2nd Gen Toyota Sequoia OEM Parts Thread
Discussion in 'Sequoia Builds' started by SprinterAE86, Sep 22, 2020.
  1. Sep 22, 2020 at 2:20 AM
    SprinterAE86
    SprinterAE86 [OP] New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    I guess we need to start a parts# tread for the Sequoia's. This are the parts I inquired or purchased for my 2012 Platinum. Some of this part# are based on my VIN and not generic across all Sequoia Trim Levels.
    Tundra/Sequoia interchangeable parts tread https://www.tundras.com/threads/ultimate-oem-toyota-parts-thread.10707/
    Grill molding (Bulge)
    53111-0C240-C0 Black
    53111-0C240-B1 MGM
    53111-0C240-A0 White
    Pro Grill
    PT363-0C200-BL Black
    PT363-0C200-GY MGM
    PT363-0C200=A0 White
    Headlight extension (Comes un-painted)
    53931-0C904 Right Front
    53932-0C904 Left Front
    Contact Me-So Custom for brackets if you want to retain the washer.
    18+ LED non-Platinum Headlight (Black)
    81110-0C200 (RF)
    81150-0C160 (LF)
    18+ LED Platinum Headlight (Chrome)
    81110-0c190 (R)
    81150-0c150 (L)
    Contact @xrunnerdude67 for the proper parch harness
    18+ smoke tail lights
    P/Ns (from L to R in pics):
    81560-0C110
    81590-0C040
    81580-0C050
    81550-0C110
    Brake Rotor
    43512-0C020 Front
    Pads
    04465-0C020 Front
    TRD Rear Sway bar
    PTR62-0C181
    AVS Socks Platinum based on VIN#
    48510-34040
    48530-34053
    90170-12009
    Licence Molding
    76801-0C040-C1
    Black Overlay Emblems
    PT948-0C200-02
    TRD Pro Fox (rear)
    Fender Flares
    Bumper Skid Guard (not TRD)
    Please contribute with the part numbers so we don't have to keep on bothering Roman. But @Roman if you have time to contribute, please do so.
    Thanks!
  2. Sep 22, 2020 at 2:59 AM
    SprinterAE86
    Ian
    Non-OEM/After Market parts
    LED puddle lights
    VLEDS
    https://www.vleds.com/shop-products/puddle-lights/toyota-mazda-puddle-light.html
    Amazon
    https://www.amazon.com/dp/B07L5GF1RL
    Running Boards
    APS Off-Road 6.5in Side Armor Aluminum Running Boards Custom Fit DC (The mounting hardware and hole placement on the brackets are very similar to the OEM running boards and the length is just shy of an inch. I think as long as you can slide the bracket/running board froward and back, you can make it work.)
    https://smile.amazon.com/gp/product/B079P6PP8J/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    2018+ LED Headlight patch Harness @xrunnerdude67
    https://www.tundras.com/threads/2018-sequoia-led-headlight-harness-for-2nd-gen-tundras.18742/
    Washer Bracket
    https://mesocustoms.com/ email Stew@ to place an order.
    Suspension
    https://www.dobinsonsdirect.com/pag...oia~yr_2008-2020-complete-suspension-lift-kit
    https://www.dobinsonsdirect.com/pag...yota~md_sequoia~yr_2008-2020-suspension-parts
    Bilstein 33-187280 5100 Series Rear Toyota Sequoia 08+
    Bilstein 24-232173 5100 Series Front height adjustable Tundra 08+
    Bilstein 5100 front/rear
    Revtek
    Fog Lights
    Morimoto-a-like (Reverse Polarity, just rotate plug to non-locking position and zip-tie for security)
    Remote Start
    12volt Solutions
    @james@tech12volts Tech12Volts
    MS22, e30cabrio, Mountun Goat and 4 others like this.
  3. Sep 22, 2020 at 9:55 AM
    Bama
    Bama Member
    2016 MGM Tundra 2015 MGM Sequoia 2014 LX
    Excellent. Thanks for starting this!
  4. Sep 23, 2020 at 7:48 AM
    Adamdsgn
    Adamdsgn New Member
    2018 Toyota Sequoia
    @SprinterAE86 Did you install those running boards on your Sequoia? Been thinking about removing ours all together and getting a more off-roadish replacement. Any chance you can share a picture of what they look like installed?
  5. Sep 29, 2020 at 6:28 AM
    War Machine
    War Machine SSEM # 5 3MW
    Buyer beware on these. I installed them in June of 2019. I don’t know when it happened, but I noticed a few weeks ago that the lens had fallen out of one of them. When I took them out to replace them the plastic was brittle as hell. Definitely a cheap option and were still functioning, but not a long term solution.
    I replaced them with Vled puddle lights which ran me 60 bucks. Hopefully they hold up well.
  6. Sep 30, 2020 at 2:58 AM
    SprinterAE86
    Ian
    I guess I have to upgrade.
    War Machine[QUOTED] likes this.
  7. Sep 30, 2020 at 7:59 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    War Machine and SprinterAE86[OP] like this.
  8. Sep 30, 2020 at 8:19 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    81110-0c190 (R)
    81150-0c150 (L)
  9. Oct 1, 2020 at 9:31 AM
    yeeyo
    yeeyo New Member
    Rodrigo
    11' Limited Sequoia
    OVtune
    Our Sequoia didn't come with puddle lights, but i ran VLED puddles earlier this year. $60 was definitely worth it.
  10. Nov 5, 2020 at 6:09 AM
    NFARIDI
    NFARIDI New Member
    Is it easy to add on puddle lights if your's didn't come with them stock?
  11. Nov 9, 2020 at 9:45 AM
    yeeyo
    yeeyo New Member
    Rodrigo
    11' Limited Sequoia
    OVtune
    I'd say it's not difficult, but it's a little complicated hooking up the correct wires. I did all the install myself and then took it to a buddy to tap into the correct circuit.
    Here's the link for the install, it's pretty straight forward, just take your time.
    https://www.tundras.com/threads/diy-tow-mirror-puddle-lights.42359/
    NFARIDI[QUOTED] likes this.
  12. Nov 9, 2020 at 8:31 PM
    NFARIDI
    NFARIDI New Member
    thanks for sharing!
  13. Nov 10, 2020 at 7:50 AM
    CJ17
    CJ17 New Member
    2017 Sequoia
    Hi all,
    New to the forum. Just purchased a 2017 Sequoia Platinum. I would really like to get rid of all the chrome. Are the parts listed at the top of the thread 100% swappable (unbolt old bolt in new) with the sequoia OEM parts? I am specifically looking upgrade my grill.
    53111-0C240-B1 MGM
    Pro Grill
    PT363-0C200-GY MGM
  14. Nov 10, 2020 at 11:38 AM
    Adamdsgn
    Adamdsgn New Member
    2018 Toyota Sequoia
    I have a 2018 Platinum and have ALMOST gotten rid of everything black. Looks like you have the grill part numbers. I have the numbers for the letter/emblem overlay kit, rear hatch garnish, Pro Fogs with bezels, mirror caps, door handles, and lower grill if you need them.
    I've swapped out everything except the lower grill at this point. Ordered the Pro Fogs with bezels and waiting for them to come in currently. Once I get those installed I'm going to figure out a way to slide the lower grill past the wife before christmas (fingers crossed)!
    SprinterAE86[OP] likes this.
  15. Nov 16, 2020 at 4:23 AM
    SprinterAE86
    Ian
    I overlooked your post from before. I believe the 2nd/3rd gen Tundra DC running board mounting points are very close or even exact based on my visual comparison.
    I have not installed my step bars yet. The current weather is not favorable to work outside and there's no garage where I currently staying.
  16. Nov 16, 2020 at 4:26 AM
    SprinterAE86
    Ian
    Yes. Assemble the grill and grill molding together. Secure with a 20mm metal screw and mount the whole thing as one.
  17. Dec 31, 2020 at 9:59 AM
    S. Equoia
    S. Equoia New Member
    Ontario, Canada
    2015 Sequoia
    Great thread!
    I’ve only just started trying to gather parts and things seem to be tricky up in Ontario. We have a 2015 Limited. Black badges and the TRD pro grille parts are what I’m currently after.
    I have the part number, been looking at a few local Toyota dealers and they all seem to scratch their head or say its not available for purchase.
    Can you recommend a parts supplier more local to Canada, Ontario specifically? I looked into sparks but is there a supplier on this side of the border? I’m 100% good with ordering through sparks but they said there is a bit or a lineup for the grille. Thanks.
  18. Dec 31, 2020 at 6:54 PM
    SprinterAE86
    Ian
    When I called Charlottetown Toyota in PE, to get pricing one the parts, they said that they can get it, but have to pay parcel and import fees since it's coming from the states. Sparks Toyota does ship to Canada is what I understand, but shipping is going to be a pain. Try doing ebay or Amazon US that ships to Canada.
    I manage to get most of the parts I need before moving to PE, but I should have gotten more parts, since the availability is still limited here in Canada.
    https://www.ebay.ca/itm/TOYOTA-4RUN...-OVERLAY-00016-35072-05-GENUINE-/153634812752
    https://www.ebay.ca/itm/2pc-Fits-To...662255?hash=item3b38e5ea2f:g:vNsAAOSwuwFdemEm
    https://www.ebay.ca/itm/Genuine-Toy...508191&hash=item2ad82c5e73:g:SocAAOSwHwldue9i
    I hope this helps.
    S. Equoia[QUOTED] likes this.
  19. Dec 31, 2020 at 7:22 PM
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    It really does, thanks! I appreciate you sharing your similar struggles. I’ve been trying local and I’ve seen the ebay ad, that one specifically, that’s an actual dealer who I guess has it in stock ready to ship? I don’t use ebay but it seems to be the best option.
    I like those Limited emblems. It’d be nice to do a full swap of all the emblems. Can’t wait to de-chrome this beast!
    Thanks again,
  20. Dec 31, 2020 at 8:04 PM
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    I’d be interested in seeing a sport grille on a 08-17, ultimately the new nightshade edition grille. I think I like the trd pro overall but its hard to say without seeing it.
  21. Jan 1, 2021 at 4:57 AM
    SprinterAE86
    Ian
    Sport grill works too.
    Have you tried posting your question to the Canada region threads? I just moved to Canada last October. I'm still learning where and how to get things.
    https://www.tundras.com/forums/canada.32/
    S. Equoia likes this.
  22. Jan 1, 2021 at 8:07 AM
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    I haven't yet but good info in there!
    Wonder if it make more sense to order direct from Elmhurst. Their site lets you search up everything, had both grille items in the cart. $700, I think that covers shipping and duty but still unsure. Might have to give them a shout. They are in Chicago which is a bit closer to home.
  23. Jan 1, 2021 at 9:24 AM
    SprinterAE86
    Ian
    This is what I paid last July.
    Part Number Part Name Price Quantity Total
    PT363-0C200-GY Grille Trd Sequoia 1 $342.73 1 $342.73
    53111-0C240-B1 Molding $57.04 1 $57.04
    Subtotal: $399.77
    Estimated Shipping to 32003 via Standard Shipping: $62.08
    Discount: -$12.42
    Total: $449.43
  24. Jan 1, 2021 at 11:08 AM
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    Wow!
    That’s from Elmhurst Toyota, I’m hoping after conversion and duty and everything else. I would assume shipping would be the same as sparks.
  25. Apr 22, 2021 at 4:07 PM
    blackout12
    blackout12 New Member
    First off I wanted to thanks all of you for putting together this list of parts to bring our rigs back to life. I own a 2012 Black Platinum Sequoia and in the last month I have updated the grill, headlights, fog lights, mirror covers, door handles, and rear license molding trim. I'm basically removing all chrome trim pieces from it.
    I wanted to share the mirror covers and handle part numbers on this thread. Color is 218 Attitude/Midnight Black.
    Part Number Part Name Quantity
    87945-0C040-C1 Outer Cover 1
    87915-0C060-C1 Outer Cover 1
    69210-0C030-C1 Handle, Outside 4
    69217-0C060-C1 Handle Cover 3
    69217-0C050-C1 Handle Cover 1
    Next on my list is to plasti dip with matte black all chrome emblems. Not sure yet about the wheels/tires. Very happy with the outcome so far after 7 years of ownership.
  26. Apr 22, 2021 at 5:55 PM
    NFARIDI
    NFARIDI New Member
    front looks amazing! good work!
  27. May 18, 2021 at 3:02 AM
    TeamHall
    TeamHall New Member
    Sam
    Cincinnati, OH
    2016 Toyota Sequoia SR5 PRO
    Blacked out grill and wheels 2nd row bench seat middle seat removed for captains chairs Remote start
    Gotta go black on the wheels!
  28. May 31, 2021 at 9:50 PM
    YBUYAV8
    YBUYAV8 New Member
    Just purchased a 2021 Sequoia TRD Sport for my wife, she loves it. So far I have added the following:
    TRD PRO Grill
    3 inch lift
    Nitto Grapplers
    Black Rhino Abrams
    Pulled the chrome off the front bumper and professionally painted in semi gloss
    Tint
    Weather tech mats
    Looking for a good aftermarket set of rock sliders, anybody have any suggestions?
    MS22, Iron1, Pnoy_toy and 3 others like this.
  29. Jun 1, 2021 at 2:08 AM
    SprinterAE86
    Ian
    The Tundra DC belly pan are the same as the Sequoia and the steps are the same length too based on my observation. If you find something in a Double Cab you like, it will fit just right with the Sequoia.
  30. Jun 1, 2021 at 10:31 AM
    Adamdsgn
    Adamdsgn New Member
    2018 Toyota Sequoia
    If you buy aftermarket sliders would you be interested in selling those stock black running boards you currently have? Think about and shoot me a PM and we discuss cost, shipping, etc.
