2wd 4wd acceleration and 488 gears
Discussion in 'Performance and Tuning' started by yoneytan, Jul 24, 2018.
  1. Jul 27, 2019 at 10:38 PM
    #61
    Tundra_power
    Tundra_power New Member
    Nick
    I would go to 5.29 for 35" because the weight of the tire.
  2. Jul 28, 2019 at 9:04 AM
    #62
    Toytun247
    Toytun247 New Member
    kyle
    2018 Toyota Tundra 4x4 TRD Sport
    Camburg UCA, Icon Stage 2, Method NV, BFG Mud Terrain km3, Nitro 5.29, MBRP Exhaust, S&B Cold air Intake, RCI Engine & Trans Skid, OEM Audio Plus,
    i thought about it but i think 4.88 brings it close to stock i just don't want the truck reving out on the freeway. if i got 4.56 it would actually be a little closer to stock but 4.88 will give it a little more power i think... do you have 5.29?
  3. Jul 28, 2019 at 10:31 AM
    #63
    Tundra_power
    Nick
    Right now they just came out and lots of people who run 35" go with 5.29. Because why spend all that money to go back to stock. You can get alttile more off the line and probably be better on gas because to go completely back to stock and counting the weight of the tires it would be around 5.13 gear not 4.88. Because people dont understand how gearing works. With our vvit 5.7 steeper gears like 4.88 and 5.29 gains mpg on hwy and alot more on city even if you rev higher in hwy than stock. You will get better mpg because our trucks adapt to anything. So 35" go with 5.29 you will not regret it.
  4. Jul 28, 2019 at 10:49 AM
    #64
    Toytun247
    kyle
    That does make sense i'll have to look more into it. if I'm gonna spend the money might as well get something thats better then stock. One thing i've noticed for sure is that even having the stock 4.30 with 35s my RPMs are lower on the highway but my gas milage is a lot worse. Ive also noticed if i drive my truck a little harder i get better gas milage as weird as that sounds. but ill definitely look into a 5.29. Thanks for all your help!
  5. Jul 28, 2019 at 11:09 AM
    #65
    Tundra_power
    Nick
    5.29 gears with 35" tires equals better gas mileage, better for your transmission and alot more fun to drive talk with dirty deeds.
  6. May 29, 2020 at 6:48 PM
    #66
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    So read the thread is it safe to say if I want bigger tires I should re gear? I’m a 2016 SR5 2WD on 35’s 5” Zone Lift
  7. May 29, 2020 at 6:54 PM
    #67
    TXTundra2722
    2015 Black Tundra
    You'll get several different opinions on this topic, no matter who you ask. 35s to me is that in between size that you can either stay stock or regear. I'm on 37s and I have 5.29s and Auburn pro in the garage just waiting to find an installer now..... best of luck no matter what you decide!
    KELZ84[QUOTED] likes this.
  8. May 29, 2020 at 7:01 PM
    #68
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    Thank you just trying to do research till probably won’t happen for another 3 years or so. I just lifted & got tires. So trying to understand and learn what my options could or would be.
  9. May 29, 2020 at 7:03 PM
    #69
    Mnorris1206
    08 tundra
    I'm stock gears 6" lift and 22x12s on 35s I still pull my camper no problem. Recent bought a bullydog tuner for pulling others here say o should feel a big difference in power while towing. Idk i do think re gearing is still in my future as well.
