2nd Gen RESZ fabrication group buy/discount thread! its live!
Discussion in '2nd Gen Tundras (2007-2013)' started by Jwood562, Oct 23, 2020.
  1. Mar 21, 2021 at 9:46 PM
    #301
    Jwood562
    Jwood562 [OP] New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    So sitting here sipping a beer, I thought I would go over the install for you guys and do a “recap” to prepare yourselves for the install.
    *disclaimer* if you choose to follow my write up as an “install guide” that is your choice. I assume no liability, I am showing you how I did mine*
    I removed my factory bumper cover, inner fender liners and impact bar.
    my first problem, bumper was hitting my installed RCI skid plate. I placed a jack stand to support it. Removed the front two bolts and middle three to allow it to hang down a couple inches.
    problem #2, my mounting holes for the bumper were off. I took some quick measurements and they were about an 1/8” off. So I used a die grinder and some cheap harbor freight bits to open the holes slowly and evenly. Took forever. But I would rather take the minimal amount at a time.
    Problem #3, once the holes were lined up. Bumper would not sit back. Saw there was a tab hitting and rubbing a hard AC line. Nothing a flap disc and grinder couldn’t fix, easy but annoying
    Line in question
    Bumper showing wear so I knew where to grind
    After
    Problem #4. This one I felt was the biggest “oversight” by reszfab in the design. The first problems could have all been caused by misaligned jig or warp causing a small shift in the specs. But this just feels like they missed it. Maybe not all tundras have a trans cooler. Mine does and it does not allow the bumper to be seated at all.
    I had to unbolt it from the radiator support. Which allowed the bumper to be installed and pushed the trans cooler back. Once the bumper was in, I was able to re install one of the bolts that held it to the radiator support. The bolt on the driver side
    With those issues cleared. The bumper can now be installed fully
    I had to get longer bolts and spacers to reinstall the RCI skid plate so it would clear the bumper.
    TheBeast, SC_TRD, nb_nielsen and 3 others like this.
  2. Mar 21, 2021 at 9:52 PM
    #302
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Bumper looks clean, sorry for the troubles on the install. A fly on the wall here with a little bit of advice... take it or leave it.
    you may want to give yourself a little more clearance between your bumper and the plastic fascia with the welting on it. In my experience you will rub through your powdercoating and cause premature rust. My demello rubbed through with just the plastic grill and I had to get it recoated.
    bumper looks great and kudos to you on the install!
  3. Mar 21, 2021 at 9:55 PM
    #303
    Jwood562
    2013 Tundra 4x4
    thank you! Also thank you for the advice. I didn’t even think about the rubber trim edge being able to wear through powder coating. I will take something (I’m thinking like a popsicle stick) as a gapping tool
  4. Mar 21, 2021 at 10:34 PM
    #304
    trevorstuart24
    trevorstuart24 New Member
    thanks for taking the time to write it all up. it does look good!
    TobyCPA likes this.
  5. Mar 21, 2021 at 10:49 PM
    #305
    TobyCPA
    TobyCPA New Member
    Looks great Jwood. Really appreciate the write up. Everything with the custom sequoia piece worked out as well?
  6. Mar 21, 2021 at 10:56 PM
    #306
    Jwood562
    2013 Tundra 4x4
    for the most part yes. If I we’re to change anything, I would have researched the bumper parts before and realized I needed the support before hand.
    maybe I would have made the cut 1/8” or 1/16” above the body line to allow for the rubber edge trim so it would not have the possibility of rubbing the powder coating as stated above.
    I also would not have dropped it (it fell from where I was letting it cure) causing scratches lol
  7. Mar 21, 2021 at 10:58 PM
    #307
    Jwood562
    2013 Tundra 4x4
    I am curious to see how a factory tundra two piece bumper fits with the reszfab bumper. So hopefully soon a member here will do it
  8. Mar 21, 2021 at 11:14 PM
    #308
    TobyCPA
    TobyCPA New Member
    curious now if you plan on eventually adding the support or if you’ll just leave it as is? In my eyes, based on your write up, once the RESZFab bumper is on I’d never go through the trouble to take it off again lol. I’ve got a two piece bumper, but (I think) I’m next in line for the 3rd round of shipments.
  9. Mar 21, 2021 at 11:17 PM
    #309
    Jwood562
    2013 Tundra 4x4
    Support for the upper sequoia part?
    It’s held solid at oem mounting points. There are plastic push pins along the top and the two screws at the fenders. Plus the support that is coming soon. It also snaps in at the fenders.
    I have no reserves at how it mounts
    It mounts like any other upper valance would
    TobyCPA likes this.
  10. Mar 22, 2021 at 12:26 PM
    #310
    DVCNick
    DVCNick New Member
    2011 5.7 4x4 Double Cab
    Sorry guys, haven't looked at the forum in a couple days.
    Sorry for your troubles Jwood, but thanks for the write up. I think my truck has the trans cooler so I might need to hit you up further on that if you don't mind... pics are a little zoomed in for me right now, but maybe it will make more sense once I get my old one off.
    Mine has the two piece factory bumper.
    I have NOT received any ship notice that I'm aware of to date. Has anyone else?
  11. Mar 22, 2021 at 12:51 PM
    #311
    nb_nielsen
    nb_nielsen New Member
    2012 Tundra double cab
    When I emailed them and got a response on this past Friday I was told that they will be shipping the next 2 bumpers out today and this afternoon we should be recieving our shipping notifications. These 2 bumpers they are talking about should be mine and yours. I have not gotten my shipping info as of yet
    DVCNick[QUOTED] likes this.
  12. Mar 22, 2021 at 1:17 PM
    #312
    DVCNick
    DVCNick New Member
    Just this second I received a note saying the order is processed and a "central transport BOL" number, which I assume is a tracking number of some sort. If so, it looks like mine is on the way.
  13. Mar 22, 2021 at 1:45 PM
    #313
    nb_nielsen
    I did as well and I received an email from Resz stating that the freight company is scheduled to pick up our bumpers tomorrow afternoon and then the tracking will be updated.
    I did send an email back asking for our 5% back since we ended up selling more than 5 bumper so we will see what they end up saying about us getting that back.
  14. Mar 22, 2021 at 2:02 PM
    #314
    TheBeast The Beach
    looks good. I would leave a gap between bumper and valance to allow for flex.
  15. Mar 22, 2021 at 8:29 PM
    #315
    Jwood562
    2013 Tundra 4x4
    Yeah. It’s not sitting tightly on the bumper but I’ll gap it a little more
  16. Mar 22, 2021 at 8:50 PM
    #316
    Jwood562
    2013 Tundra 4x4
    yeah you can hit me up anytime. Everything will become clear as soon as you dive in. My install post should just give you a heads in on my worst case scenarios.
    as far as the transcooler, which by the way I cannot confirm or deny that it is a trans cooler because my limited google research does not show this as a trans cooler is circled below
  17. Mar 22, 2021 at 8:58 PM
    #317
    BigSkyTaco
    BigSkyTaco Successfully Social Distancing since 1998
    Aaron
    W. Glacier, MT
    2011 White DC Tundra TRD
    Little searching...power steering cooler. Been wondering about it too.
  18. Mar 22, 2021 at 9:02 PM
    #318
    Jwood562
    2013 Tundra 4x4
    Damn! No wonder I couldn’t find it lol.
    so that still raises the question, do all tundras have them in the same place? I wonder if reszfab used a truck that did not have one. Because this still looked like a huge oversight and should have included a spacer or relocation bracket
  19. Mar 22, 2021 at 9:04 PM
    #319
    DVCNick
    DVCNick New Member
    Surely every truck has to have that then... seems like it should clear.
    Anyhow... assuming I can get it on, I'll just be happy to finally have it. If it takes a little drilling/grinding... It will still do what I want and it's a truck, not a Porsche...
  20. Mar 22, 2021 at 9:04 PM
    #320
    BigSkyTaco
    Aaron
    W. Glacier, MT
    Mine is in the same spot and I would suprised is any Tundra didnt have one.
  21. Mar 22, 2021 at 9:12 PM
    #321
    Jwood562
    2013 Tundra 4x4
    i agree, mine did not clear. Once I unbolted it from the radiator/core support. The bumper fully seated. Once the bumper was installed you can see the power steering cooler pushed back and the bolt hole did not line up. Definitely a clearance issue.
  22. Mar 22, 2021 at 9:16 PM
    #322
    Jwood562
    2013 Tundra 4x4
    And I couldn’t agree more about treating the truck like a truck. But I know some people might expect a true plug and play type install.
    im ok with putting in the work. It was long and difficult but I’m glad to be the guinea pig
  23. Mar 22, 2021 at 9:19 PM
    #323
    DVCNick
    DVCNick New Member
    I for one appreciate it; I'm sure the effort you've put into these posts will help me and others.
    nb_nielsen likes this.
  24. Mar 22, 2021 at 9:42 PM
    #324
    Jwood562
    2013 Tundra 4x4
    thats what This is all about. I’m glad you guys got shipping notices! You will happy when some 18 wheeler pulls up
  25. Mar 24, 2021 at 11:10 AM
    #325
    nb_nielsen
    Well I just recieved my bumper from resz and it seems as though my s2 mounts are too high as we. Going to use my drill press and see what I can do with them. Pretty much need to do the same thing as @Jwood562 when it comes to modifying the bracket. The look and finish of the bumper look great and my led bar fits snug right in there
  26. Mar 24, 2021 at 11:11 AM
    #326
    DVCNick
    DVCNick New Member
    Did your tracking info ever update?
    So far mine doesn't say anything and I'm not sure how to determine where I need to go to pick it up..
    EDIT: I didn't see that you have to switch the number type on their tracking page. Looks like it is in transit with an ETA of Friday.
  27. Mar 24, 2021 at 11:51 AM
    #327
    BigSkyTaco
    Aaron
    W. Glacier, MT
    That was fast...
  28. Mar 24, 2021 at 3:02 PM
    #328
    Jwood562
    2013 Tundra 4x4
    that was fast
  29. Mar 24, 2021 at 3:47 PM
    #329
    nb_nielsen
    It would have been a 5ish hour drive for me but when they did the free shipping I jumped all over it. I was very surprised when I checked my tracking info that it was in Detroit last night at midnight, then grand rapids at 930 this morning. I modified the brackets for the s2's just like @Jwood562 did. I will be waking up early and putting it on tomorrow since I have the day off
    DVCNick and Jwood562[OP] like this.
  30. Mar 24, 2021 at 5:03 PM
    #330
    Jwood562
    2013 Tundra 4x4
    good luck on the install!
    nb_nielsen[QUOTED] likes this.
