3/2 lift and TSS Radar
Discussion in '2.5 Gen Tundras (2014-2021)' started by emdcksn, Dec 1, 2020.
  1. Dec 1, 2020 at 12:19 PM
    emdcksn
    emdcksn [OP] New Member
    Eugene
    Eugene OR
    2021 MGM Tundra Platinum CrewMax
    Does anyone here have a 2018+ with a 3/2 lift and the sensor in the stock location? If you do, do you have handy issues at all with the radar?
    ‘I have the ‘17 Pro Grill w/the sensor in the ARES bracket. Everything’s fine around town, but at freeway speeds it cuts out. I have a 3/2 lift as well.
  2. Dec 1, 2020 at 12:24 PM
    1slow97
    1slow97 New Member
    2020 Calvary Blue LImited Off Road
    3/2 lift with 35's and SCS wheels
    mine(2020) does same thing with the pro grill and ares bracket, it's intermittent and I have just learned to live with it.
    emdcksn[OP] likes this.
  3. Dec 1, 2020 at 1:30 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Sounds like a loose connector or heavy vibrations are interfering with the sensor. I would check the extension cable's pin in - out (if it came with a cable). Rubber washers in-between the mount and the vehicle may help dampen vibrations.
    @2020Platinum managed to mount his below the grill without a mount, he may be able to share his lessons learned.
    emdcksn[OP] and 2020Platinum like this.
  4. Dec 1, 2020 at 2:05 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Hey guys!...I’m sitting on the 4/2 ReadyLift SST, and have an aftermarket grille...I got a little creative awhile back, works perfectly...a couple of my viewers have done it as well and no issues...hope it helps!
    TSS Relocation On An Aftermarket Grille (2020 Toyota Tundra)
    https://youtu.be/rDTXe9eNAFg
    emdcksn[OP] and Saltyhero13 like this.
  5. Dec 1, 2020 at 2:06 PM
    2020Platinum
    Patrick
    Northeast PA
  6. Dec 1, 2020 at 3:09 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    I have a 2.5” lift in front and 1” in rear on my 2019 with the 2014-2017 TRD pro grille and the TSS sensor relocated using the Jomax bracket and it’s been working flawlessly for over a year.
    Unless your vehicle geometry changes dramatically at highway speeds I would think it’s a loose connector or mount. Might check your wiring and sensor to make sure nothings loose.
  7. Dec 1, 2020 at 4:36 PM
    emdcksn
    Eugene
    Eugene OR
    I added a 1/4” of washers to the bottom 2 sensor bolts and it now works like it’s supposed to at any speed (checked on I5 at 78-79mph) and is was flawless. It speeds up and slows down like it’s supposed to now.
    We’ll see long term.
    2020Platinum likes this.
  8. Dec 1, 2020 at 4:39 PM
    emdcksn
    Eugene
    Eugene OR
    Spaced the bottom of the sensor another 1/4” and it is working as intended so far. It actually never worked correctly when I bought the truck new, even before the lift.
  9. Dec 1, 2020 at 5:03 PM
    emdcksn
    Eugene
    Eugene OR
    So far I really think it was the angle. I’ll see if the fix is still good in a month or so and repost. Dam, I was thinking about shackles/AAL to add another 1/2” in the rear. Well, I might do that anyway minus the extra 1/2”. I want to get rid of the blocks.
  10. Dec 1, 2020 at 5:11 PM
    emdcksn
    Eugene
    Eugene OR
    If my “fix” doesn’t work I might try this. I like how you can’t see the sensor at all.
    2020Platinum[QUOTED] likes this.
  11. Dec 1, 2020 at 6:02 PM
    Saltyhero13
    Oh that is great! so are you thinking the angle was slightly off or is the washer dampening the vibrations? I could see the beam being scattered if it is vibrating too much.
  12. Dec 1, 2020 at 6:19 PM
    emdcksn
    Eugene
    Eugene OR
    Correct, I think it was all angle because of the loss of front end rake. I think with the truck sitting level, 3/2 lift on 35’s, it possibly wasn’t seeing much of the car ahead and freeway speeds may have made it even worse. It got better when I changed from a 3/1 lift to a 3/2 lift (2” block instead of a 1”, it really didn’t work at all with the 1”). By tilting it a little more towards the ground was like adding rake back to the truck and now it works like it never has. I can actually use all 3 distance settings instead of just the largest setting #3. As before I could only use #3 around town and on the freeway until it turned itself off. When new and pre lift most of the time it was all warning and “BRAKE” messages. Like I said, it actually works now unlike the last 2 1/2 years. For the long term, we’ll have to wait and see. I know it seems to be different from truck to truck on whether or not it works, but I am more optimistic now than I ever have been.
    As far as the clean sensor message goes, I haven’t seen that message since I took the sensor out of the stock housing.
