2nd Gen Rear Bumpers!
Discussion in '2nd Gen Tundras (2007-2013)' started by FlashCulprit, Dec 13, 2016.
  1. May 10, 2021 at 7:58 AM
    #91
    Chrslefty
    Chrslefty New Member
    08 dubble cab
    Just came on here to try and see if this bumper i saw on IG was on here, low and behold first post i see. @pyrite808 . Hows the bumper holding up?
    The pic.
    pyrite808 likes this.
  2. May 10, 2021 at 10:58 AM
    #92
    pyrite808
    pyrite808 Real TRD Pros are built not bought
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    It’s holding up great, no complaints on my end. I’d say it’s actually better quality than the front bumper I got, both are China made but the Hooke road brand seems to have better welds, powder coat, more solid overall. Haven’t needed to use the recovery points yet so that will be the true test, but I am confident it will get the job done.
    Minor mod I did was a swapping out the silver d-rings for some black ones from harbor freight and also added a rubber isolator to get rid of the knocking noise I was hearing when I’d go over speed bumps and the shackles would slide around in their mounts a bit.
  3. May 25, 2021 at 11:15 PM
    #93
    Scooter916
    Scooter916 New Member
    Nathan
    08 5.7l CrewMax SR5 2wd,
    custom shift knob, Hooke Road front and rear bumpers, 12v Solutions Remote Start
    @pyrite808 I just ordered the Hooke Road front and rear as well, due in this week. Seems pretty straight forward, just cant find any info on connecting/setting up the lights? Do the rear lights splice into your reverse? Or do you need to run secondary wiring to a new switch?
  4. May 25, 2021 at 11:34 PM
    #94
    pyrite808
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    Nice post up some pics when you get em on! I didn’t get that front bumper but I think you will like it, the rear is holding up nicely. Some people have advised that the hardware may be sub par so you may wanna get some better hardware before installing, I used what’s in the kit and it’s holding up fine but time will tell. Install is very easy. For the rear backup lights I just spliced them into my reverse lights, you could run a switch but I didn’t really see a need to have one.
    Scooter916[QUOTED] likes this.
  5. May 25, 2021 at 11:37 PM
    #95
    Scooter916
    Nathan
    I will definitely post sone pics once I get them mounted up, and yeah I might go grab some nice Grade 8 hardware once it all shows up. I'll try just splicing into my reverse.
    Now just need to figure out what to do on the front light bar
  6. May 26, 2021 at 12:09 AM
    #96
    pyrite808
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    The front you have many options, me personally I bought a bussman box and am gonna do my own custom wiring/switches from ch4x4. This will allow me to add many other lights/powered accessories down the road. It was intimidating to start but I finally sat down and attended YouTube university to teach myself electrical, here’s a video I found extremely helpful
    https://youtu.be/Ya9hQDI_epE
    I’m still awaiting some parts but will share my progress in my build thread.
  7. May 26, 2021 at 11:36 AM
    #97
    Scooter916
    Nathan
    Nice!! that looks a little intimidating since I've never really done much as far as wiring. but I'll do some research.
    back to your rear bumper, one of my license plate lights is dead, I've read that the stock lights are necessarily plug and play and need a bit of cutting/trimming. are there other aftermarket units that would work with that bumper well that I could order? My bumper shipped today so I'm getting antsy, the front definitely needs to be done ASAP but I can wait a bit for the rear if I need anything special
  8. May 26, 2021 at 12:09 PM
    #98
    oogabooga289
    oogabooga289 New Member
    I ordered the rear bumper after the pics pyrite posted his build. I have it in my garage but have yet to mount it.
    I, too, would like to know what has to be cut out in order to fit the stock license plate lights. I've seen a few pictures of the stock lights on, so it can't be too difficult.
    The quality seems to be on par with DV8 (if not a little better), but I did notice that the gussets on the adapter bracket are significantly smaller than on other clone bumpers (because let's be real, they're all copying Fab Fours). The picture below is of the Fab Fours bracket and the red lines show roughly the size of the gusset on the Hook Road bumper:
    I'm sure to a welder this would be a non-issue and a quick fix. But as is, it probably wouldn't take a hit as well as a bumper with a larger gusset. Just an observation. I intend on keeping the bumper. Just looking for the time to put it on!
  9. May 26, 2021 at 12:10 PM
    #99
    pyrite808
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    Yea it is definitely intimidating if you don’t know electrical. I spent a whole day just watching videos on YouTube and searching various forums. Once you know how it all works it will give you the confidence to tackle all kinds of projects so it’s worth the investment. You could also look into switch pros but I think that is a bit pricey.
    For the the license plate lights it was just a simple swap, I don’t remember needing anything special to get them in. You may want to be extra careful when removing it from the stock bumper as the plastic clips that hold it in might be brittle and snap, one of mine did but it still mounted up no problems.
  10. May 26, 2021 at 1:00 PM
    #100
    Scooter916
    Nathan
    I think I might just order factory replacement LED units off Amazon, they are like $14, one thing I've noticed removing my front bumper yesterday was that most of, if not all the plastic clips are super brittle (13yrs old)
    I read on opne review that they needed to be trimmed a little bit, but I'll see how it looks once I get it.
  11. May 28, 2021 at 11:20 AM
    #101
    Scooter916
    Nathan
    I was worried my stock license plate lights would be too brittle (12yr old) and one of my bulbs had burned out so I just picked these up and they pop right in, no cutting/trimming however no screws and the bumper isn't tapped for threads, so I think I'll use a small drywall anchor that will expand when I thread it in.
    https://www.amazon.com/gp/product/B086W4RTNC/ref=ppx_yo_dt_b_asin_image_o01_s00?ie=UTF8
    @pyrite808 what did the mounting screw screw into on yours? did you pull it from the stock bumper? I'd like to keep my stock bumper as complete as possible so I can throw it up for sale and recover some of my expenses on the new outfit
  12. May 30, 2021 at 12:20 PM
    #102
    pyrite808
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    I just used a lock nut on the other end of a screw to secure it no biggie. Sold my stock bumper for like $100
  13. Jun 2, 2021 at 6:19 AM
    #103
    Toyoman2
    Toyoman2 New Member
    I bought both front and rear DV8 Bumpers for my 2019 SR5/TRD Offroad DC. I installed the rear this weekend with no problems. I'm not an engineer, but this bumper is 100% better/stronger than the OEM/factory.
    I'm in the process of installing the front but there was no hardware in the boxes. I procured hardware and will resume assembly tonight and tomorrow evening. I see no other faults with this bumper set and it seems to be a great deal.
    (Other than being made in China).
  14. Jun 2, 2021 at 7:56 AM
    #104
    Scooter916
    Nathan
    Went and grabbed a couple of theese dry wall anchors at the hardware store while I was getting some mounting hardware for the licence plate, tapped them into the hole and used a new stainless wood scew to tighten em up. Worked great.
    WVI, AstroDude and pyrite808[QUOTED] like this.
  15. Jun 2, 2021 at 5:34 PM
    #105
    Toyoman2
    Toyoman2 New Member
    Update. I forgot to add that the rear bumper did not come with the cutout for the trailer hitch wiring assembly.
    It's no big deal. I'll make a cardboard template of the old bumper cutout And trace it onto the new bumper and drill / cut it out. It's a simple snap in for the assembly after that.
  16. Aug 22, 2021 at 8:24 AM
    #106
    TXTundraFan
    TXTundraFan New Member
    Mountainmanjh likes this.
  17. Sep 21, 2021 at 3:29 AM
    #107
    TygerTundra
    TygerTundra New Member
    '07 Limited DC
    From my understanding, it will mount fine, but the fitment will not be as tight and there will be gaps. I asked the same picture in a Facebook group and got pictures to show the gaps, but can't find the post again now.
    Hooke Road makes a similar bumper to what your looking at, that's made for the 2nd gens and is around the same price point.
  18. Oct 4, 2021 at 10:38 PM
    #108
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    Do y'all know of any good metal fab shops in SoCal? I called SoCal Custom Metal Fab and they wanted $2500 to build this bumper that cost $1300 in Texas kRswP9D.jpg
    Then I called another place and they charged $3500 for this bumper 26231350_1801970609836881_2026584235357971505_n.jpg
    I just want a high clearance bumper that I don't have to spend $3000 on or spend $600 in gas to pick up.
    Here's what I have now. I've been waiting 5 months for my Ironman 4x4 suspension to come in.
    WVI, Kiddnapped Tundra and Peeeheeuuu like this.
  19. Oct 5, 2021 at 6:34 AM
    #109
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    Custom fabrication is time consuming and expensive. You are being charged for skills acquired over years and expensive fabrication equipment. There are lots of options for pre-fabricated aftermarket bumpers. These companies have patterns and CNC cutters that replicate designs over and over. That is why their prices are a little more reasonable but then there is shipping!
    If I have the option I will always spend a little more and support a local business. The other option of course is to buy equipment and build one yourself.
    BashFab and Hotwire like this.
  20. Oct 11, 2021 at 7:26 AM
    #110
    zachzap361
    zachzap361 MEAN GREEN MACHINE
    Zach
    San Antonio
    2010 Green Tundra CrewMax
    Toytec Aluma 2.5 Coilovers and Toytec rear shocks, Method NV 17", Nitto Ridge Grappler 35", RCI Skid Plate, Dirtydeeds Dual Dumped Exhaust, Volant Cold Air Intake and Throttle Body Spacer, SDHQ Ditch Mount Brackets, Rigid Blackout Spot Lights, Stampede Fender Flares, N-Fab Nerf Bars, Morimoto Fog Lights, 55 watt HID's, AJT Design Climate Knobs, Ellis Precision Shift Knob, Coverking Seat Covers, Husky Floor Liner's,Demello Off-road Bumper, Rigid and Baja Designs Lights, Jomax ABS Sensor covers
    So I did want to mention this but think its a little early but oh well. I spoke with the guys over at Demello Offroad as I have the front bumper for the 2nd gen and its a straight head turner and of course want a rear bumper to go with it. When I talked to them about it they said that it is very similar to the 3rd gen and just have to make a slight adjustment to the angles and its the same exact bumper. They did say they are open to a group buy and would just have to let them know of it. I can get more details on the amount or number of buyers we would need but would like to get an idea of how many people are interested.
    zcarpenter92 likes this.
  21. Oct 28, 2021 at 6:56 PM
    #111
    chaosbooboogunner
    chaosbooboogunner New Member
    Dennis
    2012 Tundra Crewmax White
  22. Oct 28, 2021 at 7:53 PM
    #112
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
  23. Dec 2, 2021 at 10:08 PM
    #113
    AstroDude
    Eddie
    I installed the Trail Toys rear bumper. No drilling, uses factory holes. 11/10 recommended
  24. Dec 3, 2021 at 11:32 AM
    #114
    tnbndr
    tnbndr New Member
    New Berlin, WI
    AstroDude[QUOTED] likes this.
  25. Dec 4, 2021 at 10:23 AM
    #115
    AstroDude
    Eddie
    Yeah I had to do that. It was super easy, I just had to make sure I was cutting a straight line. Use tape or the paint above your cut like will get all f***ed up. I then used some of this Dupli-color undercoat rubberized paint to seal the metal so it won't rust.
    Picture is unrelated to my bumper job, I included it so that you know what the can looks like. I have 1 more this to do, but I'll do it later and will post pictures. It's adding the Better Edge Trim from Trail Toys.
  26. Feb 27, 2022 at 10:13 AM
    #116
    vtdeuce
    vtdeuce New Member
    2013 Black Tundra RW
    Anybody have pics of the
    Scorpion SCO-RBTUN07 HD Rear Bumper with LED Cube Lights Toyota Tundra 2007-2013 installed? I have only seen the stock photos. Looking for a bumper with the led lights and maybe step holes but it's hard to find a subtle design. I have a 13 Black RW.
    WVI likes this.
  27. Feb 27, 2022 at 10:18 AM
    #117
    vtdeuce
    vtdeuce New Member
    My setup. I have moved the lights into the bumper since this pic but I want to replace the bumper all together.
  28. Mar 1, 2022 at 7:48 AM
    #118
    tnbndr
    tnbndr New Member
    New Berlin, WI
    This was a bumper I purchased off ebay and modified to my needs. I then had it sandblasted and powder coated as most powder coat jobs are not done correctly and only last a couple of years at most.
    Chrslefty and vtdeuce like this.
  29. Aug 20, 2022 at 10:07 PM
    #119
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    This is what I came up with for my rear. I didn’t find any high clearance bumpers that I liked.
  30. Oct 6, 2022 at 4:00 PM
    #120
    cjrtfitch
    cjrtfitch New Member
    Silver 2010 Double Cab Limited
    In-Progress
    Love this. Brand/Manufacturer?
