33" tires with mud flaps - looking for advice
Discussion in 'Wheels & Tires' started by Weez, Oct 4, 2018.
  1. Oct 4, 2018 at 9:06 AM
    Weez
    Weez [OP] New Member
    2009 Tundra SR5 Double Cab 6-1/2 box
    Hello!!
    I am new to the forum, and appreciate the posts I’ve read so far.
    I did not see any posts on this, so though I’d throw it out there.
    2009 Tundra SR5 double cab with 3/2 level and stock Toyota 18” mags with 33” BFG A/T KO2 (275 70 R18). The OEM mud flaps are still installed.
    With stock mags (I believe 60mm offset) I’m way inside the fender, and there’s 0 rubbing.
    I want to keep my mud flaps and eventually get new mags with somewhere around +18mm to +20mm offset.
    My question is, will the +18mm to +20mm rub the mud flaps with 275 70 R18 tires?
    If yes, what is the most offset I can get and not have a rub on the mud flaps?
    Thanks!!
  2. Oct 4, 2018 at 9:09 AM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    No, they will not rub.
  3. Oct 4, 2018 at 9:11 AM
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    No they won't. As long as u keep that offset
  4. Oct 4, 2018 at 9:48 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I used to run that size tire with +25 offset, and they rubbed the front little mud flap when turning in reverse. They didn't rub the mud flap behind the tire, though.
  5. Oct 4, 2018 at 10:24 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome from NorCal
    joonbug likes this.
  6. Oct 4, 2018 at 10:38 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Welcome from eastern CO! I’d be very surprised if they rub.
  7. Oct 10, 2018 at 8:54 AM
    Weez
    Thanks for the welcome and replies!!
    Does anyone have truck pictures with aftermarket rims with an offset and 275 70 18 (preferably with the mudflaps)
  8. Oct 10, 2018 at 8:59 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  9. Oct 10, 2018 at 3:52 PM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    My truck has a 2” lift with 275/70/18 and +25mm offset and they rubbed the rear front mud flaps. Could be though that yours being 3” up front may not.
    Sorry these pictures don’t show much but they are the only ones I have with the mud flaps on. I can show you some without if that helps.
    Calvint and equin like this.
  10. Oct 10, 2018 at 4:58 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Leveled with 33" It looks like it is touching the front flap but really just missing it. It will rub very slightly in revers.20171228_092514.jpg 20171228_092530.jpg
    equin likes this.
  11. Oct 22, 2018 at 11:31 AM
    dsmith13
    dsmith13 New Member
    Derek
    2018 SR5
    Hi Equin, What did you do to get rid of the rubbing when in reverse? Thanks
  12. Oct 22, 2018 at 4:57 PM
    equin
    Ed
    DFW, TX
    The rubbing wasn’t that bad, so I lived with it. Over time, as the tread wore down bit by bit, the rubbing diminished but never really went away. I eventually removed the little front flaps altogether and that got rid of the rubbing completely.
  13. Oct 22, 2018 at 8:34 PM
    dsmith13
    dsmith13 New Member
    Derek
    2018 SR5
    I can hardly turn wheel in reverse without terrible rubbing. Reading all the threads I thought I was good with 5100s on middle ring and only 33s.
    I’m thinking CB bumper spacers or trying to push plastic into bumper away from tire.
  14. Oct 23, 2018 at 1:30 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    CB bumper spacers will work.
    OR
    you can re drill some holes in the plastic push it forward and bolt em back up. should give ya a little more clearance.
    dsmith13[QUOTED] and 15whtrd like this.
