3/2 lift...help with tire size
Discussion in 'Wheels & Tires' started by 408Tundra, Feb 27, 2018.
  1. Feb 27, 2018 at 7:45 PM
    408Tundra
    408Tundra [OP] New Member
    Will
    2017 Tundra TRD Limited Crewmax 4x4
    Thinking of going 295/70R18 tires. I do not want any rubbing. Is anybody else running the same size tires with a bilstein 6112 lift?
  2. Feb 27, 2018 at 7:48 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    There’s no avoiding rubbing with 295’s
    zcarpenter92 and 831Tun like this.
  3. Feb 27, 2018 at 7:56 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    @408Tundra you can fit it with minimal trimming. Just do it.
    831Tun and joonbug like this.
  4. Feb 27, 2018 at 8:00 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    What wheels do you have?
  5. Feb 27, 2018 at 8:06 PM
    408Tundra
    Will
    IMG_1208.jpgJust got these in 18"
  6. Feb 27, 2018 at 8:07 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    You will have to do some trimming. Worth it.
    zcarpenter92 and BlueBottle like this.
  7. Feb 27, 2018 at 8:08 PM
    408Tundra
    Will
    Maybe will go with 285/70R18
  8. Feb 27, 2018 at 8:09 PM
    Backslider
    Tooele, UT
    Dont. ;)
    I originally went with 285 and ended up selling them at a loss for 295s. If you want 34's just do it first or you'll regret not doing it!
  9. Feb 27, 2018 at 8:14 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    This! Listen to us.
  10. Feb 27, 2018 at 8:24 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yup. Trimming is like passing a kidney stone. Painful and sucks while you’re doing it, but afterwards.... happiness. :)
    Eclipsed & Floating likes this.
  11. Feb 27, 2018 at 9:28 PM
    408Tundra
    Will
    I trimmed my last truck. Ok 295's thanks guys.
  12. Feb 28, 2018 at 8:48 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    Can anyone confirm if you either will or will not need a CMC with 295's?
  13. Feb 28, 2018 at 8:52 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    The way I understand it is it depends on both your wheel offset and the alignment numbers you get. Any of you guys who know better than me, feel free to correct this if I’m missing something. I’m not rubbing the cab mount with 295/70’s on +12 wheels and 2.4-2.6* of castor, I just have some rubbing on the fronts when the springs are more compressed.
    joonbug likes this.
  14. Feb 28, 2018 at 10:07 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yeah just what Zach said. Also depends on what UCA you choose. Some place the tire closer than others depends on design. It really is up in the air if it will fit but the chances of it fitting on +25 is high. Myself, Zach, Joon and others are on 295's and never did the BMC.
  15. Feb 28, 2018 at 10:37 AM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    @matluth is in that list as well, and he runs 295’s with the same wheel that I do. @Almaboy did you chop the cab mount?
  16. Feb 28, 2018 at 10:40 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    You should add a Poll @408Tundra then you can see how many people needed BMC to fit 295's
  17. Feb 28, 2018 at 11:08 AM
    Darth Tundra
    Curt
    17 CM TRD Black
    295/70/18 !!!!.....Minimal trim on the skid plate....EASY PEASY....TAKE OFF FRONT SILLY MUDGUARS - FOWARD OF THE FRONT TIRE .....GOOD TO GO :thumbsup:
    Black Wolf likes this.
  18. Feb 28, 2018 at 12:04 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    No, and I have 35s
  19. Feb 28, 2018 at 12:12 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Was thinking from the standpoint of you having +12’s. I thought you were going down to 295/70 STT Pros?
  20. Feb 28, 2018 at 12:21 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Not yet
  21. Feb 28, 2018 at 12:33 PM
    renlo
    renlo New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    This is exactly what happened to me. Originally test fitted cooper at3 295/70. Rubbed bad front liner and mud flap. Purchased 285/70 due to them not rubbing but I always thought they looked a little small when looking at the truck at certain angles. Now I know its only 10mm but to me it looked small. I ended up pushing the wheel liner forward and removing the mud flaps and test fitting Nitto G2's and they cleared. Couldn't be happier. Im running 18x9 +18's.
    Just be aware the Coopers run wider than most brands and nittos run narrower.
  22. Feb 28, 2018 at 6:25 PM
    408Tundra
    Will
    Ok.....what is BMC, CMC?
  23. Feb 28, 2018 at 6:26 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Body mount chop, cab mount chop. They’re the same thing.
  24. Feb 28, 2018 at 6:28 PM
    408Tundra
    Will
    Thanks
    zcarpenter92 likes this.
  25. Mar 2, 2018 at 11:33 AM
    judge
    judge New Member
    2017 Black Limited 4x4
    Line-x bed liner, bilstein 6112 front/ 5160 rear, Century Royal Cap, 3m crystalline tint, Weathertech rear mat (large), Yokohoma G015 AT 275/60R20
    Good luck, but my 275/60 20"s (with 6112 lifting 1.5" and 2" rear block) rubbed at full lock on the stone guard (despite a lot of research saying they wouldn't) , my mechanic cut the flanges off both sides and voila. They are 33.1" high. The 295 version vs mine is about an inch taller and half an inch wider. (I'm looking at the specs for the same tire and reading the numbers and thinking it should be more... but I'm not going to argue with the manufacturer.)
