3/1 leveling kit on 2020 crewmax 4x4..?
Discussion in 'Suspension' started by OONIGHTTRAIN, Mar 1, 2020.
  1. Mar 1, 2020 at 10:37 AM
    OONIGHTTRAIN
    OONIGHTTRAIN [OP] New Member
    jesse
    silverado 2500 duramax 4x4
    im wondering if a 3/1 leveling kit on my new truck will require any cutting or modifications.. there is 275/55/20 tires. i do not know the offset on the rims..
  2. Mar 1, 2020 at 10:39 AM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    Don’t do it.
    Rider0120 likes this.
  3. Mar 1, 2020 at 10:45 AM
    OONIGHTTRAIN
    jesse
    why not?
  4. Mar 1, 2020 at 1:34 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    I have 275/65/20 tires which are right at 34" with just the front leveled. I did remove the front mud flaps (spats) though.
    Boerseun likes this.
  5. Mar 1, 2020 at 2:55 PM
    bdpeelgren
    Round Rock, TX
    The cheapest lift you should go with are bilstein 5100s.
    A spacer lift will throw your alignment out of whack and you’ll never be able to get it 100% right.
    Also with your truck being a 4x4. Why would you want to reduce the capabilities of your truck? If you’re off-road and hit a good bump say goodbye to your shocks if you have a spacer lift.
    Do a search on google for experiences with spacer lifts. You’ll probably change your mind.
    And this is coming from a person with a spacer lift.. I regret it and will be removing it eventually.
  6. Mar 1, 2020 at 3:05 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    A friend of mine has a 3/1, 305/55-20 on Fuel Octane D509s. No bmc.
  7. Mar 1, 2020 at 3:05 PM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    not sure OP is talking about a spacer lift...
    but OP, if your talking about installing a 3/1 lift not sure why cutting would be required with the size tire mentioned, looks like a 32” tire. You probably wouldn’t have to cut until about. 34”/35” tire pending wheel offset after a 3/1 kit.
    What kit did you have in mind?
  8. Mar 1, 2020 at 3:28 PM
    OONIGHTTRAIN
    jesse
    i was just looking around, something like a rough country or ready lift..
  9. Mar 1, 2020 at 3:30 PM
    r1-superstar
    DB
    UTAH
    Either of which will be fine as long as you are not looking to go off-roading and climbing rocks. :thumbsup:
  10. Mar 1, 2020 at 3:31 PM
    OONIGHTTRAIN
    jesse
    ill do a search on them.. whats the details, an adjustable shock??
    SC_TRD likes this.
  11. Mar 1, 2020 at 3:32 PM
    OONIGHTTRAIN
    jesse
    yes, there wont be any of that.. i live in florida.. there really isnt such thing down here.. SUCKS
  12. Mar 1, 2020 at 3:34 PM
    r1-superstar
    DB
    UTAH
    Check out my build thread for your answers. Supe's MGM Sport Build
  13. Mar 1, 2020 at 3:35 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I have a BDS 3/1.5 leveling kit and no cutting. Im taking it off though and going with a 4"-6". I don't off-road and it rides fine
  14. Mar 1, 2020 at 3:50 PM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    Spacer kits are just fine when coupled with axel drops for the cv angle and bump stop extension to prevent shock bottoming out. Most well know brands come with both in the kits
  15. Mar 2, 2020 at 4:50 AM
    Gearhead22
    Gearhead22 New Member
    Corning, Ny
    I went with a spacer lift and my truck is spot on with stock specs for alignment.
    aussieaarons and Boerseun like this.
  16. Mar 2, 2020 at 5:13 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I would not disagree that the 5100 is a better option, but everything you said about the spacer lift is false information.
    There are lots of 3/1 or 3/1.5 spacer lift members here who have no issues with alignment. Yes, it's almost maxed out, but to say it will "throw it out of wack and never be able to get it 100% right" is just not true and I don't understand why people like to spread false information like that.
    To say that "hit a good bump say goodbye to your shocks if you have a spacer lift" is the same BS. The kits come with bump stop spacers. Install it and there will not be any problems. 5100s will bottom out also if you don't install the spacers that come with them.
    It sounds like you have sour grapes - maybe didn't install your kit correctly.
    Again, I agree that there are better options, but don't spread false information......
  17. Mar 2, 2020 at 6:44 AM
    r1-superstar
    DB
    UTAH
    @bdpeelgren is right in saying a spacer lift will jeopardize travel and are more prone to snapping the lower portion of your OEM shock if compressed too far. i.e hitting a good sized bump off road. Spacer lifts just raise the front of the truck but don't lengthen travel of the shock. Bilstein 5100 leveling shocks are .5-.75" longer than OEM shocks so they are less prone to collapsing in above said conditions. Granted the supplied bump stops should be installed along with the 5100s to help avoid this from happening. That is not "spreading false information"...
  18. Mar 2, 2020 at 7:26 AM
    Boerseun
    Ferdie
    Sarasota Florida
    What I was saying is that the shocks will not collapse if you install it right (i.e. with the bump stops that are part of the kit). To make a general statement saying the shocks will collapse is false information. It will only happen if not installed correctly. My truck's engine will fall out if I don't install the engine mounts. That doesn't mean the engine is bad. Same principle.
