3/1 Lift kits (Aluminum)
Discussion in 'Suspension' started by FirstTruck, Nov 13, 2020.
  1. Nov 13, 2020 at 2:08 PM
    FirstTruck
    FirstTruck [OP] New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    Hello members, I am willing to jump into a lift kit. I would like to use a solid aluminum billlet spacer than the welded iron ones. Has anyone used Low Range Offroad or / and Supreme Suspension.
    A 3/1 lift kit from Supreme Suspension is $190 with the 4WD spacers.
    Any suggestion will be much appreciated.
  2. Nov 13, 2020 at 3:38 PM
    Spacers make the ride a little harsher, and you don't want to offroad with them.
  3. Nov 22, 2020 at 12:00 PM
    FirstTruck
    Stock, for now
    Thanks for the tip. Does it get harsher even with the spacer is on top of the strut. In other words it will be outside the coilover. I have read that if you add the spacer on top of the coil, then the suspension will get a little stuffer.
  4. Nov 22, 2020 at 1:44 PM
    Yes it does. Thats why I got rid of mine.
  5. Nov 22, 2020 at 1:49 PM
    FirstTruck
    Stock, for now
    Shoot, really? So better go with shocks?
  6. Nov 22, 2020 at 1:51 PM
    There are several budget coilover systems that you can get in to.
  7. Nov 22, 2020 at 2:14 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
  8. Nov 22, 2020 at 2:42 PM
    FirstTruck
    Stock, for now
    Ok. Thanks for the advise.
