2UZ-FE Power loss at 4000rpm
Discussion in 'Other Toyota Vehicles' started by Krazie Sj, Mar 10, 2016.
  1. Mar 10, 2016 at 7:27 AM
    Krazie Sj
    Krazie Sj [OP] Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 Mall Crawler Extordinare
    All Pro Long Travel with Walker Evan Coil Overs, All Pro Expedition Leaves with Walker Evan Resi Shocks, All Pro IFS, transmission and E-Locker skid plates/guards, ARB Bumper with Kragen LED flood lights, 10,000lb SuperWinch, All Pro Rear Bumper, All Pro Sliders, Custom RTT Rack with Roto Pack, ARB Simpson RTT, Bed Tray. 285x75R16 Mickey Thompson MTZs and 285x75R16 Yokohama Geolander it g072. Airaid Short ram intake, Intake manifold spacer, Borla Cat back Exhaust.
    Don't have a Tundra, but I do have a 2002 Sequioa with the same engine. Posted here because I figured I'd get more hits.
    Currently have an issue where it's gutless going up hill and at 4000 if you stomp on it. Goes fine from a stop and isn't suffering massive MPG loss that I can tell (16-17 in the city) but its annoying regardless.
    Currently had a Cat delete to see if that was the issue. It was not. Maybe woke the engine up a little but didn't solve the issue.
    Also replaced the PCV and gasket too.
    It does have the typical exhaust manifold leak but it goes away after the engine warms up so I don't think that's the issue.
    I'm rather loath to throw money at parts that may or may not fix it. Bought a fuel filter but haven't put it on as the filter is cold welded to the pipe right now. So my only option is to hacksaw the filter off and use a nut buster to remove it. However you can understand my hesitation to do that in case it doesn't work.
    My only other idea's are the injectors are dirty (No engine codes for knocking, pinging or misfiring), fuel filter is clogged, fuel sender or pump is fuckered.
  2. Mar 10, 2016 at 1:27 PM
    Mike Tread lightly.
    south carolina
    When was it tuned up last? spark plugs and airfilter?
    Also try a bottle of injector cleaner first if you think its injectors. (rare)
    If that checks out ok then to fuel filter(plugged) and fuel rail pressure. At 4000 rpm the fuel pump might be showing some weakness as it can't keep up the correct fuel pressure at the injectors but the fuel filter must check out first.
    IF the filter is cold welded use penetrating oil on the nuts/threads for a few days and use a flare wrench to get it off.
    only other thing i can think of is timing belt or the timing belt tensioner is starting to get alittle loose. When was the timing belt replace?
    Krazie Sj[OP] likes this.
  3. Mar 10, 2016 at 3:14 PM
  4. Mar 10, 2016 at 9:46 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    @LOTSOFTOYS
    Timing belt replaced thus December.
    Air filter is brand new. Cleaned the throttle body out, spark plugs see below (first thing I changed out.)
    Sewfoamed twice now through the PCV. Still tons of white smoke the second time. Ran a bottle of injector cleaner and cat cleaner through.
  5. Mar 11, 2016 at 8:47 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    If u run it in park and wood it, does it hit red line and fuel cut? Or does is Tap out at 4k even in park?
    Check engine light on? Maybe the timing belt was installed wrong or maybe the tensioner is wasted and it jumped teeth? Early 2uz's have been known for weak tensioners
  6. Mar 11, 2016 at 8:50 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Btw @Sean266 his tag of my name^^^^ never notified me....
  7. Mar 11, 2016 at 10:32 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    I'll see if I can bounce it off the Rev limiter tomorrow.
    CEL is on for P0430/420 codes. Cats have been deleted. Other wise nothing else.
    Would the timing being off not nuke the engine? Any tips for seeing if the tensioner is weak?
  8. Mar 11, 2016 at 10:33 PM
    @Krazie Sj did you edit your post at all? If there's an edit, tags won't function.
  9. Mar 11, 2016 at 10:38 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    Negative ghost rider.
    @LOTSOFTOYS
    Trying again for shitsngiggles
  10. Mar 12, 2016 at 12:39 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just curious Jace, which one is it supposed to do?
  11. Mar 12, 2016 at 9:44 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    It should rev all the way to revlimiter. You'll know it if it does haha. If it doesn't, my bet would be timing belt, but you'd think you would get a code....
  12. Mar 12, 2016 at 9:45 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    This one worked btw. Not sure why the first one did not
  13. Mar 13, 2016 at 6:18 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    Bounces off of the rev limiter just fine. Went to 5500 rpm and hung there no problems. Didn't sound like it was misfiring, pinging or anything. I'll also check and possibly change the transmission fluid. Engine oil looked decent and was to the correct line on the dipstick.
  14. Mar 13, 2016 at 8:36 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    and it gets to rev limiter quickly, in a normal amount of time once u wood it? Sound slide ur problem is not so much engine related....
  15. Mar 13, 2016 at 10:59 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    Yup. Hit the gas and it flies to the red line easy. Just no ooommph.
  16. Mar 14, 2016 at 9:39 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Gotta have something to do with the trans then I'd imagine.
  17. Mar 14, 2016 at 9:55 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    Not thinking Fuel Filter or Pump hey?
  18. Mar 15, 2016 at 12:25 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Not particularly... did u say the c/e light was on?
  19. Mar 15, 2016 at 2:58 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    Yes. But only for the deleted cats.
  20. Mar 15, 2016 at 3:27 PM
    Mike Tread lightly.
    south carolina
    unless the ecm is having a hard time with deleted cats. Some Ecms do, do to how it was programmed. (last resort but not likely) Ecms dont like the cats gone, why you use a o2 simulator on board.
    Only other thing i can think of is a torque converter stalling out or locking up, if the transmission checks out ok. Thats the only thing can keep a engine from going up since it hits the redline in park. Or the transmisson computer has a code/fault keeping the engine at bay ( low rpms) more like a limp mode.
  21. Mar 15, 2016 at 4:28 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    It'll rev fine on the highway, it just has no power. Transmission isn't throwing any codes or overheating. However that was my thought too. Torque converter isn't locking up properly to put the power to the ground. Would the tranny show codes on the OBDII or not?
    A̶n̶y̶ ̶t̶i̶p̶s̶ ̶o̶n̶ ̶w̶h̶e̶r̶e̶ ̶t̶o̶ ̶f̶i̶n̶d̶ ̶O̶2̶ ̶s̶i̶m̶u̶l̶a̶t̶o̶r̶s̶?̶ (I can honestly say I'm positive that's not the issue as the engine is only showing -2/-3 LTFT on both banks.
    Found them.
  22. Mar 15, 2016 at 6:33 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yes transmission codes should show up on obd2. Using a ultra gauge?
    Can u feel the truck shift through all gears? Does the converter lock up?
  23. Mar 15, 2016 at 6:53 PM
    Mike Tread lightly.
    south carolina
    Negative ltft means your running rich and the ecm command is to lean out command.
    Ok one more thing and I will pull my books out. When was the transmission service last? If your filter is plugged your not getting the proper hydraulic pressure.
  24. Mar 16, 2016 at 10:40 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    No Transmission codes. I'm using an actual OBDII reader. Shifts through all gears fine. Converter locks up. I've used both the Over Drive off and the gear selector to roll through the RPM range. Engine still feels as sluggish. One thing it does is feel like it hangs gears on hard acceleration, but I feel like that's normal as the engine is desperately trying to get me to speed but can't.
    No clue. I was thinking of doing a flush on it. For the filter, is it a simple job of dropping the pan and switching it out?
  25. Mar 16, 2016 at 11:09 AM
    garnaz
    garnaz New Member
    Check maf.
    Dirty?
    Dropping out?
    Have seen them cause problems and not throw light.
    Mostly domestic worth a look.
  26. Mar 16, 2016 at 11:42 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    Maf is clean as a whistle and all the wires are intact. Additionally no MAF codes thrown.
  27. Mar 16, 2016 at 1:27 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    This is weird.... my next step would be to hook a scan tool to it and watch live data... maf readings, a/f sensors etc....
  28. Mar 16, 2016 at 7:36 PM
    Mike Tread lightly.
    south carolina
    2x in this case.
    Could be a drop out somewhere.
  29. Mar 17, 2016 at 4:27 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    Crap. My OBDII doesn't do live data.
    The one coming from Amazon does now though...
    Other thing I was thinking. Could the traction control be bugger if it up?
    I'm going to try it tomorrow, putting it in full Time 4wd, turning off VSC and seeing if that does anything.
  30. Mar 17, 2016 at 4:57 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Possibly...you'd think you'd see a light tho
