3" leveling kit, will 35x12.50R20 fit?
Discussion in 'Wheels & Tires' started by 2015Crewmax, Aug 21, 2018.
  1. Aug 21, 2018 at 7:40 AM
    2015Crewmax
    2015Crewmax [OP] New Member
    Cory
    Centennial, CO
    15 Crewmax
    BOSS 4x4 3" Lift kit, TRD Swaybars, TRD dual exhaust,
    I am looking at a set of 35's for my truck. I know id have to trim plastic, and possibly get spacers. but would they fit?
  2. Aug 21, 2018 at 7:54 AM
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
  3. Aug 21, 2018 at 8:03 AM
    2015Crewmax
    Cory
    Centennial, CO
    15 Crewmax
  4. Aug 21, 2018 at 8:04 AM
    2015Crewmax
    Cory
    Centennial, CO
    15 Crewmax
    I am also not at stock height
  5. Aug 21, 2018 at 8:27 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    They are 35s just different numbering.....
  6. Aug 21, 2018 at 8:34 AM
    2015Crewmax
    Cory
    Centennial, CO
    15 Crewmax
    they are 34x12R20 that is the same as 35?
  7. Aug 21, 2018 at 8:39 AM
    2015Crewmax
    Cory
    Centennial, CO
    15 Crewmax
    I new to this lifted truck stuff. any insight is appreciated.
  8. Aug 21, 2018 at 8:40 AM
    Heeler13
    Heeler13 21MGM
    Eastern NC
    2021 Sr5 XP
    Bilstein 5100 Front @ middle setting Bilstein 5100 Rear @ stock height Oem older Pro wheels 285/75/18 Maxxis Razr a/t
    35x12.50x20 should fit. Have to remove mudflaps, trim or bend or remove fender liner (lower front section). Being that u will have factory wheels which i think is +60 offset, i doubt u would have to do cmc. Make sure that u have room in between the tire and the uca tho. I have 35x12.50 on a 3/1 kit, but i have wheels with a +30 offset
  9. Aug 21, 2018 at 8:44 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    i'd think you'd hit the control arm at this size on stock wheels, i may be completely wrong though
  10. Aug 21, 2018 at 8:52 AM
    2015Crewmax
    Cory
    Centennial, CO
    15 Crewmax
    I was going to get spacers. 1" or 2"?
  11. Aug 21, 2018 at 8:55 AM
    Heeler13
    Heeler13 21MGM
    Eastern NC
    2021 Sr5 XP
    I was thinking that too. OP u might have to get spacers. I used Spidertrax spacers along time ago. I think they were 1.25"
  12. Aug 21, 2018 at 8:57 AM
    I had a '13 CM briefly that was on a 3/1 kit, I was new to lift scene, 35s will fit but may rub splash/skid plate at full turn lock, that may need some minor trimming
    2015Crewmax[OP] likes this.
  13. Aug 21, 2018 at 9:21 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    1" smaller than a 35....
  14. Aug 21, 2018 at 10:46 AM
    2015Crewmax
    Cory
    Centennial, CO
    15 Crewmax
    Thanks Captain Obvious. HAHAHAHA
    4x4_Angel[QUOTED] likes this.
  15. Aug 21, 2018 at 10:52 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    Sorry I'm running on little sleep as i work nights and the first day of school has thrown me off..... I'm a walking zombie
  16. Aug 21, 2018 at 10:55 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    I'm running 35s on a 3/1...minor trimming but I'm running 295/70/18.... and i have aftermarket wheels
  17. Sep 6, 2018 at 10:37 AM
    TuFerLife
    TuFerLife New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    4BE5DE5C-875F-495F-94D0-AB9D1C9AB59A_zps_916fc6b976b4667d2fdf4303a2a7f47e1a2493f2.jpg
    I just installed 35’s last night with a toytec eibach kit. Cleared the cab mount, but have to do some front liner maneuvering. I’m going to try to bend first before I start cutting.
    4x4_Angel likes this.
  18. Sep 6, 2018 at 10:50 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You will likely hit your UCAs with stock wheels and will need spacers. I'm pretty sure you will need atleast 1.25" or 1.5" spacers as the wheel bolts are longer than 1". But I wouldn't get 2" spacers, that'll just make the rubbing worse. You'll also likely need a CMC and some trimming along with removing your mudflaps.
