35's no regear - Any regrets?
Discussion in 'Performance and Tuning' started by UTAHRTK, Jan 29, 2025.
  1. Feb 3, 2025 at 9:49 AM
    #91
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    I pm'd his number.
    MVRCA[QUOTED] and FrenchToasty like this.
  2. Feb 3, 2025 at 10:08 AM
    #92
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    yeah that would be a no for me then
  3. Feb 3, 2025 at 10:10 AM
    #93
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Be patient, I have a feeling a lot of people will have cores for sale soon, thats how I did it so I could still drive the truck
  4. Feb 3, 2025 at 1:50 PM
    #94
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    #94
    FrenchToasty likes this.
  5. Feb 3, 2025 at 3:45 PM
    #95
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Well here I am with a fully modified FJ and a pretty close to stock tundra lol. :fistbump:
  6. Feb 4, 2025 at 11:06 AM
    #96
    NatesNightMare
    Pinetop Az
    so considering ive only got 55k miles on my truck could i just get the mini install kits instead of a full master kit?
  7. Feb 4, 2025 at 1:25 PM
    #97
    rcsbguy
    rcsbguy New Member
    Full master kit always. Koyo bearings only. Cheaping out isn’t worth it. Or just bring it to socal and get it done in two days for less than $3K, parts and labor.
    Lemuel1 likes this.
  8. Feb 4, 2025 at 3:26 PM
    #98
    NatesNightMare
    Pinetop Az
    ill get the gears and kit (depending) for under 1k, im hoping to definitely NOT spend 2k on labor :rofl:
  9. Feb 4, 2025 at 3:33 PM
    #99
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I was surprised how well my rear pinion and carrier bearings were. My front head pinion and carrier showed heavy wear. I was quit shocked and suspect the front diff was out of spec from factory, maybe good enough?
    You could get away with inspecting the bearings and make a call based on race/bearing wear but you would need to be in the position to get bearings if they were bad. If it were a new rig with only 2 years of light use you could get away with reusing it but be safe and pay once/cry once!
  10. Feb 4, 2025 at 5:05 PM
    #100
    NatesNightMare
    Pinetop Az
    i never stay in 4wheel for long if i need it. longest ive staee in 4wheel was beginning of jan coming back from oregon and the road was a sheet of ice. even then still only drove under 60mph
  11. Feb 4, 2025 at 5:18 PM
    #101
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I've re-used bearings before but it's mostly been an Dana 44/60's where bearings are cheap and available at any store. It would be your call to re-use them. Many have reused but would suck to have to go back in later on. Just a bunch of what if's...
  12. Feb 4, 2025 at 5:23 PM
    #102
    NatesNightMare
    Pinetop Az
    i get it. im just asking because of my low miles and i really dont go out 4 wheeling, if ever. and like i said im always in 2 wheel, only use 4x to get out or pull someone out or nasty road conditions
  13. Feb 4, 2025 at 5:39 PM
    #103
    rcsbguy
    rcsbguy New Member
    Just a btw try and cycle 4WD once a month for at least 5 miles. If you don't exercise it, the ADD actuator will get faulty
    MVRCA and NatesNightMare[QUOTED] like this.
  14. Feb 4, 2025 at 5:44 PM
    #104
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    When Zuk did my front, he reused bearings. Rear needed new bearings at 150K.
  15. Feb 4, 2025 at 8:02 PM
    #105
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I re-used my rear bearings when I did my Auburn at 50k. I decided to put new in when I went with Speedmaster and 5.29's. Just need to be prepared if you need new bearings.
  16. Feb 5, 2025 at 7:54 AM
    #106
    MVRCA
    MVRCA New Member
    Las Vegas
    2016 Tundra TRD Pro
    White Knuckle sliders, BDS 3" lift with Fox 2.5's. Method 305 NV with 35" Trail Grapplers.
    Where in So Cal are we talking? I'm not far from there as well. Thanks.
  17. Feb 5, 2025 at 9:09 AM
    #107
    rcsbguy
    rcsbguy New Member
    Placentia, CA
    MVRCA[QUOTED] likes this.
  18. Feb 5, 2025 at 2:14 PM
    #108
    MVRCA
    MVRCA New Member
    Las Vegas
    2016 Tundra TRD Pro
    This is doable. Thanks for the intel.
    s
  19. Feb 5, 2025 at 3:23 PM
    #109
    NatesNightMare
    Pinetop Az
    yeah 10hr drive for me, not happnin lol.
  20. Feb 6, 2025 at 10:52 PM
    #110
    NatesNightMare
    Pinetop Az
    well at least i was able to find both master install kits for just over $500 total
    Silver17, KH1414 and Mdl like this.
  21. Feb 7, 2025 at 4:27 AM
    #111
    KH1414
    KH1414 New Member
    Kenny
    2019 SR5 TSS
    Alpharex tails, RC nerf steps, TRD Pro rear sway, Klearz 3rd brake smoked lense
    Where?
  22. Feb 7, 2025 at 4:36 AM
    #112
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Heck of a deal! I got both for 686 and I thought that was amazing. Do the kits have the shims and everything?
  23. Feb 7, 2025 at 8:18 AM
    #113
    NatesNightMare
    Pinetop Az
    after further review the front ont was wrong and for a 9.5 rear
  24. Feb 7, 2025 at 8:18 AM
    #114
    NatesNightMare
    Pinetop Az
    summit
  25. Feb 7, 2025 at 8:58 AM
    #115
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Any New Hampshire or vicinity installers recommended?
  26. Feb 7, 2025 at 9:11 AM
    #116
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I used the ntn kit. It has koyo/skf bearing. Although I bought it on rock auto which is still out. The G2 kit is supposed to be for 9 inch front. Call G2 to confirm.
    https://www.summitracing.com/parts/ntn-nbdrk382mk
    https://www.summitracing.com/parts/gta-35-2062/make/toyota
    Or if you can wait a month order front bearings from Amayama. Minus the tail bearing. And grab a mini install kit. Or just reuse your front bearings with the mini kit. Email gearinstalls and ask about reusing front bearings. He's done it many of times.
  27. Feb 7, 2025 at 10:11 AM
    #117
    NatesNightMare
    Pinetop Az
    im thinking about the mini kit for the front
  28. Feb 7, 2025 at 10:12 AM
    #118
    NatesNightMare
    Pinetop Az
    yeah thats the rear i got
    Mdl[QUOTED] likes this.
  29. Feb 7, 2025 at 1:26 PM
    #119
    NatesNightMare
    Pinetop Az
    everything ordered now to look around town to see whos more affordable for installs
  30. Feb 7, 2025 at 2:35 PM
    #120
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Just food for thought, and everyone gets to make their own choices. But, when looking for professional services I think there are three very important things to consider.
    In a perfect world, we look for the following:
    Cheap
    Fast
    Right
    In reality, you can only choose two.
    Worth considering…
