3/4 Ton Truck
Discussion in 'Towing & Hauling' started by A-A-Ron, Jun 15, 2020.
Best New 3/4 Ton Diesel Option
  1. Ram
    26.2%
  2. GMC
    40.6%
  3. Ford
    33.2%
  1. Jul 22, 2022 at 4:01 PM
    #721
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    How big is the trailer you've towed with both trucks?
    Lake.Life24[QUOTED] likes this.
  2. Jul 22, 2022 at 4:11 PM
    #722
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    16’ with 8k of tractor. Total is around 10.5-11k. First two pics are the results of the exact same 83mile loop. Last photo is my setup now.
    FD7138E3-7E79-492D-BCE5-F1C74C5432CB.jpg 8C2DDEE3-C0A2-4289-8E33-D272513A4F13.jpg C91C226D-5E1B-4CD3-8C77-6233D6A38780.jpg
    Cpl_Punishment and ColoradoTJ like this.
  3. Jul 22, 2022 at 6:17 PM
    #723
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    1,700 mile road trip from Phoenix, AZ to Tyler, TX in the Cummins. Averaged 20.1 MPG on 35's! Speed limits ranged between 70-80mph so wasn't the most efficient speeds. First big road trip in the Ram and was super impressed. My iPhone is glitching being older but trying to send some pics
    ColoradoTJ and Lake.Life24 like this.
  4. Jul 22, 2022 at 6:40 PM
    #724
    Roctane84
    Roctane84 Tread On Them
    Louisiana
    ‘22 TRD Pro Solar Octane (SOLD)
    Ive had all 3 over the years but in 1-ton form. To me, a 3/4 ton is like a .40 cal. Makes no sense but people get them for some reason. You either legitimately need to pull weight or you dont, but I guess theres a group of folks that do need the capability from time to time but still want a somewhat comfortable daily truck.
    The Ford was garbage, and pretty much has been since the 7.3. Theyre getting some of the 6.7 issues ironed out supposedly now (only took nearly a decade) but I still am not convinced. Transmission was garbage also, not sure about now but I wouldnt trust it.
    Duramax runs great and is the “peppiest” of all three. They have their own sets of issues but nothing overall catastrophic other than CP4 and other random things, but this is across the board for all 3.
    Cummins (in stock form) doesn’t feel fast, and it really won’t until you have a trailer behind it. That’s where youll see where it shines. It is essentially a medium duty diesel (see Paccar applications) and was made to tow and move weight, and with the inline 6 torque curve, its always there. Hills dont matter. And the Cummins will go 1 million miles or more. Its the rest of the truck you have to worry about, just like the others. Make sure to get the Aisin transmission if able.
    My pick is and will always be the Cummins.
    snoope and Cpl_Punishment like this.
  5. Jul 22, 2022 at 6:48 PM
    #725
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Huge reason for 3/4 ton in many regions is GVWR can cause a lot more work with regards to commercial use for 1 tons. I know in BC here 3/4 tons are treated like a sedan - no weigh scale visits required, and there's other jurisdictions that require 1 tons to use a log book and limit hours, while 3/4 tons don't. So for personal use may as well get the slightly more beefed up 1 ton, but if commercial use is in the cards getting a de-rated (under 10000 lb GVWR) 3/4 ton could be very advantageous.
    Also around my area trying to find a gas 1 ton is like a unicorn (I've dealt with far too many DEF issues to want a personal diesel, if I'm not towing 20k lbs I'd rather pass on the diesel) but 3/4 tons have far more gassers to choose from. So in pre-crazy vehicle price times a 3/4 ton gasser could be negotiated on far easier and get the price down a lot more.
  6. Jul 22, 2022 at 7:53 PM
    #726
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    Agreed night and day difference, 1/2 tons are no match for 3/4 tons and above.
    Devcom[QUOTED] likes this.
  7. Jul 22, 2022 at 8:03 PM
    #727
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    If I was towing that much weight, I'd definitely be in a heavy duty. My Tundra seems to do fine with my 6500 lb trailer for what it is (i.e. a halfton). Obviously an HD would tow nicer. If I had to replace it today, it would most likely be with a GM 3500 gas crew cab standard box. Maaaaaaaaybe a GM 1500 with the max trailering package but they're having enough issues that it would be a tough sell. It's not like the 1500s are any cheaper than the HDs...
  8. Jul 22, 2022 at 8:15 PM
    #728
    In bold made me smile.:thumbsup:
    There's a lot of competition in the HD market today. In my opinion (whatever that is worth), the domestic truck market is very competitive. Whether you choose a 3/4 ton or 1 ton, gas or diesel...they are work horses.
    I have a group of friends with Ford 6.7L trucks without a bunch of issues with over 130K miles. They also use them for tow rigs, not grocery/soccer mom duties. The CP4 is a concern. If I owned one, the CP4 bypass kit would be installed. Best 400.00 investment to save 10-12K and months of wait time.
    Duramax LML I would do a CP3 conversion. It sucks, and it costs 1750.00 but worth the piece of mind. The conversion is a PITA and enough to make the Pope drop an F-bomb. 17-2022 do not use CP4's anymore. They use a Denso fuel system (HP4).
    Cummins....I'm a little bias since working in a Cummins performance shop. They have plenty of issues too. For instance, I would swap out the intake horn on a Cummins 6.7L ASAP due to the factory grid heater bolt that breaks off and sends it down to a piston. That is a serious concern considering how much time it takes to R&R one of these motors. 2019-2020 CP4 issues...but those are on recall.
  9. Jul 22, 2022 at 8:18 PM
    #729
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My unofficial survey of the campground says the Super Duty is the most popular new heavy duty and it's not even close. I think I've seen two current gen GMs and no current gen Dodges.
    Lake.Life24 and FrenchToasty like this.
  10. Jul 23, 2022 at 2:53 AM
    #730
    Lake.Life24
    Shawn
    Upstate, NY
    That’s exactly why I upgraded. I love the tundras. I’ve owned 2 of them. My favorite truck ever was my 2018 Tundra Crewmax in cement gray. But my needs changed so I had to get a truck to match. My GMC 3500 I got for $47k OTD. My tundras and comparable GMC 1500 would be $45-$46k back then. Now the 1500s might be more :rofl:
  11. Jul 23, 2022 at 5:42 AM
    #731
    Roctane84
    Louisiana
    Campground is probably not the best indicator. Look at the commercial use, especially hot shot freight guys. Id say over 85% Cummins. Its not even close.
  12. Jul 23, 2022 at 7:12 AM
    #732
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    True. Over here all the vehicle transporter trucks I see are RAMs and maybe 1 or 2 Fords.
    Roctane84[QUOTED] likes this.
  13. Jul 23, 2022 at 12:00 PM
    #733
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I haven't seen a lot of pickups being used commercially but most of the horse trailers I see on the highway are behind Cummins.
  14. Jul 23, 2022 at 12:29 PM
    #734
    Ram/Cummins has done a lot of work improving the current models. I would totally buy a 2022 Ram 3500 SRW in the Laramie package at a minimum.
    They are slow AF, but that’s not really what the inline 6 is designed for. Hell, your buddies with Fords and GMs can have a cold one waiting for you…
    Cpl_Punishment and Roctane84 like this.
  15. Jul 23, 2022 at 12:32 PM
    #735
    Lake.Life24
    Shawn
    Upstate, NY
    If I get a diesel it will be a Cummins. Especially if they mate that Allison to it. Towing is never a race so I’ll go for longevity
  16. Jul 23, 2022 at 12:34 PM
    #736
    Roctane84
    Louisiana
    This is exactly my point. Powerstroke and DirtyMax are always going to beat you off the line.
    The Cummins will feel like a pig off the line but when you get a trailer behind them, you just know.
    When I first got mine I thought I’d made a mistake. My dad, who has also had all 3 and has rocked the cummins since forever, said “put a trailer behind that sumbitch and then lemme know…” :rofl:
  17. Jul 23, 2022 at 12:35 PM
    #737
    It would be a toss up for me between the Ram 3500 or GM. Until Ford addresses the CP4, I’m not going to deal with it.
    In the 3/4 ton it would only be GM. I can’t stand that Ram puts a standard output in them instead of giving the option for the HO/Asian.
  18. Jul 23, 2022 at 12:42 PM
    #738
    Good trucks for sure. I’m interested in getting my hands on a ‘22 3500 with that 1075 #ft tq.
  19. Jul 23, 2022 at 12:43 PM
    #739
    Lake.Life24
    Shawn
    Upstate, NY
    True. I would only go Ram HO. Duramax after that.
  20. Jul 23, 2022 at 1:30 PM
    #740
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Duramax GM would be my choice here. The Cummins/Aisin is great, but the rest of the truck is important, too. :rofl:
  21. Jul 23, 2022 at 1:32 PM
    #741
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Shouldn't drive faster than the speed limit anyway...
  22. Jul 23, 2022 at 1:34 PM
    #742
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'd love a 3500 with the HO Cummins, a 6 speed manual and front bucket seats. Based on my brief research (I find the Ram website hard to maneuver), that combo doesn't exist.
  23. Jul 23, 2022 at 2:18 PM
    #743
    Lake.Life24
    Shawn
    Upstate, NY
    I think manual stopped a year before the HO went into production. A guy I do tree work with has a manual and upgraded the turbo. 1ton SRW Laramie. That thing is a beast. I think it’s a 2018
  24. Jul 23, 2022 at 3:06 PM
    #744
    The reason that doesn’t exist is the manual transmission can’t take that kind of abuse (hp/tq).
    Lake.Life24 likes this.
  25. Jul 23, 2022 at 3:23 PM
    #745
    Lake.Life24
    Shawn
    Upstate, NY
    That makes sense. If I was Ram I wouldn’t trust me with that much torq and a manual
  26. Jul 23, 2022 at 3:52 PM
    #746
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Would be fun though…
  27. Jul 23, 2022 at 4:06 PM
    #747
    Lake.Life24
    Shawn
    Upstate, NY
    Hell yeah it would be
