2wd off road?
Discussion in 'Trip Reports' started by sillydadztrksR4momz, Aug 31, 2020.
  1. Aug 31, 2020 at 10:50 AM
    sillydadztrksR4momz
    sillydadztrksR4momz [OP] New Member
    Has anyone takin their 2wd off road? I had an 06 4wd and I’m an avid upland bird game hunter/big game I don’t go off roading to off road I just go bc I need to to go hunting. Anyway I have used the 06 tundra many time to hunt and a lot of those times I’ve never even needed to use the 4wd (dry off road conditions) therefore I didn’t spend the extra money on my new tundra for the 4wd option bc for me the places I go the 2wd drive does great off road. These trucks are so dang strong they will surprise you. Anyone else use there’s off road with a 2wd???
    Darkness likes this.
  2. Aug 31, 2020 at 10:56 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    For things like fire roads and such you should be fine. I would avoid things like wet grass, deep puddles, or thick mud. The best upgrade you can get is a good set of tires, an all terrain would do fine. I won't say which one to get because you'll get an avalanche of favorites. Anything will probably beat the stock tires once you're in the dirt.
  3. Aug 31, 2020 at 11:07 AM
    Sunnier
    Sunny
    San Diego, CA
    Even the stock tires, aired down, do a great job. Nannies off, consistent skinny pedal. No hard stops in sand to avoid creating a pile in front of the tires. But yeah, no puddles too deep to see the bottom, no thick mud.
  4. Apr 27, 2021 at 4:39 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Not if stuck from a dead stop.
    I have been stuck in Campgrounds after the morning dew fell and needed 4wd to get moving.
    You might not need 4wd until you really do but then I bet you wish you had it.
    I do not plan to get another 2wd truck.
  5. Apr 27, 2021 at 5:34 AM
    TXTundra2722
    2015 Black Tundra
    A good posi rear does wonders, but yes, it is no 4wd. Keep a shovel and traction boards with you. Simple things like making sure someone knows where you are offroad and not deviating from that plan at all, (yes, even if you know a shortcut and is getting late) can keep you safe and friends/ loved ones at ease.
    Sunnier and Rex Kramer like this.
  6. Apr 27, 2021 at 5:51 AM
    ezdog
    ezdog New Member
    Gateway To The West
    No joke to me and with a trailer attached spinning from a dead stop is pretty common.
  7. May 20, 2021 at 1:30 PM
    TRD_FanMan
    TRD_FanMan New Member
    2021 Tundra SR5 4x4 OffRoad
    When it's dry and traversing standard grade off-road trails, I never use 4wd.. just don't need it. As soon as I hit water/mud/steep stuff, 4-high is fine, and very rarely do I ever need 4-low... but that's me personally, as I'm sure MANY of you out there do much more true off-roading than I do. But yeah, just use what you need.
  8. May 20, 2021 at 2:50 PM
    MRQZTNDR93
    MRQZTNDR93 New Member
    San Diego CA
    2022 TUNDRA SR5 TRD OFF ROAD
    HI IM 2WD AS WELL AND SO FAR SO GOOD IN DIRT, SNOW AND SOF SAND
    REALLY YOU NEED GOOD TIRES AIR DOWN AND SOME EXPERIENCE
    YOUR SOLID :hattip:
  9. May 29, 2021 at 3:13 PM
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    Some good aired down tires, shovel, boards, and a winch if you wanna go the extra mile.
