285/75r18 Toyo R/T's
Discussion in 'Wheels & Tires' started by Tacotundra, Mar 20, 2017.
  1. Mar 20, 2017 at 10:22 AM
    Tacotundra
    Tacotundra [OP] New Member
    Vegas
    2017 Tundra
    Hey guys any of you running this size 285/75r18. I been searching on here didn't find anything. Wanted to see some pics of how that size looks on our trucks. Thanks in advance.
  2. Mar 20, 2017 at 10:26 AM
    zcarpenter92
    zcarpenter92 Yotas, Coronas and 'Merica
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    @CM-LENNY had that size in G2's before moving to 37's.
  3. Mar 20, 2017 at 10:27 AM
    Tacotundra
    Vegas
    2017 Tundra
    Oh ok. I ck out his build thanks.
  4. Mar 20, 2017 at 11:19 AM
    chadjamesr
    chadjamesr New Member
    Chad
    Atlanta
    2016 Tundra Platinum 4x4 Crew Cab
    Fox 2.5 w/ DSC Remotes F&R Coach Builder +3 Shackles RW Wheels w/285/75/17 Terra Grappler G2 Interior and exterior changed to LED Retrofit headlights with DS2 4.0 Morimoto LED fog lights Morimoto 40" LED bar in front bumper Retrax PRO Tonneau cover RCI front skid plate Crystalline tint on all windows and windshield P&P Rock sliders and full skip plates
    Here is a photo of my 2016 Platinum 4x4 with 285/75/17 Nitto G2 on the stock suspension. With the Rock Warrior wheels, they fit with no rubbing. I think this is the largest size you can go with 100% no rubbing issues with the correct offset. Going larger may require trimming.
    blue16, driverdog and Crewmax Chris like this.
  5. Mar 20, 2017 at 11:27 AM
    chadjamesr
    Chad
    Atlanta
    Thanks. I think the 285/75/17 are the most practical tires you can get. Sure 35 x 12.5 look better, but come with some issues. With the 285s my mpg on the highway is still in the 18mpg range and I'm not lacking in power. The truck looks even better now with my recently upgraded Fox 2.5 lift. Once day I'll get some free time and post all the updates I've made on the truck so other can learn from my mistakes.
    14burrito and zcarpenter92 like this.
  6. Mar 20, 2017 at 4:03 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Keep in mind that 285/75-17 is somewhat smaller than the 285/75-18. I ran a Nitto G2 285/75R-18 and it is a fraction taller than a 35x12.50, but only 11.25" wide.
  7. Mar 20, 2017 at 4:11 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Isn't 285/75r18 was slightly smaller than 35"?
  8. Mar 20, 2017 at 4:15 PM
    CM-LENNY
    San Diego, CA
    Not sure in the Toyo, but in the Nitto G2 the 35 is 34.53x12.52 and the 285 is 34.84x11.26"
    zcarpenter92 and Spolar like this.
  9. Mar 20, 2017 at 4:15 PM
    Tacotundra
    Vegas
    2017 Tundra
    Yes I realize that. Thanks man. After researching more pretty sure I'm just gonna get CMC and go 35 12.50. This has been a serious delima for me :annoyed:. Haha
  10. Mar 20, 2017 at 4:18 PM
    CM-LENNY
    San Diego, CA
    What wheel are you going with ? Need correct offset or wheel spacer to clear UCA with a 12.50 wide. Good luck with all.
  11. Mar 20, 2017 at 4:19 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Shows how little I know about tires! I always assumed 35" actually measured exactly 35"
  12. Mar 20, 2017 at 4:22 PM
    CM-LENNY
    San Diego, CA
    Come on Zac......get with the picture :rofl:.Yes, until you do the leg work, some of those tire specs get confusing. Kinda like trying to pick a new beer at new brew house !
    Spolar likes this.
  13. Mar 20, 2017 at 4:45 PM
    Tacotundra
    Vegas
    2017 Tundra
    I'm gonna go with SCS Ray10 they should be 25mm offset 18x9.
  14. Mar 20, 2017 at 5:32 PM
    CM-LENNY
    San Diego, CA
    OK, no issue with UCA there. Sounds like you got things figured out pretty good now. Looking forward to the pics when you get it done.
  15. Mar 20, 2017 at 5:42 PM
    Tacotundra
    Vegas
    2017 Tundra
    Thanks man. Will make a build thread once I have my suspension in and install it. Hopefully it comes in the next week or so. Thanks for the help. And I like your build alot pretty awesome stuff.
    CM-LENNY likes this.
