295/60r20 vs 275/65r20
Discussion in 'Wheels & Tires' started by extremes074, Jan 26, 2024.
  1. Nov 6, 2024 at 3:39 AM
    #61
    the4rdan
    the4rdan New Member
    Pennsylvania
    2025 WCP Ltd. TRD OR CrewMax
    How many miles are you at on them? Any change in road noise? My AT3 XLT's have gotten really loud after about 25k miles - at 37k right now.
  2. Nov 6, 2024 at 6:23 AM
    #62
    Breathing Borla
    AZ
    I don't drive that much anymore, finally.. I used to pile on the miles like crazy over the years.
    I think Im around 12K or so, I'd have to check, but road noise has not increased at all, which I cant say for my BFGs I used to have those got loud quick. My AT3 XLTs I had on my 2016 got a little louder over time but not anywhere near the increase of the BFGs. The 4S were much quieter to start and more road friendly, so Im hopeful they stay quiet.
  3. Nov 6, 2024 at 6:57 AM
    #63
    the4rdan
    the4rdan New Member
    Pennsylvania
    Appreciate it! Thank you.
  4. Nov 8, 2024 at 10:55 AM
    #64
    Paul499
    Paul499 Large Member
    Paul
    Sarasota, FL
    2024 Platinum Hybrid
    Weld 20x9, Toyo 285/60, RC N3 level, ceramic tint
    IMO if you want bigger-than-stock ATs with the aggressive look but SL rated, the only choice is the Nitto Recon Grappler 275/65R20 116T.
    • SL-rated
    • 48 lbs
    • 34.1" tall x 10.8" wide - one size up for both from stock
    • Aggressive looks
    • Edit: fits with no rub without a lift or level
    Breathing Borla it's more than a whole inch taller but only 3-4 lbs heavier than your Coopers. Seems like a no-brainer.
    GoHuskers likes this.
  5. Nov 9, 2024 at 9:42 AM
    #65
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    I'm 99% sure to get this tire and size unless there's an 295/60/20 non-LT tire existed.
    Paul499[QUOTED] likes this.
  6. Nov 9, 2024 at 11:52 AM
    #66
    Foster1
    Foster1 New Member
    2023 TRD Off Road
    There's also the new Nitto Terra Grappler G3 and the Toyo RT Trail in that size that are SL and the same weight.
  7. Nov 11, 2024 at 9:24 AM
    #67
    Paul499
    Paul
    Sarasota, FL
    The G3 looks pretty good, 275/65R20 SL even lighter than the Recon.
