitely wasn’t fast. They’re still together though.
    Hope you get what you need!
  3. Feb 7, 2025 at 8:56 PM
    #123
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    2k isn’t bad at all after seeing other people post their charges. Getting the install done right isn’t something you want to be frugal about
  4. Feb 8, 2025 at 6:20 AM
    #124
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    I’d pay $2k to have it done right. Noisy gears are infuriating. And to do it over would be over more. But quality product. Pay a knowledgeable experienced person a fair price to install and enjoy the benefits. Or take short cut and bitch about it forever afterwards.
    FrenchToasty and Mdl like this.
  5. Feb 8, 2025 at 8:32 AM
    #125
    NatesNightMare
    Pinetop Az
    noisy gears is because of the gears, not the install. to make them quieter they need machined a bit. you paid extra for the machining. i dont care as my truck is loud to begin with (SC and 3" exhaust)
  6. Feb 8, 2025 at 9:01 AM
    #126
    Chad D.
    Chad D. New Member
    Western Oregon
    I’d say this is partially accurate.
    A quality set of gears that are poorly set up can be noisy.
    A crap set of gears will typically be noisy, but the extent of this may be affected by the install. A good installer will often have a few tricks up his sleeve that will reduce the irritation of cheap gears.
    Kinda like how a good alignment guy can make your big tires fit…
    MVRCA, Silver17 and helidave like this.
  7. Feb 8, 2025 at 9:17 AM
    #127
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’ve read complaints of noise on seemingly every brand of gears installed by a variety of allegedly highly experienced installers. There seems to be a degree of luck in regards to the noise. Just do a search for gear noise related posts on here or the Tacoma forums and you can read for quite a while on the subject. Fingers crossed I have the luck on my side.
    MVRCA, Mdl and NatesNightMare like this.
  8. Feb 8, 2025 at 9:20 AM
    #128
    NatesNightMare
    Pinetop Az
    same as long as its not annoyingly loud i dont mind some gear noise lol :notsure: just all part of the upgrades
  9. Feb 8, 2025 at 10:25 AM
    #129
    Chad D.
    Chad D. New Member
    Western Oregon
    I’d agree with this. I can’t think of a single set of aftermarket that run as silent as OEM. Some are quiet, but not THAT quiet.
  10. Feb 8, 2025 at 10:36 AM
    #130
    ScenicRoute
    Speaking from my own experience as someone who has taken apart a quiet running gear set to install a locker and reinstall the same gear set…noise can absolutely be generated from the install….then find someone to show me what I did wrong and the gears are suddenly quiet again.
    So 1000% a good set of gears can be made noisy by an inferior install.
    I have every tool to properly install ring and pinion and press on and remove bearings correctly but I lack the skill/experience/knowledge. So hence I’d pay someone who I know would do a good job a $2k sum of dollah bills yo to do it right!
    MVRCA and FrenchToasty like this.
  11. Feb 8, 2025 at 10:41 AM
    #131
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    After speaking with Zuk. He's spending more rime to get it dead on, more so than before. Some gears noisy but in reality shouldnt. He saw my pics of the pattern that were really good. Had some noise. Reason he suggested getting them REM'd and going a tad shallower on the 5.29.
    My front 5.29 are noise free and I've been driving g in 4x for 700 miles now.
    Silver17 and FrenchToasty like this.
  12. Feb 8, 2025 at 11:02 AM
    #132
    MVRCA
    MVRCA New Member
    Las Vegas
    2016 Tundra TRD Pro
    White Knuckle sliders, BDS 3" lift with Fox 2.5's. Method 305 NV with 35" Trail Grapplers.
    My approach is much others here; spend the coin and get the best shop for the work. I'm budgeting $6k for premium 5.29's new bearings, e locker and complete install.
    Mdl likes this.
  13. Feb 8, 2025 at 12:20 PM
    #133
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I was around $3750 total for REM'd Revolution 5.29s and a powertrax, with me pulling the diffs and taking them to ZUK for the setup. $5-6k sounds high, but I guess it depends on the labor charge and your local options.
    FrenchToasty likes this.
  14. Feb 8, 2025 at 12:25 PM
    #134
    centex
    centex New Member
    My Sierra gears and master install kits were $2100 shipped from dirtydeeds and the install was around that as well. I was in it for 4k or a little under.
    MVRCA likes this.
  15. Feb 8, 2025 at 1:17 PM
    #135
    MVRCA
    MVRCA New Member
    Las Vegas
    2016 Tundra TRD Pro
    My idea is to drop my truck off and come back with it complete. I don't have the time or know-how to drop diffs and bring them to a shop. We did the suspension work on our own, but that's about the limits to my skill set.
  16. Feb 12, 2025 at 2:18 PM
    #136
    NatesNightMare
    Pinetop Az
    go figure rear bearing kit was to ship today, now its back ordered till april :frusty:
    trying to find a damn replacement near the same price
  17. Feb 14, 2025 at 3:32 PM
    #137
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    I had a 21 tundra with 33 inch e rated wildpeaks and currently have a 16 with 35 inch e rated dynamo at2 extremes and there is a pretty big noticeable difference, on my 33 inch tundras if you gave it a little gas it would throw you back into your seat on this one not so much at all and there feels like no top end power
    Once I save enough I will regear with a rear e locker
  18. Feb 14, 2025 at 4:02 PM
    #138
    rcsbguy
    rcsbguy New Member
    https://www.tacomaworld.com/threads/sibi-built-2025-regear-groupbuy-6-20-spots-filled.840787/
    IEsurfer[QUOTED] likes this.
  19. Feb 15, 2025 at 4:36 PM
    #139
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    Are you sold on a E locker ? Speedmaster rear end sure is fun if you haven’t researched it.
