305/70/18
Discussion in 'Wheels & Tires' started by Theyfzman, Jul 3, 2020.
  1. Jul 3, 2020 at 3:56 PM
    Theyfzman
    Theyfzman [OP] New Member
    Pa
    08 TRD
    Just curious if anyone has run this size on there 2nd gen with a 3-1 lift
  2. Jul 3, 2020 at 4:03 PM
    That's a pretty wide tire. Some of us rub with 285 and 295's. What offset?
  3. Jul 3, 2020 at 4:05 PM
    Theyfzman
    Pa
    08 TRD
    I’ve got UCA’s and have an easy 2 inches clearance there. Running 295’s now and no rubbing. The 305 is only like an inch taller and inch wider. Think I should be safe........ at least I hope so
  4. Jul 3, 2020 at 4:10 PM
    I would have someone turn your wheels to one side so you can see how close it is to the front liners as well at the body mount. I'm betting you will be extremely close.
    Pinay and Blueknights75 like this.
  5. Jul 4, 2020 at 6:40 PM
    Theyfzman
    Pa
    08 TRD
    I did the bmc and trimmed the liners so I thinking I should be ok
  6. Oct 13, 2020 at 9:46 PM
    13CrewMax
    13CrewMax Oops
    Southern Oregon
    2013 CrewMax
    Not enough.
    Did you end up getting the 305s? If so, how did it work out?
    I just ordered SPC ucas, method nv 305 18s +25, and 305/70 pro comps for my second gen. It came with a revtek spacer lift, I believe 2.5/1.25. I think with minor mods it'll all come together, but I'm not totally sure. Do you have any pictures?
