3'' front 1'' back leveling VS only 2'' front leveling
Discussion in 'Suspension' started by herchi79, Sep 26, 2018.
  1. Sep 26, 2018 at 11:10 AM
    herchi79
    herchi79 [OP] New Member
    Tundra 2018 1794 ed.
    N/a
    Hi guys, I want to add 2'' front leveling kit to my 1794 ed. 2018 tundra, but some people that "work on lifting" say that normally tundras must have a 3/1 leveling kits. Otherwise, you are not leveling the truck. This is nonsense. If I am adding only 2'' front, I am not adding that extra inch (to make it 3'') in front so I don't need 1'' back. So according to mathematics, you must be available to level your truck with 2'' only in front. Am I right here ? or am I missing something ? Thanks
    Boerseun likes this.
  2. Sep 26, 2018 at 11:22 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
  3. Sep 26, 2018 at 11:25 AM
    TunderStorm
    TunderStorm New Member
    Michael
    2018 TRD SR5 CM MGM +
    - Toytec/Eibach 3/1.5 + TC UCAs - Fuel Vapor 18x9+20 w/BFG KO2 35’s - TRD sway bar - Go Rhino nerf bars - badge delete - Bakflip MX4 - ESP storage - Rockford Fosgate 10’s +++ - TRD shift knob - Weathertech front mats - Escort 360 hardwired - Window tint Future mods: N-Fab M-RDS front bumper w/40” Black Series RC Lightbar
    They come with a rake. Mine is a 3/1.5 and I have about .5-1” rake (higher in rear). I like the look.
    So a 2/1 seems it would make it near “level”. I’d look at pics of Tundras with just a 2” level up front and see how you like it. What tires and wheels are you going to run?
    Zoren Tundra and Shelbie67 like this.
  4. Sep 26, 2018 at 11:33 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I just did the math on a calculator. Yes, you are correct. :thumbsup:
  5. Sep 26, 2018 at 11:50 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Gernally, most kits will come with lift for the front and rear simply to achieve more lift. To get these trucks level, you are looking at roughly 2-2.5". I was worried about going nose high on mine, and only went with a 2" lift for the front. My truck has a slight rake now that it has settled, but it's pretty close and I'm happy! The first picture is right after I installed it, about 4 years ago. The others are from this year.
  6. Sep 26, 2018 at 1:38 PM
    herchi79
    N/a
    Nice truck ! Thanks parker44
    parker44 likes this.
  7. Sep 26, 2018 at 1:48 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I agree with your math.
    Same difference.
    2/0 is just leveling
    3/1 is leveling with lift
  8. Sep 26, 2018 at 1:51 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    They come with a rake, and all trucks sit different, measure from ground to top of the wheel well, get 4 measurements. Add height accordingly. I’ve heard some people add a shim just to the drivers side to even the front laterally, in addition to whatever they’re doing because it sits lower.
    Also, perfect level based on measurements will look slight Cali lean. It’s an optical illusion of the roof profile so I’d be more inclined to leave a tiny bit of rake. Since mine stock is a 2.25” difference, adding just 2” to the front will have it looking level.
    Lastly, if you go bigger tire or more offset towards zero, you may want the additional 3/1, not just 2 to avoid rubbing.
    Black Wolf likes this.
  9. Sep 27, 2018 at 10:59 AM
    enicholas
    enicholas New Member
    2018 Toyota Tundra 1794 Crew Max - Black
    Running boards & Retrax One Tonneau Cover
    Hi guys, I'm new to Tundras.com so if this is covered in another thread, please point me in the right direction.
    I recently purchased a 2018 Tundra CrewMax 1794, Black. I'm considering having it leveled also but I'm worried the leveling may interfere with the Toyota Safety Sense features because you're adjusting the height of the sensors. Has this been an issue with anyone who's leveled/lifted their Tundra w/Safety Sense? Thanks so much for the advise.
  10. Sep 27, 2018 at 1:47 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    2" in the front will be level - this is what I did initially. When I carried any weight in the back I was nose high so after a few months I added shackles in the back to lift the rear 1".
    This is level with 2" in front and 0" in back:
  11. Sep 28, 2018 at 3:13 PM
    doiz
    doiz New Member
    B
    2017 Tundra 1794 4x4
    Hey SR5Shark - Nice setup, I like the looks and stance. What size wheels and tires are you running. Any front wheel rubbing?
  12. Sep 28, 2018 at 3:20 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Thanks. The wheels are SCS SR8 (18x9 w/ +25 offset) and the tires are 295/65 18. No rubbing after removing the front mudflap and pushing the front liner forward about an inch. This pict was taken before adding the shackles. Now I have a little rake so I am not nose high when loaded or towing my popup trailer.
    joonbug, MDHinSD, equin and 1 other person like this.
  13. Sep 28, 2018 at 4:20 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    2" front only is what I did on my 2016. Level, with a little more up loaded. It is also same numbers as a PRO from 2016.
    equin likes this.
  14. Oct 2, 2018 at 6:31 PM
    TundraBilly
    TundraBilly New Member
    2019 Toyota Tundra TRD Sport
    Wireless charging center armrest mod 2 3/4 Rough Country front level kit Firestone Ride Rite rear airbags 33x12.50.20 Nitto Ridge Grappler tires Debadge IFORCE emblems 20% window tint Blue led interior and ambient footwell lights
    I have a 2019 that I want to put a 3inch level and the front and firestone ride rite airbags in the rear. Do I still need a 1 inch block in the rear?
  15. Nov 2, 2018 at 7:32 AM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    I did a 1.5” spacer in the front and it looks slightly nose high on the passenger side, and depending on the angle, also on the driver’s side. Because of the tundra’s lines and wheel wells I’ve noticed that it looks different from all angles. From the front view it seems to look nose high, and as you move to the rear, it looks different. I didn’t seem to have this when leveling my Tacoma’s. Sometimes I like the look sometimes I don’t depending on where I’m parked and how I’m looking at it. I just wanted a slight nose lift, so I may remove these and replace with the Toytec 3/4”-1” spacer. So, be aware of that before spending on some work and driving away, and that even if you have a perfect level measurement, or a slight rake on measurement, it make not appear that way by eye.
  16. Nov 2, 2018 at 8:06 AM
    18Cement
    18Cement New Member
    Olympic Valley, CA
    2018 Cement Tundra Limited
    5100's on all fours Icon rear leaf Fuel Vector 20" Nitto Ridge Grapplers 305/55/R20 Leer Shell
    I used Bilstein's 5100's front and back. Front was set to highest setting at 2.28". Rear's don't add any lift. I have a shell so I also added an Icon leaf that gives 1-1.5" of lift. I am pretty level with less than a .5" of rake. No problems with TSS sensor. My wheels are Fuel Vector 20" with Nitto Ridge Grappler's 305/55/20.
    r1-superstar likes this.
  17. Nov 3, 2018 at 2:13 PM
    JETundra
    JETundra New Member
    18 Cement-
    Pictures? I'm thinking of doing the same.
  18. Nov 3, 2018 at 2:15 PM
    JETundra
    JETundra New Member
  19. Nov 3, 2018 at 2:19 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    I have a 3/1 and love the look.
  20. Nov 3, 2018 at 2:25 PM
    Mikekoot
    Mikekoot New Member
    Canadia
    2018 MGM tundra sr5 DC /2014 SSM Toyota Tacoma sr5 DCLB
    This is a 2 inch level? Looks perfect
    15whtrd and GNTundra like this.
  21. Nov 3, 2018 at 8:09 PM
    Jpagansr
    Jpagansr New Member
    Joel
    2018 tundra Trd Sport
    Safety sence is fine up to 3 inch lift any higher and your voiding the warranty per toyota
  22. Nov 5, 2018 at 10:08 AM
    18Cement
    18Cement New Member
    Olympic Valley, CA
    You bet. Give me a day or two. On the road...
    JETundra[QUOTED] likes this.
  23. Nov 7, 2018 at 9:02 AM
    18Cement
    18Cement New Member
    Olympic Valley, CA
    TunsofFon and TheGreyTundra28 like this.
  24. Nov 19, 2018 at 9:15 AM
    Jlallen94
    Jlallen94 New Member
    Jacob
    2018 Brown 1794 Tundra
    Looking for the same information. I have 2018 1794 and am pretty set on getting the Toytec/Eibach (which is either 2” or 3”) coils and running 285/60r20. However, I don’t really want the “lifted” look, but want the nose to be level (if not a tiny bit higher) than the front. I believe that 3/1 may be a little taller than I’d like, but worried that 2/0 want be as high in the front to truly level it out.
    Does anyone know if the Toytec/Eibach is exclusively either/or 2” or 3”, or can it be set between 2” - 3”?
    If anyone one has any input/pictures to compare it would be great!
  25. Nov 24, 2018 at 5:47 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Every truck is different. When I had the pro comp 3/1 I was slightly nose high. I had an add a leaf put on so now I have rake back which looks better. Plus I haul stuff in the bed and didn’t want to stare at the sky when I did. Add a leaf gives you extra payload if you need it
  26. Nov 24, 2018 at 5:52 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I have a 3/1.5 on mine but started with a 3/1 kit but I also tow once in awhile and now thinking of selling both my BDS 1" shackles that were on the truck for about 3 weeks and my TOYTEC shackles that I've had on my truck for about 5 months and purchasing the COACHBUILDER 2
  27. Dec 28, 2018 at 11:57 AM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    @Guhner123 what brand is that 3/1 level kit? Love the look, been researching on what i should do with my 2016 Tundra TSS SR5
  28. Dec 28, 2018 at 12:03 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    I have the 1inch block but I would recommend going with the adjustable shackle.
  29. Dec 28, 2018 at 2:32 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Toytec/eibach coilovers at 2" setting, no lift in the rear, with 275/70-18's.
  30. Dec 28, 2018 at 2:39 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    I’m shooting for 285/65/20 @helidave nice truck !
