305/55/R20 Fuel Vapors +1 offset with 3/1 nitro kit
Discussion in 'Wheels & Tires' started by Skatebc1, Sep 19, 2016.
  1. Sep 19, 2016 at 5:24 PM
    Skatebc1
    Skatebc1 [OP] New Member
    CHRIS
    Bronze Tundra Lmtd 2014
    3/1 Nitro Kit (pro comp)
    Recently ordered a set of 305 55 R20 with some Fuel vapors +1 offset. Will this set up work with a Nitro 3/1 level lift? Worried about the rub..
  2. Sep 19, 2016 at 5:31 PM
    chphilo
    chphilo Tundra addict
    Western PA
    If your truck is anything like mine, you will need to chop the body mounts. My wheels are 18 mm offset wheels and my tires are a few mm away form the body mounts.
  3. Sep 19, 2016 at 5:46 PM
    Skatebc1
    CHRIS
    I figured there would be rubbing. Damn.. Didn't want to mess with the frame. Would another offset work?
  4. Sep 19, 2016 at 6:09 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I just moved to a +25 offset wheel, running 285/65r18 with a 3/1 coilover lift - I had rubbing when in reverse even after removing the front and rear mudflaps in the front wheel wells. With the new wheels that is no longer a problem.
    Your wheels are only about .5" bigger than mine, so I imagine if you can get your offset somewhere between +30 and +12 you'll be in good shape.
  5. Sep 19, 2016 at 6:19 PM
    Skatebc1
    CHRIS
    I'll look into another offset. Thanks for your input.
  6. Sep 19, 2016 at 6:21 PM
    Backslider
    Tooele, UT
    I should also mention my previous offset was effectively about +9.2
  7. Sep 19, 2016 at 6:24 PM
    Skatebc1
    CHRIS
    Buddy of mine got the same lift/same tires and his offset was +18 still had some rubbing
  8. Sep 19, 2016 at 8:36 PM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    I have a 3/1 lift on 305/55/20 nitto trail graplers, 20x9 +18 offset. HAD no rubbing, got it alighed and they zeroed out my caster and now I rub at full lock in reverse, just a tiny bit. Next alignment I'm going to have them back up the caster .5 degrees to where it was and it'll never touch. Or I might just heat and move my plastics a half inch. Either one would fix it.
    Skatebc1[OP] likes this.
  9. Sep 19, 2016 at 11:08 PM
    chphilo
    Western PA
    For 2nd gen Tundras, it's easy to unscrew the two bottom screws and make two push the plastic liner as tight as it goes then rescrew. It's an easy mod. I understand that with 3rd gen, it's not as easy.
    If you are not planning to get fender flares, get around 35 mm. The side of your truck will thank you.
  10. Sep 20, 2016 at 1:22 PM
    TNTundra08
    Blake
    2008 DC 4x4
    Would you then cut off the excess of the lower underside part of the bumper. It's been so long since I've been under there I don't remember what it looks like
  11. Sep 20, 2016 at 2:04 PM
    chphilo
    Western PA
    When you unscrew the two bottom screws, the plastic liner can be pushed further into the bumper. For most rubbing, that should be sufficient.
  12. Sep 25, 2016 at 5:34 AM
    Skatebc1
    CHRIS
    Hey guys. Just had my 305 55 R20 Cooper ST maxx fit on my tundra and there is some rub on the body mount.
  13. Sep 25, 2016 at 6:47 AM
    Skatebc1
    CHRIS
    Would this be safe to trim without taking away strength?
  14. Sep 25, 2016 at 6:56 AM
    Skatebc1
    CHRIS
    Also would changing the offset prevent rubbing?
  15. Sep 25, 2016 at 7:51 AM
    Just get the cab mount chop done to fix that issue.
    And depending what your current offset is, yes that's a possibility.
    +18 is a solid number.
  16. Sep 25, 2016 at 11:33 AM
    Skatebc1
    CHRIS
    Just got done chopping the mount. Hopefully that does the trick. Gunna have a cap welded on it also. Thanks for the reply.
    T-Rex266 likes this.
