2nd Gen RESZ fabrication group buy/discount thread! its live!
Discussion in '2nd Gen Tundras (2007-2013)' started by Jwood562, Oct 23, 2020.
  1. Mar 20, 2021 at 11:17 AM
    #271
    Jwood562
    Jwood562 [OP] New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    Ugh!
  2. Mar 20, 2021 at 11:24 AM
    #272
    Jwood562
    2013 Tundra 4x4
    Ugh!
    it has fitment issues. Mounting holes are 1/16” off. So I’m opening the holes 1/32” on each side to try and make it fit as even as possible.
    stay tuned. I’m in right now. I’m not sure it that’s a powder coating thickness issue
    acutally looks more than a 1/16”. Not happy
  3. Mar 20, 2021 at 12:21 PM
    #273
    Jwood562
    2013 Tundra 4x4
    Almost there. Opening the holes a little at a time with a die grinder. I do not have good carbide bits so blowing through harbor freight ones
  4. Mar 20, 2021 at 12:25 PM
    #274
    trevorstuart24
    trevorstuart24 New Member
    this is messed up. With the delay already and first shipment not being checked for accuracy is not acceptable. Sorry you’re dealing with this. Are you reaching out to him?
  5. Mar 20, 2021 at 12:29 PM
    #275
    Jwood562
    2013 Tundra 4x4
    I’m going to. But you already know how hard it is to get a response.
    I’m taking pictures and documenting things.
    he still hasn’t relied about the 5% back we are supposed to get
    @RESZfab maybe a credit card charge back will get his attention
  6. Mar 20, 2021 at 12:46 PM
    #276
    trevorstuart24
    I’ve had some concern over ever getting the bumper and was looking into the charge back process. Unfortunately a lot of credit companies have a 60 day max on disputes.
  7. Mar 20, 2021 at 12:51 PM
    #277
    Jwood562
    2013 Tundra 4x4
    Found another small clearance issue with the hard AC line in the front near the driver side mounting point
  8. Mar 20, 2021 at 12:52 PM
    #278
    Jwood562
    2013 Tundra 4x4
    I would make the argument that the 60 day period should begin when the item is received
    TheBeast likes this.
  9. Mar 20, 2021 at 12:56 PM
    #279
    nb_nielsen
    nb_nielsen New Member
    2012 Tundra double cab
    I'm hoping to have my bumper by Wednesday or Thursday then I'll see what issues mine has I guess... this is discouraging
  10. Mar 20, 2021 at 1:04 PM
    #280
    trevorstuart24
    I think you’d have a case. Especially since the order hasn’t been properly completed. Hopefully mike can make this right.
  11. Mar 20, 2021 at 1:08 PM
    #281
    Jwood562
    2013 Tundra 4x4
    Another clearance issue. Not sure if it’s an oil cooler or trans cooler. Small two finned cool front of the radiator
  12. Mar 20, 2021 at 1:13 PM
    #282
    BigSkyTaco
    BigSkyTaco Successfully Social Distancing since 1998
    Aaron
    W. Glacier, MT
    2011 White DC Tundra TRD
    Would those spacers fix any of the issues?
  13. Mar 20, 2021 at 1:13 PM
    #283
    BigSkyTaco
    Aaron
    W. Glacier, MT
    I think that is the trans cooler...
  14. Mar 20, 2021 at 1:18 PM
    #284
    Jwood562
    2013 Tundra 4x4
    Spacers are in. Another set would definitely make it clear
    BigSkyTaco likes this.
  15. Mar 20, 2021 at 1:20 PM
    #285
    Jwood562
    2013 Tundra 4x4
    Bumper is on....
  16. Mar 20, 2021 at 1:22 PM
    #286
    Jwood562
    2013 Tundra 4x4
  17. Mar 20, 2021 at 1:22 PM
    #287
    Jwood562
    2013 Tundra 4x4
    I foresee problems with rci skid plate too.
    dealing with trans cooler now
  18. Mar 20, 2021 at 1:44 PM
    #288
    Jwood562
    2013 Tundra 4x4
    I was only able to get one bolt for the trans cooler back I hopefully that’s enough. Took some creative work but got it in
  19. Mar 20, 2021 at 2:20 PM
    #289
    TheBeast The Beach
    where does it hit ?
  20. Mar 20, 2021 at 2:25 PM
    #290
    Jwood562
    2013 Tundra 4x4
    passenger side. here. There is a 12mm bolt behind this holding it to the radiator support. The bumper pushed it back. So I unbolted both bolts. Which allowed the bumper to be installed. Got the driver side support bolt back in.
    TheBeast[QUOTED] likes this.
  21. Mar 20, 2021 at 2:27 PM
    #291
    Jwood562
    2013 Tundra 4x4
    Taking a break.
    need some longer bolts and spacers for RCI skid plate to work
    I also keep blowing my fog lights fuse when I plug in the passenger side fog....
    I need a beer lol
    TheBeast and TobyCPA like this.
  22. Mar 20, 2021 at 2:54 PM
    #292
    BigSkyTaco
    Aaron
    W. Glacier, MT
    Well your getting there! The fogs light fuse is odd. I have LEDs in the stock housings without 1 problem...so just changing to another 12v light seems like it should be seemless.
    Double check polarity or a wire scraped and grounding out?
    Jwood562[OP] likes this.
  23. Mar 20, 2021 at 3:00 PM
    #293
    Jwood562
    2013 Tundra 4x4
    Thanks! It was a grind.....literally lol!
    down hill from here. But needed a break.
    the fogs are confusing. I had squadron sae in there so it must be a polarity issue
  24. Mar 20, 2021 at 3:03 PM
    #294
    BigSkyTaco
    Aaron
    W. Glacier, MT
    Yeah just double check the wires and swap the pins really quick. Might be a simple fix....or drive you insane for the next week!
    Jwood562[QUOTED][OP] likes this.
  25. Mar 20, 2021 at 9:11 PM
    #295
    Jwood562
    2013 Tundra 4x4
    Well all done. It’s a wrap. Got it all installed looks clean and great.
    my custom two piece sequoia bumper idea worked and closed the gap between the grill also.
    I will post better photos tomorrow in day light as well as work on a install guide/review.
    I wonder if all tundras didn’t come with a transcooler, that seems like a big oversight by reszfab
    TheBeast, nb_nielsen, TobyCPA and 2 others like this.
  26. Mar 20, 2021 at 9:20 PM
    #296
    BigSkyTaco
    Aaron
    W. Glacier, MT
    Thats awesome...sounds like a whole day event. Was the fog light fix something simple? Do you think an extra or larger spacer would be the ticket for all of these?
    Looking forward to pics.
  27. Mar 20, 2021 at 9:28 PM
    #297
    Jwood562
    2013 Tundra 4x4
    so an extra spacer would solve the problem, but I would be concerned with the amount of threads left for the bumper to grab on to.
    As far as the fogs I’m not sure. I only had one fuse left so I just used a baja designs splitter since it was only the passenger side blowing the fuse. I just used a splitter from the driver side.
    One thing about my install and initial drive right now. My fogs are useless the way I installed them, they are 45 degree ditch lights
  28. Mar 20, 2021 at 9:34 PM
    #298
    Jwood562
    2013 Tundra 4x4
  29. Mar 20, 2021 at 10:07 PM
    #299
    BigSkyTaco
    Aaron
    W. Glacier, MT
    Yeah...after seeing your pic. There really isnt room for another set a shims. Maybe a small set of 1/8" shims, but that looks like it might be pushing it.
  30. Mar 20, 2021 at 10:44 PM
    #300
    TobyCPA
    TobyCPA New Member
    I’m glad you were still able to get it on despite the headaches. Not looking forward to installation now lol. Cant wait to see the pictures after all these months!
    nb_nielsen likes this.
