33x12.5 or 35x12.5?
Discussion in 'Wheels & Tires' started by Tundra2010, Jan 17, 2015.
  1. Jan 17, 2015 at 1:15 PM
    Tundra2010
    Tundra2010 [OP] New Member
    2010 black tundra 4.7
    I have a 2010 tundra with a 3/1 level kit and I bought 18x9 ballistic jesters with +12mm. But which tire should I go with 33x12.5 or 35x12.5......any suggestion would be great guys let's hear them
  2. Jan 17, 2015 at 1:38 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    35s. You will have to rim some plastic and remove the front flaps but they fill the wheel wells nicely
  3. Jan 17, 2015 at 4:02 PM
    Tundra2010
    Are there any pics with that, setup that you know of??
  4. Jan 17, 2015 at 5:45 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    35s for sure. Here's the same set-up
    scratchex likes this.
  5. Jan 17, 2015 at 8:39 PM
    chphilo
    chphilo Tundra addict
    Western PA
    35 will look sweet, but with 12 mm offset, you may have to do the body mount mod. But then again, you may not. Each truck is somewhat different. I have 18 mm offset with 295/70/18 (11.73 wide according to Nitto's web site) and I am very very close to the body mount.
  6. Jan 18, 2015 at 6:29 AM
    Tundra2010
    What do you mean. By the body mount mods?
  7. Jan 18, 2015 at 6:47 AM
    chphilo
    Western PA
    For large tires with low wheel offset, the rubbing typically occurs at the body mount (located toward the outer body of the truck). So the mod effectively cuts a portion of the mount so the tires will clear. Personally, this goes beyond what I wanted nor have the ability to do, so I went with 18 mm offset. Every truck is somewhat different, but anything lower, there's a certain chance you may have to do this mod. I knew going in that with 18 mm offset, 295/70/18 or 305/65/18 is just about the largest tire size I could go without having to do this mod.
    Stock mount
    Cutting of the body mount
    Body mount hammered into a narrower shape, rewelded, and painted.
    Final tire clearance
    If you want the original thread, here is the link to the thread. http://www.tundratalk.net/forums/exterior-mods/83543-d-i-y-body-mount-mod-cut-weld.html
  8. Jan 18, 2015 at 7:13 AM
    Tundra2010
    Thanks I appreciate it
  9. Jan 24, 2015 at 6:31 AM
    csuviper
    Broomfield, CO
    I have roughly 34.5" tires with my 3/1 lift. Only chopped plastic so far. I like the looks. I purchased the metal caps for the cab mount chop but haven't needed to install yet. With true 35s I might need to
  10. Jan 24, 2015 at 6:36 AM
    Tundra2010
    My buddy bought a 4/2 lift and wants to go 35's do you think he'll have any problems?
  11. Jan 24, 2015 at 6:37 AM
    Tundra2010
    Hey viper what size tire and wheel do you have and do you have any pics of it I may see??
  12. Jan 24, 2015 at 9:14 PM
    csuviper
    Broomfield, CO
    No problem at all.
  13. Jan 24, 2015 at 9:17 PM
    csuviper
    Broomfield, CO
    315/70R17 Goodyear Wrangler Duratrac tires with 17x8 TRD Rock Warrior wheels. Check out my build for pics.
