3/4 Ton Truck
Discussion in 'Towing & Hauling' started by A-A-Ron, Jun 15, 2020.
Best New 3/4 Ton Diesel Option
  1. Ram
    26.2%
  2. GMC
    40.6%
  3. Ford
    33.2%
  1. Aug 3, 2021 at 11:31 AM
    #571
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    This description sums it up best:
    "This is the AirDog I FP-100 fuel system for the 2001-2010 Chevy/GMC Duramax 6.6L. This diesel lift pump mounts to the frame rail using the supplied sandwich plate mounting system. This system utilizes the factory suction port in the fuel module for suction and plugs into the factory fuel line on the pressure side to supply fuel to the CP3 injection pump. The return is sent back to the tank through a filler neck tee. This is one of the easiest fuel systems to install. This is a 100GPH (Gallon Per Hour) lift pump system. Check out our installation manual for a list of parts that are included with this kit."
  2. Aug 6, 2021 at 6:46 PM
    #572
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    I actually had a 2007 Duramax LBZ back in the day. That was one of the only trucks that I really kicked myself for getting rid of. Mine was flawless. Give anything if I still had that truck today!!!
  3. Oct 16, 2021 at 7:42 AM
    #573
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Liking that way more than the Denali....are you now not happy with the diesel?
  4. Oct 16, 2021 at 8:28 AM
    #574
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    The one I picked up from Idaho, my dad thought it was an LBZ. Quickly I figured out it was a LMM.
    Now, am trying to figure which truck to start building out:
    Tundra = blower; or
    Duramax = delete, tune, slight lift, wheels
  5. Oct 16, 2021 at 9:23 AM
    #575
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I’m still very happy with my GMC Diesel!
    Lake.Life24 likes this.
  6. Jan 12, 2022 at 10:52 AM
    #576
  7. Jan 13, 2022 at 7:12 AM
    #577
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    I've had my 2018 Ram 2500 Cummins for over a year now.
    Been to the dealer twice, for a power folding mirror issue, then again when they installed the wrong mirror.
    I've only put 8,900 miles on it.
    Price on maintenance hasn't really been an issue personally (I don't drive very much). I put Amsoil fluids in diffs, engine and T-case myself and did Oil/Fuel Filter change. With that said fuel filters are about 120 bucks for the pair.
    MPG Avg is about 18.6, went on a road trip (all flat driving) towing a 20' bass boat half the trip and over all avg was 22.8 MPG (hand calculated computer showed 23).
    It's still stock except for Banks Diff Cover, Tint and AFE Intake Filter.
  8. Jan 13, 2022 at 7:31 AM
    #578
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    Nice Ram!
    ColoradoTJ likes this.
  9. Jan 13, 2022 at 7:31 AM
    #579
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    The thing about 2007+ diesel trucks is that the emissions equipment killed the fuel economy. Most of these HD diesel pickups now days are 15-17 MPG trucks empty, 10-13 MPG loaded heavy. If I'm going to get 11 MPG towing a large trailer, why use a diesel when a gas engine will do the same on less expensive fuel?
    I just came from two diesel trucks to this Tundra. What is refreshing is that I no longer have to buy $45 oil filters, $40 fuel filters, jugs of DEF, $9/quart engine oil, etc. I also don't have a $10,000 Bosch fuel injection system to worry about. I don't have to wait in line at the one diesel pump when there's 8 gasoline pumps open. And I don't have to buy fuel that's $0.50/gallon more expensive anymore.
    Diesel is cool, but 9 out of 10 people who own one don't need it and are spending more money to have it.
    AircareTundra and Cpl_Punishment like this.
  10. Jan 13, 2022 at 7:35 AM
    #580
    Nightshade Tundra
    Alex
    Some of the same reasons why I just went with the gasser. I'm getting 18 on the highway and 13 around the city and about 11/12 towing my 33ft trailer. Also I would have been paying $10k more for the diesel option if I went that route. The gasser fit my needs better but diesels do hold their value much better in the long run
    PLC721 likes this.
  11. Jan 13, 2022 at 8:09 AM
    #581
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    The HD gassers are getting there. I love my 6.6L GMC. I have a couple times wished I purchased a diesel. But I was able to buy the truck and a dump trailer for the price of the diesel. Now it got me into a side business. Anyone looking at a HD truck don't shy away from testing out the gas engines
  12. Jan 13, 2022 at 8:34 AM
    #582
    Redcon41318
    Redcon41318 New Member
    I just dont think these new diesels due to emissions regulating, perform as well as pre def diesels. My families 06 duramax is a beast. Gets 19-20mpgs highway and 15mpgs towing a 10k trailer.
  13. Jan 13, 2022 at 8:45 AM
    #583
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    The efficiency certainly isn't there, but they are ungodly powerful now - you tow something and you don't know if you have 2 quads back there or an apartment building. It would be awesome to delete a new one, but that sure is costly on top of the big premium to start with.
    Cpl_Punishment likes this.
  14. Jan 13, 2022 at 8:48 AM
    #584
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    IG: PLC721
    Deleting is actually pretty inexpensive (in comparison to replacing emissions parts), the tuner is the costly part. The cummins can be fully deleted for under 2k
  15. Jan 13, 2022 at 8:51 AM
    #585
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    My old boss just deleted his 2017 DuraMax. Is a freaking beast.
    I am still researching on what to do with my 2007.5 DM LMM.
  16. Jan 13, 2022 at 9:04 AM
    #586
    belanger9
    Edmonton, AB
    A bunch
    Kinda pointless to delete without a tune though, why start the process without finishing it to get all the efficiency gains (do you really need power gains anymore?)
  17. Jan 13, 2022 at 9:30 AM
    #587
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    IG: PLC721
    You have to tune it if you remove any of the emissions parts to pass any inspections, not have a CEL and to run correctly too of course
  18. Jan 13, 2022 at 11:02 AM
    #588
    I guess it depends on where you live. Diesel is not more expensive than 87 octane here. I never wait for fuel…then again I don’t go to the small stations that have 2 diesel pumps either.
    2C8594F5-0E5F-4A91-B3CD-FA8274B87DC8.jpg FCFF856F-1DBC-4F7F-98B9-9652174E48F2.jpg
    My last fuel economy testing in the mountains….
    Now make an apples to apple towing comparison. Let’s say 9k behind your tundra and 9 k behind a diesel. Tow the same route at the same speed and the gap will be a lot bigger. When I’m getting 11-13 mpg, the load is also 24-25k combined.
    Embellished a little on the oil filters…most expensive OEM one was 19.00. My Duramax one is 10.00. Fuel filters on Ford and Ram are more...that's for sure. Great candidates for a FASS or AirDog lift pump.
    Agreed on the Bosch fuel system (unless you have a newer DM, Denso injection system) and a good portion of people do no need diesels. Ask anyone that chat with me about what I recommend when purchasing a HD truck.
  19. Jan 13, 2022 at 11:03 AM
    #589
    Kennedy Diesel
  20. Jan 13, 2022 at 11:07 AM
    #590
    I don't think diesels hold better value. You pay 10K more at purchase. Here are two trucks, same year, similar mileage, Laramie package and what do you know...around 10,000 dollars difference in price.
    https://www.autotrader.com/cars-for...Code1=RAM&modelCode1=RM2500&clickType=listing
  21. Jan 13, 2022 at 11:08 AM
    #591
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    https://youtu.be/5YEmihm6w6g
    AircareTundra likes this.
  22. Jan 13, 2022 at 11:10 AM
    #592
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    Man. I haven’t seen diesel cheaper than gas in 15 years or so
  23. Jan 13, 2022 at 11:25 AM
    #593
    Nightshade Tundra
    Alex
    Man those two trucks are great examples I guess your right. The 6.4 has been getting a lot more attention lately than it has in the past so I wonder if that has something to do with them holding their value a bit better. Here's hoping that my 21 holds a decent amount of value over the years even though I don't plan on selling it
  24. Jan 13, 2022 at 11:29 AM
    #594
    Bama Tundra
    Bama Tundra New Member
    Eric
    2018 Crewmax Limited 4x4
    I’m thinking about a travel trailer & I’m looking at gas 3/4 ton trucks. The new Ford 7.3 gas & GM’s 6.6 gas motors. We have 3 Ram 5500’s & dealing with the DEF system is terrible. Our company won’t let us delete them but we have numerous problems. At a 100k the Ram’s interior starts falling apart. Our trucks don’t just have 1 driver multiple people drive them. I will not be spending my money on any Rams, Dodge. Hell I’d rather push a GM or a Ford.
    Lake.Life24 and Cpl_Punishment like this.
  25. Jan 13, 2022 at 11:32 AM
    #595
    It’s been like that for a long time. Been having that argument for many years about diesel vs gas holding value.
    If one can justify a diesel and afford it..great option. Most cases…not needed.
  26. Jan 13, 2022 at 11:56 AM
    #596
    Lake.Life24
    Shawn
    Upstate, NY
    From someone that has a 6.6 gas motor, I think you will enjoy it. Also I would try to find a 3500 single rear wheel. Price difference from 2500 is a joke and you get 1k more lbs of payload. My GMC 3500 has 4286lbs payload for reference.
    If you are going to be towing a lot. I think the best option and this is painful for me to say, it's the Ford 7.3L w/10spd and 4.30 gear. I picked GMC because I am biased and the Ford road like crap compared to the GMC independent front suspension. If I was towing in mountains or extreme weather I would get the Ford.
    GM needs two make two changes. Bring back the 4.10 option and/or add at least an 8spd
    ColoradoTJ and Cpl_Punishment like this.
  27. Jan 13, 2022 at 11:59 AM
    #597
    Nightshade Tundra
    Alex
    I'm gonna prove you wrong that the Ram interiors fall apart at 100k miles but we have to wait about 90k miles gotta get there first lol
  28. Jan 13, 2022 at 12:00 PM
    #598
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I think it's crazy that they don't offer the 10 speed with the gas engine but GM always has to try to upsell folks. 24 gallon gas tank in the 1500s so you go to an HD if you're towing. 6 speed with the gas engine so you go to diesel...
    Lake.Life24[QUOTED] likes this.
  29. Jan 13, 2022 at 12:05 PM
    #599
    belanger9
    Edmonton, AB
    A bunch
    GM was going to catch flak either way going 6 or 10 speed. A LOT of HD buyers do not want change. Heck going to 6.6 from the 6.0 bothered some people even though the 6.0 was so far behind the Ram and Ford offerings. So it was likely a smart move to keep existing customers by only changing the engine at this point, and save the 10 speed for the next couple years to introduce it.
  30. Jan 13, 2022 at 12:07 PM
    #600
    aggie_tundra
    2021 2500 Custom
    Long bed SLE 3500 with x31 off-road package and convenience package with 6.6 gas motor is $55k and well worth it. That’d be what I’d trade my custom for which was $48.5k for reference.
