35" Tires
Discussion in 'Wheels & Tires' started by kevjr16, Jun 8, 2018.
  1. Jun 8, 2018 at 2:17 PM
    kevjr16
    kevjr16 [OP] New Member
    New to the forum...I have a 2nd generation Tundra 4x4. I am currently running 33x12.5x18 Toyo R/T's on my stock Tundra. I am interested in going to 35" Toyo R/T's and getting a 3" level kit. Does anyone know if the 3" leveling lift kit will allow 35" tires or if I may need to do some trimming? If trimming approx how much trimming is needed? I called a local shop in my area (San Diego) and they told me that if I went with a 4" suspension lift I would have to run 35" Toyo's on 20" wheels? Doesn't seem to make sense but not sure. Any help/suggestions would be great.
  2. Jun 8, 2018 at 2:59 PM
    SCSPerformance
    SCSPerformance #teamstealth Vendor
    Vin
    Bay Area, CA
    A 3" lift can accommodate 35s, but you'll need to do a cab mount chop for good clearance. Remove the front mud flaps and some lighter liner trimming and you'll be golden.
    zcarpenter92 and joonbug like this.
  3. Jun 8, 2018 at 3:01 PM
    kevjr16
    Any clue as to how much a cab mount chop might cost at a specialty shop?
  4. Jun 8, 2018 at 3:02 PM
    SCSPerformance
    Vin
    Bay Area, CA
    Labor rates will depend on what area/state you're in. In CA, it can be around $120-150 to do both sides.
    joonbug likes this.
  5. Jun 8, 2018 at 3:03 PM
    kevjr16
    Ok good to know, thanks for the info!
  6. Jun 8, 2018 at 3:19 PM
    TheBeast The Beach
    if you in san diego area I can recommend a great guy for Toyota work. He will install your suspension and CMC no pb to clear 35"s. he is in Vista,CA
  7. Jun 8, 2018 at 5:41 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    How was the fender and body lining tucked back?
  8. Jun 8, 2018 at 5:45 PM
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    You might get lucky. I run 35x12.5 with a little less than 3” lift and didnt have to chop cab mount. They barrrrrrrrely touched it at full lock/full stuff. That is with a 18x9 +18 wheel.
    Depending on offset and width of rim will determine how much you will need to trim or ‘massage’ the plastic inside the fender and may need to trim a bit on the bumper(not visible).
    Black Wolf likes this.
  9. Jun 8, 2018 at 7:12 PM
    TheBeast The Beach
    notched, pinched and folded back
  10. Jun 8, 2018 at 7:20 PM
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    When in doubt, chop it out!
    TheBeast likes this.
