3” Lift with 33’s or 35’s???
Discussion in 'Wheels & Tires' started by nathanmck, May 10, 2020.
  1. May 10, 2020 at 6:22 PM
    nathanmck
    nathanmck [OP] New Member
    Nathan
    2016 Toyota Tundra SR5 4x4
    Hello everyone!!
    Just purchased a Tundra and I am having the hardest time trying to figure out wether I should put 33” tires or 35” tires on. I plan on doing a 3” front lift and 1” rear lift and running 20x10 wheels but i’ve heard from people that I can absolutely not run 35” tires unless I chop the frame, but others have said differently. Pleas help me put because I am ready to order these parts and need to figure out what to buy, really looking to get 35’s but if it is not possible than i’ll have to get 33’s.
    Thanks guys!
  2. May 10, 2020 at 6:40 PM
    I run 285/70/18's (34's) on an 18x9 0 offset with a 3/2 lift. The 295/70 is popular as well. I don't know what size that correlates to with a 20 inch wheel. Others will chime in. Check out customoffsets.com for ideas as well.
    TXTundra89 and Tundraman1000 like this.
  3. May 10, 2020 at 7:56 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    5BFD1034-A41D-45A5-9B5D-7B43977B2F7B.jpg 305/70/r17 ridge grapplers 33.85 tall 12.25 wide on Rock Warrior wheels. 3/1.5 lift just a slight skid plate trimming. No rubbing throughout suspension travel..
    Skew12 likes this.
  4. May 10, 2020 at 8:04 PM
    redduc
    redduc 2018 Limited
    Derek
    2018 Met. Gray Tundra TRD
    Shell so far ......I’m going with a 3 inch lift and want to know if you guys like 285/70 or 75’s and did they rub?
    285/75 r18 Ridge Grapplers 34.8 high 11.2 wide, stock wheels 3/1 leveling kit Pro Comp little skid plate trim and remove front mud flaps no rub at full lock forward or reverse
    MTRock likes this.
  5. May 10, 2020 at 8:16 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    For you it's all going to depend on the offset of the wheels. That is what will make the decision for you unfortunately.
    I got 35s on my truck with positive offset wheels, no cutting necessary.
    MTRock likes this.
  6. May 10, 2020 at 8:31 PM
    EglSctAndy
    EglSctAndy MGM Crüe
    Andrew
    Arizona
    2019 MGM Crewmax TRD Sport
    Icon Stage 5 17” Icon Rebound Wheels TOYO Open Country A/T 35 12.5 RCI Heavy Duty Side Step Weathertech Mats 4” Stubby Antenna Fyre Flys Interior LED Lights Plastic Dipped Badges Decked tool box Baja Designs Squadron Sport fog lights
    Nobody regrets going big. Get the 35s :spending:
  7. May 10, 2020 at 9:37 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You’re not chopping your frame. You’re cutting off an itsy bitsy teeny weeny tiny little piece of metal off your cab mount and welding back a piece to cover it back up. 35’s!!!!
    jayjaces21, bocabasser, equin and 7 others like this.
  8. May 11, 2020 at 2:42 AM
    linwozzle
    linwozzle New Member
    Linden
    2014 SW Tundra Platinum 4x4 CM
    I got 33s, should've went with 35s so I am now looking at 35s
    Lightning_Lad likes this.
  9. May 11, 2020 at 2:56 AM
    Jemz808
    Jemz808 New Member
    Maui, Hi
    2018 SR5 Offroad
    I have a 3/1 lift with 35's...cut body mount and welded block off plate, remove those mud flaps, a little trimming and push the front wheel liners forward and your good to go 20200509_182202.jpg
  10. May 11, 2020 at 3:01 AM
    Jemz808
    Jemz808 New Member
    Maui, Hi
    2018 SR5 Offroad
    This is what we cut off the frame. Near the body mount.
    tundra_20, Toyotoholic and Tundra_361 like this.
  11. May 11, 2020 at 4:28 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    IMO, 33" tires on a 3" lift would look too small (I used to have 33" tires on a 1.5" lift and they looked small).
    I just went with 295/60/20 (34") on a 3.5" lift with 20x9 +20mm offset wheels. With that setup, I only had to trim the front liner and I still kept the front mudflaps. I could fit 35" tires, but I would have to use bumper shims to push the bumper out further.
    The wider you go with the wheel or the lower offset you run, the more trimming that you will need to do. Doing the cab mount chop is not a big deal. It is very common.
    checkout my build thread for more pics:
    https://www.tundras.com/threads/netmonkeys-build-thread-2-0.63758/
  12. May 17, 2020 at 9:51 AM
    nathanmck
    Nathan
    What are your tire specs? Like exact size because I think I want to keep my stock wheels. Also POST MORE PICS!!
  13. May 17, 2020 at 1:30 PM
    Jemz808
    Jemz808 New Member
    Maui, Hi
    2018 SR5 Offroad
    35x12.5r18 Nitto Trail Grappler M/T tires with 1.25 spidertrax wheel spacers
    ajaxv2000 likes this.
  14. May 17, 2020 at 2:08 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    35x11.5r20 Nitto Ridge Grapplers. No cutting required
    MTRock and Ely010606 like this.
  15. May 17, 2020 at 2:13 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Looks good, nice flares.
    Medic343[QUOTED] likes this.
  16. May 17, 2020 at 3:19 PM
    Jemz808
    Jemz808 New Member
    Maui, Hi
    2018 SR5 Offroad
    ajaxv2000, equin, tundra_20 and 2 others like this.
  17. May 18, 2020 at 6:41 PM
    nathanmck
    Nathan
    What 3/1 lift do you have, looking at a few different brands can’t seem to find one that’s particularly better.
  18. May 18, 2020 at 7:39 PM
    Jemz808
    Jemz808 New Member
    Maui, Hi
    2018 SR5 Offroad
    I have Rough Country on
  19. May 19, 2020 at 8:12 PM
    stangless40
    stangless40 New Member
    Alberta Canada
    17 Platinum
    lots
    35s all the way, if you don't mind spending the money to do it right.
    Junior 88, ajaxv2000 and equin like this.
  20. May 19, 2020 at 9:38 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    I’d stay w/33’s. Been there done that. 35’s slow you down to much. Just my opinion though.
    Tundyfundy and MTRock like this.
  21. May 19, 2020 at 10:23 PM
    TheBeast The Beach
    33's -> 35's -> 37"s -> ?? :D:p
    tundra_20, MTRock and Tundyfundy like this.
  22. May 21, 2020 at 11:38 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    35s and don’t look back.
    I had 295/70/18 on oem alloys and they looked good.
    went new shoes and got 18x9 methods +18 offset with 35” ridge grapplers
    had to do the BMC and adjustments to the inner fender plastics, no cutting but the heat gun molding method and new screw holes.
    Mfanatic22, tundra_20 and TheBeast like this.
  23. May 21, 2020 at 11:38 PM
    TheBeast The Beach
    :worthless:
    MTRock likes this.
  24. May 22, 2020 at 12:55 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Im in same predicament, I have a 3/2 and have bumper shims at the ready. My Fuels are -1. I dont want to cut or loose power.
  25. May 22, 2020 at 1:14 AM
    MTRock
    MTRock 1889
    Montana
    I did notice power loss from 285’s to 305’s.. not a lot, but Glad I didn’t get 35’s? FWIW the Ridge grapplers are impressive! But spendy!
  26. May 26, 2020 at 10:28 AM
    smalls_ADV78
    smalls_ADV78 New Member
    I have 3/2 lift; 285/65/20. I had to remove mud flaps and heat gun the front inner lining. All is well. But...….I wanna swap things up and go 18s with 35s. I'm trying to find out where I can get a cab mount chop around Charlotte NC?? Anyone?
  27. Oct 28, 2020 at 6:29 PM
    ajaxv2000
    ajaxv2000 New Member
    Hello!
    I was thinking the same setup.
    Did you have to chop or remove anything?
    Could you please send me a picture?
    Thanks.
  28. May 19, 2023 at 4:54 PM
    DallasTundra
    DallasTundra New Member
    2014 Tundra CrewMax SR5 4X4 5.7L Silver Sky
    2" MotoFab leveling Kit, 2Crave NX-5 wheels(5X150 +15 offset to fill in fender flares space), 275/60R20XL Nitto Terra Grappler G2 Tires, VLEDs Triton V3 Switchbacks, TRS Morimoto XB LED Fog Lights, CCI Chrome Grille, 2019 LED Headlights, Extang Solid Fold, Texas Edition, Leather, Nav, JBL, OEM Flares, Husky WeatherBeaters.
    I’m installing 3”/1” setup next week. Here is the difference tire size calculation shows between what I’m considering:
    275/60-20 33.0in
    285/65-20 34.6in
    Question is what kind of gas mileage is everyone getting with either tire? Also, if you guys have a toolbox in the bed and running either tire size is there a perceivable loss of power; especially with the 285/65/20’s?
  29. May 27, 2023 at 9:39 PM
    EddieBolt
    EddieBolt New Member
    David
    2020 CM SR5 4x4
    I was running 315/70/17s on my DC and got 13.6mpg or so. Mostly highway miles.
  30. May 27, 2023 at 9:48 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I vote 33. With 35s there a whole lot of other stuff you would need/want/should do like chopping stuff, regearing, speedometer correction, big gas mileage drop, extra stress on your truck components, will need to buy new rims, not to mention 35s are way heavier weight wise and on your wallet.
    If you want them then go for it. Or if your an offroader. I offroad on 33s no problem, my speedometer is dead nuts and my gas mileage didn't take much of a hit. I do agree that 35s and rims looks badass but to me it isn't worth an extra 5 grand.
    You could also do 295/70/18. Way cheaper and almost same size.
    Edit
    With 33 bfg ko2, stock sr5 steelies, 2 inch lift front and 2.5 inch rear, full armor, family of 4, winch, diamondback, molle, some offroad gear and baggage and a steel front bumper I still can get 17 or 18 mpg light highway cruise on trips and average 15 with my normal driving 75% highway. My city only is real bad though with the weight. Maybe 12 or 13.
