3 inch vs 2.5 inch lift up front
Discussion in 'Suspension' started by TexMedic, Oct 1, 2022.
  1. Oct 5, 2022 at 5:59 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Are you sticking with stock rims? If you get some with less offset (like +25 vs +60) that will be 7x the 5mm you'll get with 295 vs 285. The more the tires stick out though, the more clearance issues you have fore and aft, but +25 is decent. +30 or +35 would be better but they are rare. I don't know about spacers, but if you get quality ones and install them properly, they are probably fine.
    I get >16 mpg around town (small town) and >17 on the freeway, avg. Tires vary a lot in rolling resistance. Which ones do you have?
  2. Oct 5, 2022 at 6:41 PM
    TexMedic
    TexMedic [OP] I ask a lot of questions…
    2017 Dark Gray DC Tundra 4x4
    I would like to stick with my stock TSS offroad rims (2017 year). I’m hoping that SPC uppers would give more UCA clearance compared to my stock UCAs. From the looks of it, I’m not sure I could go taller with my 285 because of my stock UCAs. That really makes me question 295.
  3. Oct 5, 2022 at 6:54 PM
    rruff
    rruff New Member
    Do your own research, but I'm pretty sure that everyone who has used 295s with stock UCAs and rims has had no issues.
  4. Oct 5, 2022 at 7:24 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    295/65/20 is a badass tire size
  5. Oct 6, 2022 at 5:45 AM
    TexMedic
    Yeah man, I think it’s a really good combo without the drawbacks of a 12.5 wide. Just gotta decide if I wanna go that big… we’ll see.
  6. Oct 6, 2022 at 9:57 AM
    rruff
    rruff New Member
    If making your tires even with your fender flares is what you want, then you are going to need spacers or new rims. You won't get it with tire width. Period.
    You never said what your use case or goals were otherwise... ? If I wasn't offroad so much, had fender flares, wanted to keep stock rims, and wanted my truck to look good and perform well on the street... I'd lower the rear 2" instead of raising the front (airbags too if you carry loads), 1.5" wheel spacers, and run Michelin LTX in 295/60r20 (33.9"):
    But... I'd get new rims since I'm going to be spending so much on tires anyway. 22x10" with 305/45r22 (32.8"); same tires as above.
  7. Oct 6, 2022 at 2:32 PM
    TexMedic
    My overall goal is to make it look a bit more aggressive, while maintaining its reliability/durability. I think 3.5 up front would look great, but I don’t wanna take a shit on my CVs. So as of now I’m leaning towards 2.5 to make it level. I could just throw some strut spacers up front, but I wanna maintain and improve its ability, hence the coilovers. 90% of the time I’m going to be in the street, but I want to be able to do some off-roading if I need too. I want to be able to do more than driving up a dirt path with some pebbles on it, but I’m not gonna be scaling a 89 degree wall. I think that hopefully conveys my thought process.
  8. Oct 6, 2022 at 3:33 PM
    rruff
    rruff New Member
    Best look, reliability, and street performance... would be lowering the rear ~2", bigger wide tires with street tread, upgrade shocks. You can still go offroad, no problem. Ground clearance will be better than stock if you have bigger tires. AT E load tires that everybody buys are not so good on the road, as they are stiff, heavy, noisy, worse for mpg, lacking in traction, expensive.
    I wouldn't buy these wheels and I'd want more meat on the tire, but this gives you an idea of what a rear level looks like.
  9. Oct 6, 2022 at 3:37 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    How does one lower a tundra rear just 2 inches?
  10. Oct 6, 2022 at 4:17 PM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    I actually know the answer to this. One day, I incrementally loaded up the bed and measured the sag. 1,180lbs is what it took to lower it 2” over the rear axle :D
    Or, if you want to do it with suspension, I believe a former member who got the ban hammer—Rex Kramer I think was his handle—had a RCSB that he lowered the rear 2” on. I’m pretty sure he detailed the process somewhere on here.
    Hbjeff[QUOTED] likes this.
  11. Oct 6, 2022 at 5:14 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The axle flip drops 3.5 inches
    BlackSheep likes this.
  12. Oct 6, 2022 at 7:24 PM
    TexMedic
    How does one managed to get banned? I think I’m pretty well mannered, so I think I’m safe- just wondering.
  13. Oct 6, 2022 at 7:40 PM
    BlackSheep
    Scott
    Kansas City, MO
    That does make sense, given the diameter of the axle. I do recall him saying he did nothing to the front suspension though, and his truck sat perfectly level. I remember, cuz I drooled over that RCSB haha. So I don’t know what he did to do that.
    stay clear of anything remotely political, and you will probably be ok. There’s a thread somewhere on here that the mods update with temp and permanent bans, with the reasons for them explained.
  14. Oct 6, 2022 at 8:40 PM
    rruff
    rruff New Member
    I've seen that as well, SUA and nothing to the front. That's what the guy did in the photo I posted above. https://www.tundratalk.net/threads/lowered-tundra-owners-group.101609/page-62
    https://sosperformance.com/products...-front-slash-3-dot-5-rear-fits-2007-16-tundra
    If that results in too much drop, a lift shackle should easily get it where you want.
    BlackSheep[QUOTED] and Hbjeff like this.
  15. Oct 7, 2022 at 9:14 PM
    rruff
    rruff New Member
    Look what I found: https://www.tundras.com/threads/2007-rcsb-rescue.17240/
    Tires a couple inches taller and wider would look perfect...
