295/60/20 with 5100 Level? Possible?
Discussion in 'Wheels & Tires' started by NC_Nole, Jan 8, 2020.
  1. Jan 8, 2020 at 5:08 AM
    NC_Nole
    NC_Nole [OP] New Member
    Paul
    '17 Platinum MGM 4x4
    Morning all! I've been waiting for my stock tires to finally kick the can and I'm there. I'm going to have 5100s put on at 2nd setting and want to put a taller & wider tire on the stock Platinum rims. With this setup has anyone pushed the limits past the recommended 285/60/20 from the Largest Tire? The additional height on this is nice but the 4/10 inch width addition is not very exciting. If so, any direction to pics or tire type suggestions would be greatly appreciated. Thank y'all!
  2. Jan 8, 2020 at 5:21 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    as long as the tire will clear the UCA, you can fit those tires. however, you may have some trimming to do.
    i have the 5100's on the second setting with 295/55/20 tires on a 20x9 +50mm offset wheel and they just barely clear the UCA.
    find a tire shop that will test fit a 295/60/20 on your truck. good luck :)
