3 inch leveling kit tire size on 18inch TRD wheels
Discussion in 'Wheels & Tires' started by jacob.jons.jj, Jan 5, 2018.
  1. Jan 5, 2018 at 2:16 PM
    jacob.jons.jj
    jacob.jons.jj [OP] New Member
    Jacob
    2014 toyota tundra SR5 5.7 trd4x4
    leveling kit
    im putting a 3 inch leveling kit on my tundra and want to know what size tires people are running on stock 18" TRD wheels? i want the biggest i can get but dont want to do a lot of cutting and stupid stuff. if you have pictures that would be awesome!!!
  2. Jan 5, 2018 at 3:37 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    If you want to go bigger than a 275/70 or 285/65 you’ll need spacers with those wheels.
  3. Jan 5, 2018 at 3:45 PM
    jacob.jons.jj
    Jacob
    leveling kit
    why is that? because it rubs the upper control arm?
  4. Jan 5, 2018 at 4:39 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Yeah, the sweet spot for offset on a 3” lift is generally +18 to +30. Though I’m running wheels with a +12 on 295/70’s and a 3/1.5 lift and only rubbed on the front liner.
    Black Wolf likes this.
  5. Jan 5, 2018 at 4:45 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    275/70 has no rub on 18" TRD wheel on 2018. This is the largest I was advised would work without modification
    jacob.jons.jj[OP] likes this.
  6. Jan 5, 2018 at 5:48 PM
    jacob.jons.jj
    Jacob
    leveling kit
    do you have a picture of your truck running them?
  7. Jan 5, 2018 at 5:50 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
  8. Jan 5, 2018 at 5:52 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Truck is at the dealer getting a sensor issue fixed, that' the 1 and only photo I have it.
  9. Jan 5, 2018 at 5:54 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Check out @Law323’s build in the 2nd gen section. He’s running that size with a 3” front lift as well.
  10. Jan 5, 2018 at 5:59 PM
    jacob.jons.jj
    Jacob
    leveling kit
    dude that is a bad ass color on that truck!!! looks great i already have a 2 inch leveling kit im not sure its worth putting my 3 inch leveling kit on because im running 275/70 now...
    Larmand[QUOTED] likes this.
  11. Jan 5, 2018 at 6:02 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Thanks, one of the few colors that look good with chrome.
    Yeah that's a tough call. Good luck in your decision making.
  12. Jan 5, 2018 at 6:09 PM
    jacob.jons.jj
    Jacob
    leveling kit
    Thanks man i really appreciate it.
  13. Jan 5, 2018 at 6:10 PM
    jacob.jons.jj
    Jacob
    leveling kit
    if i wanted to run something bigger what size spacers would i need and what size tires could i run then?
  14. Jan 5, 2018 at 6:34 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    A 295/70 or a 35 is the biggest you could go, and you’d need 1.25” spacers. BORA is a commonly used spacer that size.
    Steve6 likes this.
  15. Jan 5, 2018 at 6:39 PM
    jacob.jons.jj
    Jacob
    leveling kit
    AWESOME!!!! thanks man. with a 35 how bad would it scrub with the spacer? and where could i buy the spacers from?
  16. Jan 5, 2018 at 6:41 PM
    jacob.jons.jj
    Jacob
    leveling kit
    and with a 1.25" wheel spacer can i still use my factory studs? and should i expect excessive wheel bearing issues?
  17. Jan 5, 2018 at 7:00 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Might need to push the liner forward, but that’s easy. A CMC is a possibility, but with the offset you’d be at with spacers you’re in the right range to avoid it. Off the top of my head, Toytec sells em.
    Not sure on the studs, and haven’t heard of any wheel bearing issues with spacers. @csuviper did you have any issues with yours? I’d say look through the wheel and tire section, there may be something in there.
  18. Jan 5, 2018 at 7:09 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yes you can use factory studs.
    I didn’t have any issues at all and I believe I had the wheel spacers on for 3 years
  19. Jan 5, 2018 at 9:57 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Very nice-looking truck. Glad to see I'm not the only one who thinks cement looks good with chrome! I was all set to de-chrome right away, but then the more I looked at my truck the more I realized I didn't not like the way it looked with chrome. That, plus I hate spending $$$ if I don't have to. That said, if Toyota ever gets around to releasing that TSS-P-friendly TRD Pro grille I might have to bite...
  20. Jan 5, 2018 at 10:02 PM
    Air2Ground
    Air2Ground This summa bitch is gonna scream!
    Michael
    Herndon, Va
    Building this brick by brick.
    K&N CAI Series 77 Banks Monster Exhaust Stage 2 Icon suspension SPC UCA's Coachbuilder Shackles +2's and poly bushings Coach Builder Front Bump Stops Steel Braided Break Lines by ToyTec Icon 6 speed 17" Wheel 315/70/17 BFG Goodrich KO 2's Tekonsha Trailer Brake AirRaid Throttle Spacer Slotted/Drilled Rotors by StopTech w/ stock pads Pioneer AVIC 8100 Receiver/Focal Component Speakers (4) JL Stealthbox JL Audio HD series amps 500/4 and 750/1. Complete Dynamat of cab Python Alarm/Remote start Linex sprayed front billet grille with "T" logo Linex sprayed bed Retrax Bed Cover 6" powder coated step bar High End 3M 5% tint PIAA Fog Lamps DIY Superman trailer hitch "S" WeatherTech Mats TRD Shift Knob Upcoming Mods: debagging Future mods: Front/Rear bumper winch supercharger and rebuild (blueprint) engine new lights in and out headlight/taillight combo Skid plates Cat Back Exhaust and Long Tube Headers.....? (Still deciding most optimal way) I NEED A SOLID TUNE!!!! Etc....
    I ran 305/65/18 with factory OEM wheels on 3/1 spacer. Minor bending took place. I actually have the old OEM wheels and tires for sale
  21. Jan 7, 2018 at 5:05 PM
    jacob.jons.jj
    Jacob
    leveling kit
    Awesome man glad to see someone out there with some facts and running what i want to put on mine.
    Sunnier and Watt maker like this.
  22. Jan 13, 2018 at 5:58 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    No pushing the fender liner forward??
    Watt maker and Sunnier like this.
  23. Jan 13, 2018 at 8:38 PM
    Sunnier
    Sunny
    San Diego, CA
    Ronald, your truck looks great! You don't have any rubbing, not even turning, in reverse? That's winning!
    Watt maker likes this.
  24. Jan 13, 2018 at 8:50 PM
    Sunnier
    Sunny
    San Diego, CA
    This is great! Finally, some info I'll hold on to, for when it's time for replacement tires. I'd like a tiny bit more clearance off road, but not a lift for looks. :thumbsup:
  25. Jan 13, 2018 at 9:27 PM
    Sunnier
    Sunny
    San Diego, CA
    Well, shoot. I did forget that. For reasons I don't know, I always get comments that my TRD truck looks "leveled" but it came this way from the dealer. No hurry but, when you get a few minutes, please will you measure your truck at the front, from mid-hub to ground, and from mid-hub to the edge at the lip of the fender-- then get the same measurements at the rear?, and, if you do, share them with me (and the OP).
    I've never needed to know if my lift really is a bit off in a good way-- but knowing what it is in comparison to yours would help me know if it's realistic to stuff bigger tires on without more lift. No hurry (these are new tires, and I practice great discipline resisting most of what I don't need).
    If you can do this, thanks in advance!
  26. Mar 8, 2019 at 3:51 PM
    Keepin'itreal
    Keepin'itreal New Member
    2017 Tundra TRD Offroad
    None...yet
    So no leveling kit with the 295/70/18 tires? I have the TRD Off Road but was looking at adding 2.5' to the front because I think it needs a little adjustment.
  27. Mar 8, 2019 at 5:16 PM
    49erSR5
    49erSR5 New Member
    18 SR5 4x4
    3" lift 34" BFG KO2 on SR5 wheels Rear AirLift airbags with on board compressor.
    Here is 275 ko2's on the sr5 wheels with a 3" kit.
  28. Mar 9, 2019 at 3:02 PM
    Kurdt
    Kurdt New Member
    Austin TX
    2019 Cement CrewMax TRD OR
    I keep reading conflicting things about running 295's on the stock TRD Offroad and 2017 era TRD Pro wheels. I was told that you'd be hitting the UCA without using spacers on 295's, but it seems like that isn't the case for everyone. I'd rather not run spacers if I can avoid it, but I'm planning to run 295/70/18 with about 2.5" lift up front.
