32 gallon tank swap COMPLETED!
Discussion in '3rd Gen Tundras (2022+)' started by cccasti3, Mar 30, 2024.
  1. Jun 7, 2024 at 11:48 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Well thx. I stand corrected. Every TRD/OR I looked at had the 32GA. I’ll dig out my window sticker tomorrow. I remember some stickers called it out as an option and some didn’t even list it even though it had the 32.
  2. Jun 8, 2024 at 12:34 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    rwsessions and Tundrastruck91 like this.
  3. Jun 12, 2024 at 8:11 PM
    paravane
    paravane New Member
    c
    Tank acquired. Had to remove the passenger seat to get it in the RAV4 and the gasoline smell wasn't noticed until I got out and got back in but it was very mild and didn't "stain" the car. Once I removed it and put it in the garage it aired out just fine.
    Won't be installing it for a few days I ordered what I believe is the strap you need to complete it. I'm currently waiting on 3 things.
    1. I have an open warranty for my door seals and I'm275 miles from my warranty being up.
    2. The strap. Figured I'd complete the install and do it all at once. 776020C170 here's what I believe is the strap assembly. I have no idea if it comes with the bolt and pin I need yet.
    3. To be low on gas. Don't want to try dropping it while it's half full.
    Will make a new post with a "guide" or what will more realistically be "My struggles."
    Also I talked to my dealer about getting the ECU to read the new tank correctly. They didn't say no. They said they don't know. No ones asked them this before. So they didn't sound optimistic but not outright denying it. Will update on that too.
  4. Jun 14, 2024 at 11:43 AM
    chunkytundra
    chunkytundra New Member
    SOCAL
    KING 2.5 Coil Over Resi W/ Adjuster KING 2.5 Rear Shock Resi W/ Adjuster KING Rear Sway Bar Billet Link Kit KING 2.0 Rear Bump Stop Kit MAZZULLA Billet UCA MAZZULLA Billet Trailing Arms DR.KDSS Track Bar Correction Kit PERRY PARTS Front Bump Stops BAJA DESIGN 9 XL Linkable Roof Bar Kit BAJA DESIGNS XL Sport A-Pillar BAJA DESIGNS S8 20" Behind Bumper Light Bar BAJA DESIGNS S2 Dual Fog Light Kit BAJA DESIGNS S8 20" For TRD Heritage Grill BAJA DESIGNS S2 x2 Chase Lights BAJA DESIGNS S2 x2 Flush Mount Revers Lights BAJA DESIGNS Rock Light Kit SPOD HD BantamX SDHQ Built A-Pillar Light Mounts ALPHAREX Nova Headlights RRW 17x8.5 ET 0 TOYO TIRES RT Trails 37x12.5R17 Extended Brake Lines INNOV8 Racing Billet Bed Support Kit PERAGON Tonneau Cover Limited HDx CHARVONIA DESIGN Billet D-Rings ALPINE Off-Road Y Strap TRD Heritage Grill TRD Pro Marker Lights TRD Camo Fenders TRD Skid Plate W/ Black Lettering Gold Hook "TRD 4x4 Sport" Replacement Bedside Decals in Black/Gray/Silver Colorway SEIBON CARBON RR-Style Carbon Fiber Hood Painted/Matte Clear Carbon Fiber
    I know you need to order 1 strap and bolts, but other than that I wonder if you order Part Number: 770010C160, will it be coming with everything else you need?
  5. Jun 14, 2024 at 8:01 PM
    paravane
    paravane New Member
    c
    When it comes in I'll let you know.
    chunkytundra[QUOTED] likes this.
  6. Jun 20, 2024 at 1:37 PM
    paravane
    paravane New Member
    c
    So it does not come with the bolt or the pin needed. But I'm going to put a jack under it and pull one of the bolts from the other straps and go by my parts store to find one that matches. Then for the pic I think I'll just get a nut and bolt that will fit in the socket as I don't want to wait a year and a half for a dealer to send me the bolt/pin.
  7. Jun 21, 2024 at 8:35 AM
    chunkytundra
    SOCAL
    Sweet!! Thank you.
    I am going to pull the trigger soon. If the system the does not read right, I am okay with that, I guess.
  8. Jun 25, 2024 at 6:49 PM
    paravane
    paravane New Member
    c
  9. Apr 28, 2025 at 3:38 PM
    CathDAT
    CathDAT New Member
    Republic of Texas
    2023 SR5 Tundra
    SR5 Slick with TSS Package.
    When I bought my 2023 SR5 4wd, I looked into the possibility of upgrading. It did surprise me that you can't order it as a complete kit under one stock number. All the parts have to be ordered separately.
    I do remember the service tech telling me that they have to do something to the onboard computer to "tell it" that it now has a 32 gallon tank. That may have been the issue with the distance to empty reading being a bit wonky.
    Still on my "to do" list along with skid plates for my truck...
