315/70/17 on Rock Warrior Wheels
Discussion in 'Wheels & Tires' started by mechmatt138, Apr 24, 2020.
  1. Apr 24, 2020 at 11:18 AM
    mechmatt138
    mechmatt138 [OP] New Member
    William
    Fort Worth, TX
    2016 Super White CM SC’d
    Magnuson Supercharger, Bullydog Tune, Borla Exhaust.
    I’ve searched and searched and still can’t get a for sure answer.
    I have a freshly powder coated set of RW’s I want to put on my 2016 Tundra. At first I wanted 285/75/17’s but they seem to be hard to find. A local tire shop has some 315/70/17’s and I’m curious if they will rub with a 3” level? I’ve been told they rub on the UCA’s and I’ve been told they don’t.
    Any help would be great! Pictures too!
    :thumbsup:
  2. Apr 24, 2020 at 12:18 PM
    TemujinNomad
    TemujinNomad New Member
    If they are KO2s, they will not rub.
  3. Apr 28, 2020 at 3:20 PM
    mechmatt138
    William
    Fort Worth, TX
    @TemujinNomad The shop I’m buying at said they do have 317/70/17’s in BFG KO. No KO2’s. I’m debating between those or 35” Nitto Grappler A/T
  4. Apr 28, 2020 at 3:33 PM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    Wheel offset is your enemy here. Worst case scenario is that you will need some 1.25” wheel spacers. If the place is local, I would drive over and have them mock it up and see if it rubs.. if you have aftermarket UCAs it’s going to be a case by case issue. I am guessing you will rub or be extremely/scary close. I know it would cause issues with the stock TRD wheels at about 12” wide and those are +60 offset, while it looks like the RW are +50 offset, which is about 0.4” difference and the tire you want is about 12.4” wide... literally dancing on the line.. I think just go check and see :notsure:
    EDDO likes this.
  5. Apr 28, 2020 at 3:47 PM
    TemujinNomad
    You will not rub on the UCAs. You may have to push the front liner in and do a bmc. 315kos are 12.7 wide.
  6. Apr 28, 2020 at 4:04 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I can say with a lot of confidence,
    1.25" wheel spacers may help clear the UCA with will more than likely cause cab mount rub.
    I had 285/75 RW with 1.25 spacers,
    Jumped to 35s and rubbed my cab mount like crazy. Took em off, beautiful clearance.
    EDDO and SC_TRD[QUOTED] like this.
  7. Apr 28, 2020 at 4:17 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    This is a 285/75R17 AT3W on a rock warrior wheel without spacer. Right around 25mm clearance. Based on that, a 315 would have 10mm clearance in that area. You will most definitely rub on the splash guard at full lock, but that is an easy fix with a pair of pliers.
    14burrito and SC_TRD like this.
  8. Apr 28, 2020 at 4:27 PM
    SC_TRD
    Colin
    Round Rock, Tx
    this seems pretty definitive if OP has stock UCAs. I know I was forced into the spacer realm with my SPC UCAs, while their adjustability is awesome, it causes them to stick out a bit extra for that camber adjustment.
    EDDO[QUOTED] likes this.
  9. Apr 28, 2020 at 4:32 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Fair point. I assumed OP had stock uppers and in my 'ronaboredom went out and took a pic.
    SC_TRD[QUOTED] likes this.
  10. Apr 29, 2020 at 3:01 AM
    mechmatt138
    William
    Fort Worth, TX
    Yeah I’m on stock UCAs. I’m still debating. I have cash down on any set I want. $200 for a used set of 4. Most if not all sets are $200. No worries, it’s a reputable Tire Shop down here in Texas. I guess I just want more side wall and a little poke. I’m hoping 315/70/17’s on some spacers will clear and poke a little. Thanks guys for the info!
  11. Jul 12, 2020 at 5:41 PM
    Milam08-WV
    Milam08-WV New Member
    Anthony
    2015 White Crew
    What happened with this? Did you get the 315s, if so were the spacers necessary?
  12. Jul 13, 2020 at 4:53 AM
    mechmatt138
    William
    Fort Worth, TX
    Sorry I totally forgot to update! No spacers needed, just had to remove front small mud flaps and trim the outboard edges of the skid plate. No rub at full lock:thumbsup:
    n0rth, Skew12, equin and 4 others like this.
  13. Jul 13, 2020 at 5:20 AM
    Blueknights75
    Ron
    Clayton, NC
    How close to the UCA are you?
  14. Jul 13, 2020 at 6:24 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Glad you decided against spacers because I know for a fact 1.25" will rub - that's why I took mine off ha
  15. Jul 13, 2020 at 6:45 AM
    14burrito
    2014 SR5 CM 4x4 5.7
  16. Jul 13, 2020 at 7:41 AM
    mechmatt138
    William
    Fort Worth, TX
    It’s hard to get my big ass head in there to measure but roughly 3/4 of an inch to 1” between UCA to side wall.
    EDDO, SC_TRD and 14burrito like this.
  17. Jul 13, 2020 at 9:29 AM
    SC_TRD
    Colin
    Round Rock, Tx
    this came out great, looks really good! Nice color scheme as well. :thumbsup:
  18. Jul 13, 2020 at 9:36 AM
    mechmatt138
    William
    Fort Worth, TX
    I appreciate it! A work in progress but coming along :thumbsup:
  19. Jul 23, 2020 at 1:07 PM
    geoffreythomas
    geoffreythomas New Member
    @mechmatt138 where did you get those black TRD center caps? Looking to do the same thing with my RW wheels and would to find some of those. Thanks man, wheels look sick!
  20. Jul 23, 2020 at 7:14 PM
    mechmatt138
    William
    Fort Worth, TX
    I vinyl wrapped those matte black and hit up TVD Vinyl for the white lettering. Super easy, only took about 30 minutes for all four caps including the painful lettering. I appreciate that!
  21. May 20, 2021 at 6:07 PM
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    I'm on Method Roosts right now, +25 offset. With 295/60/20 Wild Peak AT3s, they stick out enough to fling rocks all over the place ... I had flares but took them off since I'd rather have the splash protection from the flaps, which flares don't provide. I'm looking at picking up Rock Warrior wheels to pull things back in, and going with a 285/75/17 tire, but seeing this post has me concerned, since I'm running 6112s at the top setting along with SPC UCAs.
    What tire size forced you into spacers with RW wheels in combo with SPC UCAs?
