2nd Gen RESZ fabrication group buy/discount thread! its live!
Discussion in '2nd Gen Tundras (2007-2013)' started by Jwood562, Oct 23, 2020.
  1. Mar 30, 2021 at 3:36 PM
    #361
    DVCNick
    DVCNick New Member
    2011 5.7 4x4 Double Cab
    If anyone knows of an actual good tool or drill bit for widening these holes I'd be all ears... I just smoked my old dremel, and most of one of the grinding bits it came with. And my drill(s) look like they will work eventually grinding but rpm is pretty slow to make much quick progress.
    Maybe a drill bit big enough to go straight through?
  2. Mar 30, 2021 at 3:51 PM
    #362
    nb_nielsen
    nb_nielsen New Member
    2012 Tundra double cab
    I used a drill bit in my Dewalt and it did the trick. Didn't feel too good on my wrist when it would catch but it did the trick. Did you see 2 spacers on your pallet? There should be 2 like 1/4 inch thick spacers that mount right to the frame rails. With those on I had no clearance issues
    DVCNick[QUOTED] likes this.
  3. Mar 30, 2021 at 3:53 PM
    #363
    DVCNick
    DVCNick New Member
  4. Mar 30, 2021 at 4:03 PM
    #364
    nb_nielsen
    My drill bit worked great, honestly it was maybe a 10 minute job tops with a drill bit. Just slightly pushing pressure onto the bumper. Just when the drill catches, it will put a hurting on your wrist lol
  5. Mar 30, 2021 at 11:08 PM
    #365
    Jwood562
    Jwood562 [OP] New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    I used a die grinder and grabbed these from harbor freight a carbide bit would be the best/fastest tool.
    hopefully the spacers will help you more than me! Good luck
    DVCNick likes this.
  6. Mar 31, 2021 at 8:24 AM
    #366
    DVCNick
    DVCNick New Member
    Unfortunately we have rain here and my garage is full right now, however, one thing to note.... the spacer plates got rained on overnight and had a good bit of surface rust this morning. I don't know if they are supposed to be stainless or not, and I don't know how much it will help, but I'm going to spray them with some rust preventative before final assembly.
    The drill bit was doing better than I thought it would, but also going to get a small grinding wheel bit.
    nb_nielsen likes this.
  7. Mar 31, 2021 at 4:55 PM
    #367
    DVCNick
    DVCNick New Member
    Well it's on. There's a little bit more of a gap on the passenger side but not sure how to fix that without further egging out the holes and pretty sure I don't care nearly enough to do that at this point. Just going to roll with it for now and see how it goes.
  8. Mar 31, 2021 at 10:21 PM
    #368
    Jwood562
    2013 Tundra 4x4
    other than opening the holes, any clearance issues?
  9. Apr 1, 2021 at 5:09 AM
    #369
    DVCNick
    DVCNick New Member
    Actually after reviewing your pictures again, it is at least touching that AC line, and I need to get a better look at the other cooler thing today with better light.
    It is flat up against the spacers, but still, if it actually bumps anything it is going to transfer energy straight into that ac line. So, looks like I'll take it back off and at least grind off some clearance for that spot...
  10. Apr 1, 2021 at 12:44 PM
    #370
    DVCNick
    DVCNick New Member
    So I took it off, cut out a little slot for the AC line, and took out the passenger side support bolt for the cooler coil. It think it is just touching that coil and it appears to have a little flexibility with that bolt removed so hopefully that will prevent any damage.
    The slightly bigger gap is still there on the passenger side.
    I've read about "Tundra lean"... any way that could be responsible here?
    Like I said it's a 10 year old pickup and I don't really care all that much, but if it is easy to eliminate I would. Right now I can't tell whether it is the bumper or something else that is slightly off.
    Hopefully I'll have time to work on the lights soon.
  11. Apr 1, 2021 at 12:48 PM
    #371
    BigSkyTaco
    BigSkyTaco Successfully Social Distancing since 1998
    Aaron
    W. Glacier, MT
    2011 White DC Tundra TRD
    Taken from @Jwood562 pics. I would lossen all nuts, slightly jack up the passenger side...tighten nuts and see if that helps. @DVCNick
    TheBeast likes this.
  12. Apr 1, 2021 at 12:50 PM
    #372
    DVCNick
    DVCNick New Member
    Good point, I tried just lifting it by hand but a jack would probably be better...
  13. Apr 1, 2021 at 2:50 PM
    #373
    BigSkyTaco
    Aaron
    W. Glacier, MT
    Any luck on straighten it up a bit?
    Jwood562[OP] likes this.
  14. Apr 2, 2021 at 11:57 AM
    #374
    DVCNick
    DVCNick New Member
    I probably won't have time to mess with it until at least tomorrow afternoon, and possibly next week... Got work and family stuff with Easter this weekend.
  15. Apr 3, 2021 at 9:33 PM
    #375
    Jwood562
    2013 Tundra 4x4
    Keeping this thread alive and tracking orders.
    the first three on the list received their bumpers. We are awaiting on the last three, but I think @trevorstuart24 cancelled his order.
    4. @BigSkyTaco #19399
    5. @TobyCPA #19531
    6. @trevorstuart24 #19576
    TobyCPA and nb_nielsen like this.
  16. Apr 3, 2021 at 10:41 PM
    #376
    ajdeez
    ajdeez New Member
    albert
    I expect mine to arrive in late April, any luck with contacting RESZ with correcting these fitment issues? I might still have time to advise them if they aren't already following this thread.
  17. Apr 3, 2021 at 10:49 PM
    #377
    trevorstuart24
    trevorstuart24 New Member
    they were aware before they shipped out the second set. that was mainly why i cancelled my order.
  18. Apr 3, 2021 at 10:50 PM
    ajdeez
    ajdeez New Member
    albert
    Ouch...they knew.
  19. Apr 7, 2021 at 6:37 PM
    #379
    BigSkyTaco
    Aaron
    W. Glacier, MT
    Talked to Resz Fab this week. My bumper should be heading to powder coating the end of next week and then being shipped out afterwards. They also confirmed they are addressing the issues and lowering the tabs for the S2s and opening up the mounting bolts more for the frame.
    Hoping to have it mounted by the beginning of May!
    Jwood562[OP] and nb_nielsen like this.
  20. Apr 7, 2021 at 6:42 PM
    #380
    ajdeez
    ajdeez New Member
    albert
    :fingerscrossed:
    BigSkyTaco likes this.
  21. Apr 14, 2021 at 8:14 AM
    #381
    DVCNick
    DVCNick New Member
    Ok, so I'm back at it, on the lights this time... I don't know what I did but neither side appears to have any voltage on it now.
    Before I took it apart the factory fog lights worked.
    Prior to installation I checked the BD lights just hooked up to a battery with the supplied wiring harness and they worked.
    So I guess I've blown this fuse? Not sure how that would have happened. Volt meter shows zero volts on either side.
    Both the old factory connector and the BD connecter were clearly marked so I know I've got + to + and - to -...
    Which fuse is it I need to look at?
    I'm still planning to try to get the bumper straighter at some point but haven't messed with that yet.
    Thanks
  22. Apr 14, 2021 at 8:22 AM
    #382
    DVCNick
    DVCNick New Member
  23. Apr 14, 2021 at 8:26 AM
    #383
    Jwood562
    2013 Tundra 4x4
    yeah that’s the one.
    I had a funky problem with mine too. But it was only the passenger. Kept blowing it. Was really weird. Had nothing wrong wiring wise.
    just ended up using the Baja harness and tap the passenger side with the driver side and called it a day
  24. Apr 14, 2021 at 8:35 AM
    #384
    DVCNick
    DVCNick New Member
    Well I don't think I ever turned the switch on between the time I took it apart till now so I'm really not sure how that would have happened.... If you had voltage on one side but not the other are they on separate fuses? I don't see how that's possible either if they're on the same circuit.
  25. Apr 14, 2021 at 9:07 AM
    #385
    DVCNick
    DVCNick New Member
    And, it just instantly popped again. Greeeaaaattttt...
  26. Apr 15, 2021 at 12:01 PM
    #386
    BigSkyTaco
    Aaron
    W. Glacier, MT
    Seems kinds weird since the LEDs should be drawing less power then the stock bulbs. Be kinda of pain having to run a relay just for the fogs.
  27. Apr 16, 2021 at 2:06 PM
    #387
    DVCNick
    DVCNick New Member
    Yeah I don't know. Current situation:
    Both lights unplugged and flip the switch on: Fuse doesn't pop.
    As soon as the connector completes a circuit to EITHER light (and I've tested both independently) the fuse pops.
    So I guess there is a short somewhere else in the wiring that must have happened when I was installing the bumper? I was careful to remove both bulbs before the bumper came off and the wire leads were never pulled/etc.
    So I don't know. Should probably start another thread in the appropriate forum. I guess it is a good thing they threw in this extra wiring harness and power connections.
  28. Apr 30, 2021 at 8:42 PM
    #388
    TobyCPA
    TobyCPA New Member
    Hope everyone’s been safe.
    Quick question for ya @BigSkyTaco. Did you ever get a shipping notice for your bumper? I’ve been pretty patient, but it’s getting ridiculous at this point lol. Still have to drop it off for powder coating too if I ever receive it.
  29. Apr 30, 2021 at 8:49 PM
    #389
    nb_nielsen
    Still never got a response about our extra 5% either but they seem to repost my photos on Instagram when I tag them...
    TobyCPA[QUOTED] likes this.
  30. Apr 30, 2021 at 9:08 PM
    #390
    Jwood562
    2013 Tundra 4x4
    Yeah, there IG is always getting updates but I can’t get phone calls, emails or messages responded to.
    TobyCPA likes this.
