33" tires on stock tundra, with leveling kit.
Discussion in '1st Gen Tundras (2000-2006)' started by Ray122, Jun 17, 2020.
  1. Jun 17, 2020 at 6:30 PM
    Ray122
    Ray122 [OP] New Member
    2005 toyota tundra
    Hey everybody, this is my first post. I just bought a 2005 toyota tundra 2wd with leveling kit. The tires need replacement and they look small for the truck anyway so I wanted to upgrade, I also drive alot of washboard and dirt roads, nothing crazy but I feel the larger tire will give a better ride.
    I'm running 265/65r17's right now which are about 30" and I want to come up to 32"-33". I've done quit a bit of research on the forum before posting and I found 275/70r17 to be probably the best but they're not a common size and as a result very expensive. Ive seen 285/70r17 for much cheaper even thought its a larger tire, is anyone running these? Any issues with rubbing, excess suspension wear, etc?
    Pictures speak a thousand words so show me what you have! Thanks
    JimboSlice413 and TundraTss like this.
  2. Jun 17, 2020 at 7:14 PM
    SalsaTheTundra
    SalsaTheTundra New Member
    jd
    Birmingham, Alabama
    2008 Salsa Tundra Double Cab SR5 5.7
    Ubar led headlights K&N filter +50HP
    Grab a set of pull offs from a 3rd gen. Mike are 275/70/18
  3. Jun 17, 2020 at 7:15 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    285/70/17 is a great choice for your set up. With those wheels you will need 1.25 or 1.5 hub centric wheel spacers. Lots of different choices of tires in that size and will make your truck look great. Taking off your mud flaps and some trimming may be necessary. I would consider something like these:
    https://simpletire.com/mastercraft-p285-70r17-90000037403-tires
    Darkness likes this.
  4. Jun 17, 2020 at 8:36 PM
    Ray122
    2005 toyota tundra
    Yea i figured I'd ditch the the mud flaps and do some trimming in the wheel wells. Im a little hesitant to put on spacers though because ive heard it causes alot of excess strain on the axle and suspension. Im not gonna be rock crawling or anything crazy(only 2wd sadly), but i want it to be a solid truck thats dependable off road. I noticed you have a 02 and 06, what are you running on your trucks?
  5. Jun 18, 2020 at 4:12 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Yeah, just drill an extra lug bolt hole in ‘em and you should be good to go.
    Where’s @bmf4069 when you need him?
  6. Jun 18, 2020 at 4:34 AM
    Professional Hand Model
    Hand Protectors
    :yes:
    TX-TRD1stGEN likes this.
  7. Jun 18, 2020 at 6:17 AM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    Sorry forgot the 1st gen were 6 lug
    MNtundra and Darkness like this.
  8. Jun 18, 2020 at 6:25 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @Ray122 it's a pretty classic formula for these trucks. Looks like you have a spacer kit installed already. 285/70/17 will be okay with minimal rubbing on the body, but not knowing the backspacing of those wheels it's hard to say if you will clear the upper arm.
  9. Jun 18, 2020 at 6:42 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Hey! No sir!
  10. Jun 18, 2020 at 11:54 AM
    Ray122
    2005 toyota tundra
    I have spring spacers up front to level out the truck, but as far as I know no hub centric wheel spacer like revtune was talking about
  11. Jun 18, 2020 at 12:31 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Right, I was referring to the spacers on top of your shocks. The hub centric wheel spacers might be needed to clear the upper arm with a 285 tire, it's kind of a crap shoot. A wheel with 4.5" of backspace or less will allow a 285 tire no problem.
  12. Jun 18, 2020 at 5:29 PM
    Ray122
    2005 toyota tundra
    Yes I do have spacers on top of my shocks, have contemplated replacing the setup with longer coil overs. And I'm not sure what the backspacing on the wheel is
  13. Jun 18, 2020 at 5:40 PM
    Ray122
    2005 toyota tundra
    update, found a set of 275/70r17 radial advanturo at3 for $620, $700 including install. Seems like a good on road/off road tire. Especially with the price. I think I'm gonna pull the trigger and buy them. I plan on probably removing stock mud flaps. I'll post after picks and detail the fit and quality of the tires.
    Also heres a updated picture including the new tool box. 20200618_170036.jpg 20200530_160721.jpg 20200530_160753.jpg
  14. Jun 19, 2020 at 11:40 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    I’m running 285/70/17 at3w (2002) these tire are just ok. I like the look, but I wouldn’t get them again. They are p rated. Running nitto terra g2 285/70/17 on the 06. I like these tires and they are really “only” around a 32 inch tire because they aren’t E load. The nittos ride nice. If you’ve decided on the 275’s that’s great.
  15. Jun 19, 2020 at 1:49 PM
    Ray122
    2005 toyota tundra
    I was looking at the g2's also but they only had them for 18" wheels and I want to keep the wheels it has. And thats interesting, the atw3 im looking at are Lt rated. And the 275's are just Slightly narrower then the 285's. Did you have to trim at all to fit the tires?
  16. Jun 19, 2020 at 3:21 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    minor trimming on the 06. Front height, I’m at 22.5 from center of hub to bottom of fender flare and took the mud flaps off too. Can you get a measurement of the front of your truck? Also, I just took this screenshot from Walmart.com.
  17. Jun 19, 2020 at 3:24 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Here’s another 285 you might want to consider. Great price too.
  18. Jun 19, 2020 at 3:31 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    I don’t know anything about the GT radial tires you mention, they may be good. Me personally, I would just do the 285’s and adjust as needed. Those are Tacoma sport wheels you’re running. I would keep those too. Run some 1.5 wheel spacers if your too close to the UCA. You most likely will be. I run 1.5 wheel spacers on my 2006 with 4 runner wheels.
    MS22 and Professional Hand Model like this.
  19. Jun 19, 2020 at 3:45 PM
    Blueranger501
    Blueranger501 New Member
    I hated my Yoko Geolanders in the snow, AWFUL. Rear ended one person, spun out in the middle of the road. Dont run if you are going to see that type of climate.
  20. Jun 19, 2020 at 3:51 PM
    Hand Protectors
    Cheap tires they are not.
    Michelin Defenders LTX. Been on these for 15 years. Long life. Great in rain, snow, and sand. Quiet.
    They look nice, too.
    revtune likes this.
  21. Jun 19, 2020 at 3:57 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Here’s another 285 I would consider. Sumitomo makes falken tires and the tread pattern on these Looks to be more street friendly then the at3w. That’s my biggest gripe with the at3w is the tread pattern is bordering on mud tread. You feel the added resistance and that’s just with the non E load tire.
  22. Jun 19, 2020 at 4:04 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Probably the best as far as tires go. I was suggesting some middle of the road (price) choices based on the OP saying he’s looking at the GT radials. Me personally, I probably wouldn’t go with anything less then federal tires. They make a new one called “xplora” that looks interesting. Rule of thumb, stay away from a 285 tire that’s less then $150 per tire:oops:
  23. Jun 19, 2020 at 4:13 PM
    Hand Protectors
    The original tires on the 2002 lasted 19k miles before becoming dangerous. I bought 2 sets of mud/off road tires in two proceeding years which both sets sucked (Dunlop and BFG). They were super loud and wore out in a weird way. In general, they were poop.
    These Michelins never wear out. I change them at the 5 year mark due to the 5 year rule. Highly recco!
    revtune likes this.
  24. Jun 19, 2020 at 6:32 PM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    Which Geolander model did you have? They make several kinds, some models suck and some don't. The G015 above is an excellent all-terrain tire if you get any snow. Kinda like "Goodyear Wranglers" - that is not enough information. There are probably 10 specific models and tread patterns with the generic Wrangler "family" name. So when some says "Goodyear Wranglers suck" that is not enough information either...
  25. Jun 20, 2020 at 8:31 PM
    Ray122
    2005 toyota tundra
    I went to the tire shop and it turns out that there's no gt radial tires not only in any where house in the Sacramento area but none in the US. I guess because they're Chinese tires and something with the coronavirus they haven't had a shipment in a while. But I got a good deal on some general grabber at tires, I like the look and tread pattern a little more. Im gonna have them installed either Wednesday or Saturday. Will post pictures
  26. Jun 20, 2020 at 8:35 PM
    Ray122
    2005 toyota tundra
    I like the look of your truck, i went with the 275’s because I want to avoid the use of wheel spacers. They're almost identical to what your running just a little narrower. And thanks i was wondering what wheels they were. Didn't think they were stock, any clue what year tacoma they come from?
  27. Jun 20, 2020 at 9:03 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Pretty sure they’re from the 2016-2020 TRD sport model. They should look really good with those general tires.
  28. Jun 20, 2020 at 9:04 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Great choice, those tires look awesome.
  29. Jun 21, 2020 at 10:26 PM
    Ray122
    2005 toyota tundra
    Yea I'm actually really glad they were out of the radial, I had my eye on the general grabbers and it justified me spending the extra money on them to my wife haha. I'm gonna take my mud flaps off tomorrow, any other plastic crap or trimming anyone think i should do?
  30. Jun 24, 2020 at 1:48 PM
    Ray122
    2005 toyota tundra
    Update, 275/70r17s did not fit! Just got back from the tire shop and the 275s wouldn't even mount, hitting the upper control arm in a major way. Also tried downsizing to 265/75/17 and was still rubbing. So after wasting almost 2hrs at the shop and no doubt pissing off every employee there i left with my old tires and have come to the conclusion that the wheels i have have alot less backset then the stock wheel because even the 265/65's were 1/4" from rubbing. So even though I didn't want to have to use spacers its gonna have to be a necessity to keep these wheels. Im split between 1 1/2" and 2" spacers. My wheels are way tucked in under the truck so I think i can get away with 2" and not look stupid with my wheels sticking way out there. Any thoughts?20200624_132109.jpg 20200624_132013.jpg 20200624_132036.jpg
