305/50/20 rub on '14 didn't on '07
Discussion in 'Wheels & Tires' started by Pooch1043, Aug 3, 2014.
  1. Aug 3, 2014 at 7:14 AM
    Pooch1043
    Pooch1043 [OP] New Member
    For my new '14 tundra I got the same set up I had with my 07. Was shocked when I drove away and I was rubbing when I turned. I removed front mud flap and did some minor cutting and it doesnt rub when going forward. It still rubs on back mud flap when doing full turn in reverse.
    Any good way to make room with the back mud flap?
  2. Aug 3, 2014 at 10:02 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Remove mud flap and do some more cutting.
    T-Rex266 likes this.
  3. Aug 4, 2014 at 6:11 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Is it lifted?
  4. Aug 5, 2014 at 7:55 AM
    Pooch1043
    Just a 2.5 front lift. As for removing or cutting front-rear flap, it doesn't look good. The front flap doesn't real cover much, removing the back one exposes a lot of frame (doesn't look clean).
    Only solution is to look for a flap that doesn't stick out as much.
  5. Aug 5, 2014 at 1:39 PM
    csuviper
    Broomfield, CO
    I removed mine and it looks just fine to me.
  6. Aug 5, 2014 at 1:42 PM
    TruckyTruck
    Gary
    how is the alignment? sometimes when a truck has a lift it throws off the alignment and can cause rubbing. just a thought
