3.0 coilover with tie rod contact
Discussion in 'Suspension' started by 14burrito, Jul 31, 2018.
  1. Jul 31, 2018 at 9:59 AM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    You're going to sell your Icons to @dcsleeper408 and buy Kings? :notsure:
    dcsleeper408 and joonbug[QUOTED] like this.
  2. Jul 31, 2018 at 10:02 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Hell no. I love my Icon 3.0's. I just hate the damn Tubular UCA's. Really wish I coulda afforded the Icon Billets... I woulda been set.
  3. Jul 31, 2018 at 10:34 AM
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    Can you give me your full alignment specs?
  4. Jul 31, 2018 at 10:38 AM
    14burrito
    14burrito [OP] IG @14burrito
    2014 SR5 CM 4x4 5.7
    On a similar but seperate note,
    I have a CM with no added weight up front. My wheeling style I am VERY happy I went 600lb coils vs rhe 650/700 options which were available.
    The ADS 3.0 only come with 650lb from them....
    Anyone have any feedback on their 3.0 setups in these regards?
    Please note which mfg you have and what the spring rate is. Thanks
  5. Jul 31, 2018 at 10:42 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    -.5 degrees camber. .17 degrees toe. .32 degree total toe. 0 degree steer ahead.
    d0zer[QUOTED] likes this.
  6. Jul 31, 2018 at 10:44 AM
    sdhq_offroad
    GILBERT, AZ
    Icon's come with a 600lb spring rate but there is no option for heavier springs with their set up. So if you plan on doing a heavy bumper/winch set up, it may not be the shock for you. You could always do a 1/2" bumpstop spacer which gains you another 1/2" of preload. We have that done on our shop truck.
  7. Jul 31, 2018 at 10:48 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    ADS doesnt offer anything except the 650lb.
    Makes me curious why there arent multiple options for coil rates on the 3.0.
    Doesn't coil rate only "affect" valving around 5-8%?
  8. Jul 31, 2018 at 10:56 AM
    sdhq_offroad
    GILBERT, AZ
    Its the the block heights of the coil spring rate. For Icon's 16" spring set up, going to a 650 or 700lb increase the block height which limits the amount of preload. Mathematically, the lose of available preload yields the same lift height as the 600 with more preload.
    Total Coil Length - Shock Travel Length - Block Height = Available Preload before coil bind.
  9. Jul 31, 2018 at 10:59 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    At least you moved the boot in as to not wesr through that
  10. Jul 31, 2018 at 10:59 AM
    sdhq_offroad
    GILBERT, AZ
    Also, Icon's coils are a 16"x3.63x600, not 3.75 ID. So they are a little narrower to provide a little bit more clearance.
    dcsleeper408 and 14burrito[OP] like this.
  11. Jul 31, 2018 at 11:01 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Lot more involved that appears from the surface.
    I really do like the 600lb coils currently though :(
    dcsleeper408 likes this.
  12. Jul 31, 2018 at 11:03 AM
    sdhq_offroad
    GILBERT, AZ
    3.0's with 600lb coils and zero preload (thank you spindle) rides like clouds on and off road.
  13. Jul 31, 2018 at 11:21 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    So it moved itself?
    Should be to where the polished portion ends, about an inch or so more outward
    GodlessPro and dcsleeper408 like this.
  14. Jul 31, 2018 at 11:40 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Lol!
    GodlessPro, 831Tun and joonbug like this.
  15. Jul 31, 2018 at 11:55 AM
    TheBeast The Beach
    some good info here for the big boys with big toys..
  16. Jul 31, 2018 at 12:16 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm not even sure that it's the rack. When I start hitting bumps off road I feel something in the steering wheel, hard to describe, but it feels like the vibration you might notice from a rod being loose inside a cylinder. I don't know for sure that it's the rack, might be the half shaft? There isn't any play in the steering wheel..... meaning that the truck tracks straight and the steering doesn't have slop.
    I have a 175* turn at the bottom of the hill where I live. I was turning there (full lock) when I felt/ heard a slight pop that seems to coincide with the time that the steering issues began. At the time I was running Camburg ball joint arms. Unfortunately I don't know what the caster was at. All this is circumstantial and should be taken with a grain of salt 'cause I've got no actual proof. It's all merely my conjecture from what I've experienced.
  17. Jul 31, 2018 at 12:18 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    FACT!
  18. Jul 31, 2018 at 12:24 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yeah from trial and error knowledge can be found........:spending:
  19. Jul 31, 2018 at 3:38 PM
    #49
    14burrito
    2014 SR5 CM 4x4 5.7
    Found a 16" 600lb coil that has more "travel" / has a smaller block height than its Eibach counter part. It would seem the actual diameter of the coil itself may be smaller (smaller OD) which may remedy the contact issue with the tie rod?...hmm
  20. Jul 31, 2018 at 3:43 PM
    #50
    ReCKzX
    ReCKzX New Member
    2023 Tundra TRD Pro Ice Cap
    If I get back into a Tundra, I would be going with a TC UCA and King 3.0's with 700lb springs. Anyone run this combo and have problems?
    tundra_20 likes this.
  21. Jul 31, 2018 at 3:48 PM
    #51
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It says you have a base SR5?????? :rofl::rofl::rofl: No respect for your PRO.
  22. Jul 31, 2018 at 7:33 PM
    #52
    Mountains49
    Mountains49 New Member
    2018 White Platinum
    Icon 3.0’s with Icon Billet UCA’s. No contact that I know of so far.
    Wish I would have had this information/recommendation when I was planning my build.
    Custom Pac Springs through @sdhq_offroad are off the table and from what I hear so are attempts from Icon with Eibach.
    Can you explain the bumpstop spacer situation? Brand/material/height?
    Any modifications required?
    Pelfreybilt front bumper is on order. Is this an option or is looking for new coilovers in my future?
    What are the rest of your trucks specs?!
  23. Jul 31, 2018 at 8:06 PM
    #53
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    I've got 700lb springs on my ADS 2.5's ;) Then again, I had to land on their wall of shame to get them haha
  24. Aug 1, 2018 at 9:55 AM
    #54
    14burrito
    2014 SR5 CM 4x4 5.7
    Disregard.....you have the 2.5s. Nvm.
    Not sure why your on the wall of shame....they offer it.
  25. Aug 2, 2018 at 8:41 PM
    #55
    Help New Member
    Ryan
    Tucson, AZ
    I broke something. A first for everyone that saw it haha
  26. Aug 22, 2018 at 6:44 AM
    #56
    14burrito
    2014 SR5 CM 4x4 5.7
    So the PAC 600lb coils would cause more contact as they are about 1/4"larger OD then the 650 eibach on the ADS 3.0s. Poop.
    joonbug likes this.
  27. Aug 24, 2018 at 10:53 AM
    #57
    14burrito
    2014 SR5 CM 4x4 5.7
    Well, ill be making the jump here in the next couple weeks. Here's to hoping I will be contact free lol
    blue16 likes this.
  28. Aug 24, 2018 at 11:13 AM
    #58
    GodlessPro
    Matthew
    NorCal
    It's all in the alignment. I had to go back a second time. It was a shame, because I liked the way it drove after the first alignment better.
    joonbug and dcsleeper408 like this.
  29. Aug 24, 2018 at 11:27 AM
    #59
    14burrito
    2014 SR5 CM 4x4 5.7
    Which arms do you have again?
    Disregard, MCM uppers
    Well then, hopefully it works to clear my 35s still then. Just got aligned after jumping up to 315/70/17
  30. Aug 30, 2018 at 10:25 AM
    #60
    14burrito
    2014 SR5 CM 4x4 5.7
    Well, we shall see...
    These things are huge.
