34.5 on leveled first Gen tundra?
Discussion in 'Wheels & Tires' started by Need to know stuff, Apr 8, 2018.
  1. Apr 8, 2018 at 10:02 PM
    Need to know stuff
    Need to know stuff [OP] New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    I just got a tundra and am planing on leveling it with 3 inch struts spacers and was wondering ifii could run 34.5x12.5 grabber at2s. Could someone help me out?
  2. Apr 8, 2018 at 10:03 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Welcome from Ventura!
  3. Apr 9, 2018 at 6:50 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Welcome aboard. The short answer is yes. Depending upon wheel offset, there might be some fender trimming. I'm running 34/10.5 BFGs with a little over 2.5" dialed into mine. They only rub the frame at full lock. GL.
    TheBeast likes this.
  4. Apr 9, 2018 at 7:23 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Seems reasonable to assume if a 10.5” wide tire barely rubs the frame, then a 12.5” one is gonna rub pretty significantly. Haven’t seen hardly any 1st gens running 34’s on 3” of lift myself.
  5. Apr 9, 2018 at 10:32 AM
    Need to know stuff
    I may go 4 in the front and use lil spacers so they dont rub to bad
  6. Apr 10, 2018 at 10:13 PM
    SouthshoreYota
    SouthshoreYota New Member
    Jordan
    Ontario
    2001 Toyota Tundra X2
    3” supreme suspension leveling kit 2” supreme suspension wheel spacers Home fabbed bumper Complete frame swap Complete exhaust swap to 3” stainless
    I’ve run 32’s with and without wheel spacers, with a 2” wheel spacer they will only frame rub at full turn lock. Without the spacers they will rub everything! Now I just ordered and installed a 3” leveling kit which claims to clear at least 33 inch tires so I’ll let you know what kind of measurements I get
  7. Apr 10, 2018 at 10:17 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    A lot depends on your wheel offset. You can run 35s but you might go through a lot of trial and error making it work. I've seen 35s on LT 1st gens.
  8. Apr 10, 2018 at 10:20 PM
    SouthshoreYota
    Jordan
    Ontario
    Agree, went through a few spacers before I found the best “fit” (still rubs) the only issue you may run into is pushing your wheels out excessively far if you don’t have fender flares
  9. Apr 10, 2018 at 10:44 PM
    TheBeast The Beach
    anything can fit with the right tools :D
    BestGen and 831Tun like this.
  10. Apr 11, 2018 at 5:31 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    285/75/18 Toyo RT's on 18x9 Method Standards, no rub on frame. Didn't do the BMC.
  11. Apr 11, 2018 at 6:39 AM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    I’m betting that’s on a 3rd gen, not a first.
  12. Apr 11, 2018 at 6:49 AM
    Need to know stuff
    That would be nice if you let me know. Tuanks
  13. Apr 11, 2018 at 7:17 AM
    Tundradrenalin
    Virginia Beach, VA
    Oops yes it's a 3rd gen.
    I did have a 2005 on 285/70/17 leveled for 12 years. My truck had 2.75" coilovers and a 1" BL. I tried a 285/75/17 for a couple months and it rubbed the frame bad. You need to go over 4" in the front for that tire.
  14. Apr 11, 2018 at 7:34 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  15. Apr 11, 2018 at 9:32 AM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    I'm on 295-75-16 with a 2 inch leveling kit. That tire measures out to a 33.4x11.6-16. I had to run spidertrax 1.25 inch spacers to get them away from the upper control arm. I had to cut the front bumper up and the fenders to get them to clear. You will most likely need a 4 inch kit. Not saying it cant be done, but you're going to have A LOT of cutting to do. Plus, you need to check the rims for the right backspace. I'm at 4.26 inches of backpacking on my rims. You try that with a stock rim, it ain't gonna work. Raceline Rockcrusher rims are a decent wheel with I believe 3.71 inches of backspace on their 16x8 rim. They'll stick out, but should clear the upper A arm. Still may need a small spacer though.
  16. Apr 11, 2018 at 9:33 AM
    Need to know stuff
    The stock rims are ugly anyways.
  17. Apr 11, 2018 at 9:46 AM
    mudslinger79
    Christopher
    Williamsburg, Va
    Yes. Yes they are.
  18. Apr 11, 2018 at 9:47 AM
    mudslinger79
    Christopher
    Williamsburg, Va
    I have 16x8 Classic II's.
  19. Apr 11, 2018 at 8:49 PM
    Gtfour43
    Gtfour43 New Member
    Oahu
