295/70R18 STT Pro on Stock TRD Wheel?
Discussion in 'Wheels & Tires' started by UTTundra, Sep 17, 2017.
  1. Sep 17, 2017 at 7:15 AM
    UTTundra
    UTTundra [OP] New Member
    Lou
    Utah
    Anyone run the STT Pro in 295 70 18 with little to no modifications? I've read others have fit 295 70 18 in other tires without issue, but supposedly the STT Pro runs a little bigger.
    If you have this size tire in the STT Pro, how much did your performance and mileage drop? They're pretty heavy at around 69 lbs each. I'd be coming up from a 55 lb KO2 in 275 65 18.
    I currently have 5100s at second setting, and I'm planning on getting 6112's at second to last setting. Have an aftermarket bumper that gives a little extra room in front of the tire with the fender lining and mud flap removed. Thanks.
    MDHinSD likes this.
  2. Sep 17, 2017 at 7:42 AM
    T-Rex266 Sushi, and Teslas Staff Member
  3. Sep 17, 2017 at 10:12 AM
    Black Wolf INCOGNITO undercover mafia
    Aurora CO
    TuwaPro headache rack
    My STTs run at 34.5". My Maxxs' which are also 295/70/18 run at 34". No CMC is needed with the STTs'. You do have to move the front fender skirt foward and lose the mud flap. The Coopers are heavier. For good reason. Better made. Quality belts. AmorTek sidewalls for one. My favorite brand now so I'm totally biased. The STTs' were better in snow than my Nitto Trail Grapplers were. Better all around actually. I expect the Maxxs' to perform better in the snow.. The STTs' are a great M/T and the Maxxs' are a great hybrid A/T.
  4. Sep 18, 2017 at 6:18 AM
    UTTundra
    Lou
    Utah
    I was a little worried about rubbing on the UCA...but sounds like I should be OK. Did you notice any significant drop in mpg or feel sluggish when you went up to that size?
    Yea, I've heard only good about the STT Pro. A friend of mine runs them in 275 65 18. They look awesome.
  5. Sep 18, 2017 at 7:43 AM
    Aurora CO
    My Tundra had Nitto TG M/T 275/70/18's on it when I bought it. My gas mileage average was a little over 11. My STTs' average dropped to 10.2. I've been running with my new MAXXs' for about a month now and my average is back up to 11.2. I go up to the mountains almost every weekend to my average is low. I averaged over 15 mpg on the highway with my STTs'. I expect my MAXXs' to better on the highway mpgs..Going down to my property in a couple weeks. Should find out then. Lots of highway getting there.
    Darth Tundra likes this.
  6. Sep 18, 2017 at 7:48 AM
    Darth Tundra
    Curt
    17 CM TRD Black
    Is your property in Oregon Matt ?
  7. Sep 18, 2017 at 7:49 AM
    Aurora CO
    Near Ft Garland Colorado at 8300 ft. 5 acres with a billion $ view..
  8. Sep 18, 2017 at 7:51 AM
    Darth Tundra
    Curt
    17 CM TRD Black
  9. Sep 18, 2017 at 9:10 AM
    Aurora CO
    Spanked Wyoming...
    Darth Tundra[QUOTED] likes this.
  10. Sep 18, 2017 at 9:35 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Not all 295/70/18 tires are same.
    STT Pro is widest among 295/70/18 (12 inches wide) tires and Nitto Trail Grappler is the tallest (34.57 inches). Both Nitto Trail Grappler and Toyo OC MT are More than 5 lb heavier than STT Pro.
    I don't think you can go wrong with any of these tires (assuming that you like aggressive tires).
    edit: FYI, spec for 295/70/18 is 34.3" in diameter and 11.6" in width.
    UTTundra[OP] and Black Wolf like this.
  11. Sep 18, 2017 at 9:36 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    You're going to get really close to your UCA's on stock wheels if you don't hit it. I got the same tires but also added a lift and Method wheels at the same time so not sure how much the tires contributed but I went from 15.5mpg to about 13.5mpg, via computer. I'm too lazy to hand calculate and I just don't care. I felt about 10-15% dropoff on acceleration on the Butt Dyno but you get used to it after about a month and barely even notice it anymore.
  12. Sep 18, 2017 at 10:51 AM
    Aurora CO
    Yeah, My STTs' are wider than my MAXXs'. All those tires mentioned can be a real pain in the back when changing tires. Can't imagine changing a 37"er. No shortage of decent tires to choose from for sure.
    joonbug likes this.
  13. Jan 15, 2018 at 12:27 PM
    YotaguyVA
    YotaguyVA New Member
    Renato
    16 silver sr5 Trd crewmax
    LED conversions, spray in liner, tonneau cover, color matched handles, 3/2 level, 2" spacers, 295/70r18 cooper st maxx on stock wheels.
    I run the 295/70r18 st maxx's, just installed this weekend. I have 3/2 leveling kit and a 2" spacer. There is rub at full turn either direction on the front fender, but didnt have to do the Body Mount Chop. Supposedly you can heat up the plastic in the front and move it forward but i have yet to see it done. I will add some pics today.
  14. Jan 15, 2018 at 12:55 PM
    Aurora CO
    You shouldn't even have to heat it up. Would make it easier I guess.
  15. Jan 15, 2018 at 7:15 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Anyone have some pictures???
  16. Jan 15, 2018 at 8:33 PM
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    Here is a poc
    68 RS/SS, Silv333, parker44 and 5 others like this.
  17. Jun 1, 2018 at 3:42 PM
    Dbello70
    Dbello70 New Member
    David
    2015 Tundra TED 2WD
    Readylift 3/1
    Monica
    online
    Junior MemberJoin: about 1 hour agoPosts: 1
    about 1 hour ago · #1
    295/70/18 hitting Control Arm
    Hello everyone. I am new to this forum so please go easy on me. I have a 2015 Tundra TRD 2WD. I recently installed a Readylift 3/1. I wanted to keep the stock 18 inch rims but put new 295/70r18 Nitto Trail Grapplers on. All the research I did on this site and other forums stated I would not have a problem installing 295/70/18 tires on stock 18 inch rims with a 3/1 lift level, but when I went to install the 295/70 r18 Trail Grapplers on the front, the wheels would not fit because the tire was hitting the Upper Control Arm. Again, all my research led me to believe a could put a 295/70 r18 on with no modification so i was shocked to find the UCA was preventing the wheel from being put on.
    So, here I am. Did I possibly do something wrong in during the 3 inch spacer install? The truck was running great with the Readylift install and wheel alignment.
    What are my options now? Do I need spacers on? If yes, how big? Were all the posts stating 295/70 R18s Trail Grapplers on stock 18 inch rims with a 3inch lift would fit with no modifications? I do not want to buy new rims at this time
  18. Jun 1, 2018 at 8:39 PM
    Steve Tundra
    Steven
    2022 4x4 platinum
    I have a 4 wheel drive. Only had to remove front mud flap and had some running on front pan but did t touch the uca. Wondering is 2 and 4 wheel drive is the difference.
  19. Jun 2, 2018 at 4:11 AM
    Dbello70
    Dbello70 New Member
    David
    2015 Tundra TED 2WD
    Readylift 3/1
    Truck looks great. I'm completely stumped maybe the 4 wheel is different. I've seem posts where some trucks needed spacers and some didn't. It this point is in the game I'm just going with spacers. Thank you.
  20. Jun 2, 2018 at 4:11 AM
    Dbello70
    Dbello70 New Member
    David
    2015 Tundra TED 2WD
    Readylift 3/1
    BTW, did you Plastidip your wheels?
  21. Jun 2, 2018 at 7:15 AM
    Steve Tundra
    Steven
    2022 4x4 platinum
    No mine are the actual trd pro wheels. But I’ve seen plasti diped or powder coated and really like them.
  22. Jun 2, 2018 at 7:16 AM
    Steve Tundra
    Steven
    2022 4x4 platinum
    I’ve been debating some small spacers for a more agressive look. Post some pics when your done.
  23. Jul 1, 2018 at 10:46 PM
    StrattAg21
    StrattAg21 New Member
    Denver, CO
    2018 Tundra Mag Grey
    @Dbello70 , how did that work out for you? I'm looking at pulling the trigger on some 295/70R18 and need to know if I need to get the spacers. I've got a 3/1 lift and it's 4wd, just curious how it all worked out for ya. If you did get spacers, what size?
  24. Jul 2, 2018 at 4:59 AM
    Glock17
    Glock17 New Member
    Helena, Al.
    2016 TRD PRO
    Fab Four bumpers, Warn Zeon 10, Line X, Toytec lift, Rugged Tri fold cover, Cooper SST, Weathertech liners, Weathertech vent guards
    The coopers are what came on my truck. Look great but got kinda loud at about 15,000 miles.
  25. Jul 2, 2018 at 6:32 AM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    I love mine. 305/70 18 but definitely noticed some mpg drop and a little decrease in get up and go. They are a little noisy, but not bad. When comparing to stock lol. All in all I love them. Would def reccomend. Oh and no cmc.. the +25 offset seems to be the sweet spot. I can actually fit my fingers in behind them fairly easily.
  26. Jul 6, 2018 at 4:51 PM
    StrattAg21
    Denver, CO
    so just an update - installed my 295/70R18 Ridge Grapplers on my 3/1 w/o spacers... only thing it rubbed was the skid plate which I rolled back a bit and so far so good... no offroad playing yet - will update once I get some trail roads in, but on pavement so far so good w/ the skid plate trim!
  27. Jul 20, 2018 at 7:57 PM
    emdcksn
    emdcksn New Member
    Eugene
    Eugene OR
    2021 MGM Tundra Platinum CrewMax
    Installing a Ready Lift 3/1, Camburg UCA’s, Spidertrax 1.25” spacers and Cooper STT PRO 295/70R18 on TRD OR wheels next weekend hopefully. All parts should be here by next Thursday. I’ll let you know if there is any rubbing and what I had to do to fix it.
  28. Aug 1, 2018 at 12:15 PM
    emdcksn
    emdcksn New Member
    Eugene
    Eugene OR
    So, with all of the parts in post #27 installed, mud flaps removed and the caster set at 5-5.5 (tech didn’t want to go more) i have no rub on the front bumper at all but am rubbing on the BM at full crank. Sure would be nice if I didn’t have to do the BMC.
  29. Aug 3, 2018 at 2:56 PM
    leadboot
    leadboot New Member
    What is your set up in this pic? No spacers and 295/70/18 on the TRD Pro rims?
  30. Dec 28, 2019 at 10:42 PM
    Noodleboy
    Noodleboy New Member
    HP
    SGV
    2015 tundra double cab
    Did you have to run spacers to fit the 295 70 18?
