2uzfe motor compatibility
Discussion in '1st Gen Tundras (2000-2006)' started by Ayerish, Mar 20, 2017.
  1. Mar 20, 2017 at 3:36 PM
    Ayerish
    Ayerish [OP] New Member
    I have a 2000 tundra. I have to replace the engine. I was wondering if anyone knows if any other toyota engines are compatible. For example, if a 02 Tundra engine would fit, would an 02 Sequoia?
  2. Mar 20, 2017 at 3:41 PM
    Mike Tread lightly.
    south carolina
    If my memory is correct you can go-to 03 after that Toyota put more on the engine emission wise which more wiring is needed. Plus they started vvti to the engine in 2004 I believe so that's a no go unless you pull the harness and replace it.
    Side note what's wrong with the engine you have now?
  3. Mar 20, 2017 at 3:51 PM
    Ayerish
    It's got 287k and leaking and burning oil like crazy. Then it seized up on me the other day.
  4. Mar 20, 2017 at 4:25 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Where are you? I have a friend with a 2000 Tundra parts truck, 240 km if memory serves right, good runner. Truck is rusty and the tranny went.
  5. Mar 20, 2017 at 4:26 PM
    Ayerish
    I'm down in Florida
  6. Mar 20, 2017 at 4:43 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Canada borders on Florida, right?
    joonbug, landphil and joem1cha3l like this.
  7. Mar 20, 2017 at 4:51 PM
    Ayerish
    Haha yep.
    gosolo likes this.
  8. Mar 20, 2017 at 4:53 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Probably not your best bet then.
  9. Mar 20, 2017 at 6:53 PM
    Mike Tread lightly.
    south carolina
    If you plan on keeping the truck buy a remanufactured engine.
  10. Mar 29, 2017 at 6:30 AM
    Clint
    Clint New Member
    2010 Tundra 4wd 5.7L
    N-fab steps
    2000-2002 are the same. 2003-2004 same motor but drive by wire. 2005-2006 vvti
