3" / 1" - LRO -/- Supreme Suspension
Discussion in 'Suspension' started by LiftMeUp, Oct 5, 2016.
  1. Oct 5, 2016 at 9:41 AM
    LiftMeUp
    LiftMeUp [OP] New Member
    I'm pretty set on a 3" front / 1" rear lift. I know there are other routes, but this will be all highway just for looks, no towing and on a budget. I've read rave reviews for LRO but have also seen where people like Supreme Suspension as well. Both match up closely, billet aluminum, etc., but a good bit difference in pricing.
    Anyone familiar with Supreme Suspension? Any deciding factors between the two that would make you lean one way or the other? Thanks.
  2. Oct 5, 2016 at 9:58 AM
    ToyotaTundraMike
    2015 Tundra
    Tbh Ive never heard of either one of those. Search this forum and check out toytec's website. Even if you dont go offroad I would be very skeptical of putting a random lift from a company that doesnt have any sort of reputation with Tundra owners.
    Forum members also get a discount at toytec, and they sell brands other than their own as well.
    Black Wolf, TheBeast and T-Rex266 like this.
  3. Oct 5, 2016 at 10:37 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I'd definitely go with a reputable company. Even better, go with bilsteins. Not much money but better all around product.
    Or go with toytecs in shock spacers. Safer than on top spacers.
    Or save up some cash and get coilovers.
    T-Rex266 likes this.
  4. Oct 5, 2016 at 11:11 AM
    LiftMeUp
    LRO - Low Range Off-Road. Just about every thread I'm come across is promoting LRO, supposed to be the best out there along with Toytecs. Actually, seen where Tundra owners go with LRO over the Toytecs.
    Going to have to check out the shock spacers.
  5. Oct 5, 2016 at 11:43 AM
    onsafari
    onsafari New Member
    Mark
    Castle Rock, CO
    2016 Tundra CM TRD
    I've been doing some research on the LRO kit and it's the best out there as far as on the top of the shock spacer do to the way the studs are fastened to the spacer. Their kit also comes with the 1" rear block that is tapered to help the rear drive shaft angle.
    The ToyTec kit is nice as well but the spacer goes between the top hat and the spring which compresses the spring which makes the ride a bit more harsh and stiff.
    Ultimately the best route is a new set of shocks whether the 5100's, 6112's or a new coilover set but it all comes down to personal preference. If it just a street truck then I would think a set of spacers which sit on top of the shock would be fine. There are plenty of them on the road and sitting on dealer lots with this very thing and I've never heard of any issues.
  6. Oct 5, 2016 at 12:05 PM
    LiftMeUp
    Yea, everything I read was that LRO was the best kit out there. I came across the Supreme Suspension kit and looks very similar and about $100+ less. Those that used it said it was the same just less expensive. Lifetime warranty, etc.
    I've always wondered about those trucks on the dealer lots, if that is what they went with. I've seen post about having the kits put on at dealerships as an option or purchase with them. Seems if dealers are going this route, then it must be okay?
    I've looked into the 5100s but would not give me the rise that I need and everyone says it's a harsher ride quality.
  7. Oct 5, 2016 at 12:51 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I was in the same boat as you. I went with LRO just because of their track record. I know the spacer is aluminum but what I'd be worried about are the studs. If Supreme goes cheap on the studs it can sheer off causing an accident and damage to your vehicle. I should be getting mine installed on the next week or two. Hopefully my ride will be nice still.
  8. Oct 5, 2016 at 1:15 PM
    LiftMeUp
    Definitely something I'm going to have to look into. Another thing is whether the rear block is angled or not. Wouldn't seem at an inch it would matter, but don't think it could hurt either.
    You doing install yourself? If not, how much does it run if you don't mind me asking. You going front and rear or just front?
  9. Oct 5, 2016 at 1:18 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I actually just bought the front from LRO.
    I got CB+3 for the rears.
    A friend will be doing the install.
    If you want just the fronts, email LRO and they will adjust he price. Hope that helps. I prefer shackles over blacks.
  10. Oct 5, 2016 at 1:25 PM
    LiftMeUp
    Yeah, I spoke to one of the sales guys and said they he would break it up if I only needed the front. Or I could order the kit and return the rear if I didn't use. Not sure, once I put on the front 3" that I will need the rear. Right now I have about a 3.5" rake, so gonna look and see.
    I thought about going with shackles but since maybe only going 1" thought blocks would work. It's all highway miles.
    If you have any side pre pics and then some post, would love to see.
  11. Oct 5, 2016 at 1:28 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    :eek: Lol ...
    We know what you meant.
  12. Oct 5, 2016 at 2:22 PM
    ToyotaTundraMike
    2015 Tundra
    Sounds like you have done your research. If other Tundra owners run them without problems and your goal is just for looks Id say go for it and keep us posted how it turns out for ya. Just a fyi though, I wouldn't justify installing something just because a dealer does. These are the same ppl that install pro comp long travel kits which are known to be garbage and ask for an extra 15 grand.
    zcarpenter92 likes this.
  13. Oct 5, 2016 at 8:05 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    LOL I didn't even see that... iPowned Autocorrect!
  14. Oct 8, 2016 at 5:39 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Got my lift in today.
    Ended with about 3.15" up front & 1.5-1.76" rears.
    LRO spacer + CB +3 rear shackles
    Still on stock wheels & tires
    8C210851-A23C-4767-B321-652A94A4D61F_zps_4b47dcdfb1085d5fb52702db422143077d251197.jpg
    csuviper, Law323 and rons23 like this.
  15. Oct 8, 2016 at 8:11 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Give the shocks about a week to settle. You'll probably lose around a quarter of an inch in height up front.
  16. Oct 8, 2016 at 9:03 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @Law323 yeah I have an appointment for my alignment next week so hopefully it's settled by then. The front does seem pretty high. I was expecting more rake with the +3. Right now I only have less than 1/4" rake.
  17. Oct 8, 2016 at 10:26 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yeah, my truck was perfectly level give or take 3/4 rake and I hated it (second gens look nose high even at level) I decided to wait a week before taking any steps and sure enough I had lost about a quarter of an inch or so. Now it sits perfect for me at 1.25" of rake.
    Every guy I know that's done the level has lost a little bit of height afterwards.
    Alignment will help with that somewhat too. So you're golden!
    PermaFrostTRD and BlueBottle like this.
  18. Oct 13, 2016 at 6:51 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Getting my alignment tomorrow. What numbers are you guys shoot for as far as caster? I will shoot for oem spec for camber and toe.
  19. Oct 13, 2016 at 6:57 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    All same as stock numbers. Should be in the computer at the shop. That's what my shop did.
    How'd the shocks settle?
  20. Oct 13, 2016 at 7:02 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @Law323 reason I ask is LRO instructions say to use 2 for caster. Not sure why. Should I follow those instructions or stick with stock?
    I driven about 200 miles. It only settled another 1/16" from initial install lol. So I'm still over 3"!
  21. Oct 13, 2016 at 7:38 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    There's a thread on another forum that says what to put your alignment numbers at. Mine rode great on these numbers.
    http://www.tundratalk.net/forums/tu...recommendations.html#/topics/112656?_k=hz7ksp
    I'm betting it'll go down a little after alignment and another week!
    BlueBottle likes this.
  22. Oct 14, 2016 at 1:30 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @Law323 sweet.. made me do a lot of reading there!
    Cliff notes for those that don't want to read all those pages....
    Camber : +.1 / side
    Toe : +.12 /side
    Caster : as much caster you can get without sacrificing +.1 camber
    Please correct me if this is wrong!
    Law323 likes this.
  23. Oct 14, 2016 at 2:12 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I just skimmed through it and got the first post pertaining to alignment specs.
    Sounds about right brother!!
    Sorry about the novella link LOL
