295/70/18 Ridge Grappler and Method Wheels on my PRO!
Discussion in 'Wheels & Tires' started by Matte Tundra, Feb 9, 2017.
  1. Feb 10, 2017 at 4:18 PM
    BRNG ITT
    BRNG ITT New Member
    San Antonio, Texas
    2016 CrewMax TRD PRO
  2. Feb 11, 2017 at 2:17 PM
    Voyagermike
    Voyagermike New Member
    California
    awesome thanks for the photos.:thumbsup: Im getting rid of my tacoma and trying to educate myself before the pro comes in.
  3. Feb 23, 2017 at 9:34 PM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    It's for sale!!! Portland, Oregon craiglist. Very tempting.
    Voyagermike likes this.
  4. Feb 28, 2017 at 4:30 AM
    Ricechex21
    Ricechex21 New Member
    Rich
    2016 White TRD PRO
    Bushwacker flares, raptor running boards, 2"level removed mud flaps all around, fiberglass toneau cover, weather tech rain guards
    I just received my Nitto terra grapplers 295/70R/18's , can I put these on my stock TRD rims without spacers? I have already removed all the mud flaps and installed Bushwacker flares.
  5. Feb 28, 2017 at 7:43 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I think they'll hit the UCA. But, you can try.
  6. Feb 28, 2017 at 8:22 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Man that looks GREAT!!
    Matte Tundra[OP] likes this.
  7. Feb 28, 2017 at 10:47 PM
    Matte Tundra
    Matte Tundra [OP] New Member
    2017 TRD PRO Cement
    www.tctwraps.com
    You can, but I would HIGHLY recommend wheel spacers. 1.25-1.50" for a much more aggressive look but most importantly because your tire will sit not even a finger width apart from your UCA. But I do not think it will hit it. My uncle has a '16 pro with stock wheels, no spacers, and 295/70/18 trail grapplers and it just sits very close to the UCA but has never physically touched it..
    831Tun and Voyagermike like this.
  8. Feb 28, 2017 at 10:47 PM
    Matte Tundra
    2017 TRD PRO Cement
    www.tctwraps.com
    do it! ;)
  9. Mar 1, 2017 at 10:37 AM
    Ricechex21
    Rich
    2016 White TRD PRO
    Thanks Matte, obviously spacers are cheaper than new rims and I believe the stock TRD PRO wheels are a +60 offset, so in theory I could achieve the same spacing with a +18 offset wheel as I would with 1.25" spacer....is my theory accurate?
  10. Mar 1, 2017 at 10:49 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No, that will put you at about a +28 offset.
    1.25 x 25.44 = 31.8mm
    60 - 31.8 = 28.2mm
    TheBeast and CM-LENNY like this.
  11. Mar 1, 2017 at 11:05 AM
    Ricechex21
    Rich
    2016 White TRD PRO
    Thanks Joon, I have read most of these forums and honestly my head is spinning....lol, a +28 makes the wheel closer the frame than a +18 would if I am correct. So now my question is, with these 295/70/18 tires, whats better, a +28 or +18? keep in mind I only have the 2" leveling done. I dont want to do the CMC but I am not opposed to a little plastic trimming if needed.
    I also read that Bilstein 5100's could also be a cheaper way to get some lift, but does that provide any more clearance?
  12. Mar 1, 2017 at 11:23 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes, it'll be 10mm more tucked in than the +18. And yes, I think you're better off with the +28. You'll have less rubbing the more it's tucked in. But you're still going to have quite a bit of rubbing. Here's mine, +25 with that same size tire.
    KEG89, rons23, Jsena and 2 others like this.
  13. Mar 1, 2017 at 11:47 AM
    Ricechex21
    Rich
    2016 White TRD PRO
    Joon, how much did you have to cut?
  14. Mar 1, 2017 at 11:55 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Removed my mudflaps and trimmed the front liner and pushed it forward and re-drilled. But I have a 3" lift and I'm still very close to the cab mount. I also have Cooper STT Pros, which run a little bigger and they're mud terrains.
    Local46er likes this.
  15. Mar 1, 2017 at 7:29 PM
    sk8142
    sk8142 New Member
    Shawn
    WA
    2014 Black Tundra TRD
    Bilstein 5100 F&R - Front middle setting w/2 CB shims Toytec rear shackles @ 1" setting Method NV 18x9 +25 Bronze 295/70/18 Nitto Ridge Grappler Retrofit headlights with Morimoto DS2 4.0, Apollo 3.0 shrouds, switchbacks Prodigy P3 brake controller
    bigger as in taller or more wide? I have the same wheels but with 295/70 Ridge Grapplers. I haven't installed them yet but I'm wondering if they'll sit outside the fenders like yours.
    geno0506 likes this.
  16. Mar 1, 2017 at 7:57 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Taller. It's basically 34.5". Yours will stick out the same as mine. If it's different, you won't notice it by eye.
  17. Mar 2, 2017 at 8:37 AM
    Ricechex21
    Rich
    2016 White TRD PRO
    should I add the Bilstein 5100's and the spacers, or do you think its better to get the offset rims with or without the 5100's?
  18. Mar 2, 2017 at 8:56 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Okay, hold on. You have a Pro, right? In your sig, what does the 2" level mean? Are you talking about your Pro suspension or did you raise it some more with a spacer lift?
  19. Mar 2, 2017 at 8:58 AM
    #49
    Ricechex21
    Rich
    2016 White TRD PRO
    I just have the standard PRO suspension which I believe is the 2" level.
  20. Mar 2, 2017 at 9:18 AM
    #50
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yea, Pro is level so it's +/- 2" taller than stock. NO WAY should you swap Pro shocks for 5100s. For one thing, it won't get you more lift and 2nd it's a downgrade. You can put shims on top to get more height but you should really call Dave at Coachbuilder first. Ready lift also makes a lift for the Pro and the one example I know of resulted in the guy getting rid of his truck because it made the ride so bad, read that in a thread here.
  21. Mar 2, 2017 at 9:21 AM
    #51
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Okay, got it. You don't need to write that, everyone already knows the Pro is leveled and it makes it sound like you put on a 2" spacer lift or something. So first of all, your Pro suspension is much better than 5100's, no way should you swap that out. You probably have 3 choices from there.
    1) Just put the tires on as is and see if it rubs your Upper Control Arms. If you don't rub, you'll be extremely close and should be good.
    2) If it does rub or you want more of an aggressive look, get wheel spacers
    3) Get new wheels
    Any of these 3 you will probably have to deal with some rubbing, but the more tucked in you are, the less rubbing you'll probably have to deal with.
    Law323 and 831Tun like this.
  22. Mar 2, 2017 at 9:26 AM
    #52
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    @Ricechex21, the 5100's you read about are for people with non-Pros with crappy, low, stock suspension. You can just completely get them out of your mind. :D
  23. Mar 2, 2017 at 9:29 AM
    #53
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    +1^^^. I've got some I'd like to get out of my garage...lol
    zcarpenter92 and joonbug[QUOTED] like this.
  24. Mar 2, 2017 at 9:36 AM
    #54
    Ricechex21
    Rich
    2016 White TRD PRO
    Thanks Joon, I am obviously trying to avoid a CMC, not sure why, I just dont want to cut on it. I was looking for a way to get some added lift but in no way want to ruin the suspension in the process. I will try the tires as is and will probably get some spacers in case it rubs. I am also looking at some +25 offsets. I do want the more aggressive look, but not with a lot of lift, just trying to figure out the best way to achieve this without too much chopping.
  25. Mar 2, 2017 at 9:47 AM
    #55
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Oh @Ricechex21, I just noticed you have bushwackers. You should definitely get some wheel spacers atleast if you keep your stock wheels. With your flares it will look way too tucked in without them. I'm sorry I have no experience with flares so I don't really know how much you need your wheels to stick out, but I would think +25 would be the minimum. Since @Matte Tundra put on +18's without a CMC, I would aim for something near there.
    831Tun likes this.
  26. Mar 7, 2017 at 6:30 AM
    #56
    CCTundra
    CCTundra New Member
    Seattle,WA
    2021 1794 Tundra
    Bilsteins 6112 top setting, 0.5" Coach builder shims, 5160 rear shock with 3" Coachbuilder shackle kit. RB20 Step bars, Forged TRD Pro wheels, Back flip cover, Kennwood 10" Head unit, 2JL 10" Subs, Alpine 6 channel Amp.
    Beautiful truck man. I love the set up. How do those tires ride? I'm going back and forth between these tires and the nitro trail grapplers in a 285/55/20. I know the trail grapplers are a little loud on the freeway.
  27. Mar 8, 2017 at 11:53 AM
    #57
    Matte Tundra
    2017 TRD PRO Cement
    www.tctwraps.com
    Thank you. I love them. I had the trail grapplers on my 2015 trd, but these are still very aggressive, much more quiet and smooth, and great overall. Definitely happy with them.
  28. Mar 8, 2017 at 12:45 PM
    #58
    CCTundra
    CCTundra New Member
    Seattle,WA
    2021 1794 Tundra
    That's great. How have they been wearing? That tire has a little funky tread pattern, so I'm a little concerned about how it wears.
  29. Mar 9, 2017 at 10:16 PM
    #59
    Matte Tundra
    2017 TRD PRO Cement
    www.tctwraps.com
    Too soon to tell
  30. Mar 15, 2017 at 2:56 PM
    #60
    Tommy B
    Tommy B New Member
    Truck looks awesome! Do you think the leveler system for the front would have eliminated the rubbing? I really don't want to hack up my Pro and I am looking to go with 295-55/60-20 ridge grapplers on 20-9 +20 wheels.
