295/55/20 fit 2018 without rub or trimming?
Discussion in 'Wheels & Tires' started by Jlaw74, Nov 23, 2017.
  1. Nov 23, 2017 at 8:08 PM
    Jlaw74
    Jlaw74 [OP] New Member
    2018 super white platinum tundra
    Guys I need help on choosing the proper tire size for my 2018 platinum stock rims...will 295/55/20 ridge grapplers fit with no rub or trimming?
  2. Nov 23, 2017 at 9:04 PM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    Click Forums. Scroll down to wheels and tires. Sticky thread at top Largest tires stock all gen.
    trayday and T-Rex266 like this.
  3. Nov 23, 2017 at 11:53 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
  4. Nov 24, 2017 at 4:35 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I personally would opt for 275/60/20 rather than 295/55/20. They are both 33 inch tires. For stock wheels, 295s will be 10 mm closer to the suspension components (too close at least for for my comfort).
  5. Nov 24, 2017 at 7:14 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    I believe the platinum wheels are 20x8 with a +60mm offset. with 295's, you might rub the UCA's. I have a 20x9 wheels with a+50mm offset with 295/55/20 ridge grapplers and there is about a 1/4" of clearance to the UCA:
    you have 275/55/20 on your truck now, right? check the clearance from your tire to the UCA and see if you have at least 5/8" of clearance. putting on a 295 will soak up 1/2" of that clearance. also, if you can find a tire shop that will work with you, have them put on the 295 and see if it clears. if it doesn't, then you will have to go with a 285 or a 275. ridge grapplers have 285 and 275 options that you can use.
    as far as the diameter on the 295/55/20 goes, you will have to remove the little front mud flap to prevent rubbing.
    good luck :)
  6. Nov 24, 2017 at 7:45 PM
    Jlaw74
    Thanks for the info guys
  7. Apr 1, 2018 at 11:10 AM
    LastCanadianExit
    LastCanadianExit The dude abides...
    Bucks County, PA
    2018 Platinum
    ReadyLift 8" Lift Fuel Trophy Wheels Yokohama 37s
    What
    What did you end up doing?
  8. Apr 1, 2018 at 3:26 PM
    Jlaw74
    iskoba2 and srad750c like this.
  9. Apr 1, 2018 at 3:27 PM
    Jlaw74
    Went with th 295/55/20 ridge grapplers with a fox 2.0 level kit
    iskoba2 likes this.
  10. Apr 1, 2018 at 4:30 PM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
    Nice! Thanks. Did it need the level to fit the tires?
  11. Apr 12, 2018 at 12:35 AM
    srad750c
    srad750c just passing through
    NC
    2015 Limited DC 4x4
    TRD Pro exhaust, TRD Pro suspension, G-Tek Fab door sill protectors, Stealth running boards, 20" Gunner wheels, BFG K02
    Looks good, its time for new tires on my 2015 Limited DC. I wanted to try 295/55R20 also. I have TRD pro suspension. Did you have to trim anything?
  12. Aug 15, 2018 at 5:07 PM
    chatch82
    chatch82 New Member
    Did you have to do the front level to fit them? Are you running wheel spacers?
  13. Oct 25, 2019 at 12:54 PM
    PlatinumXing1985
    PlatinumXing1985 New Member
    Kevin
    2015 Attitude Black Platinum Tundra
    Iron cross side steps, color matched door handle / side mirrors, s&b cold air intake, Trd shifter, MX4 tri-fold cover, tundra bed mat
    What
    What psi do you run front and back?
