285/75/18 duratrac finally installed!
Discussion in 'Wheels & Tires' started by Js18tundra, Mar 8, 2018.
  1. Mar 8, 2018 at 8:40 AM
    Js18tundra
    Js18tundra [OP] New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    So to answer a couple questions, no I haven’t had any issues with the tss, yes I had to trim the skid plate and remove the front flap. They are 5100’s on middle setting, with two cb shims on the drivers side and one on passenger side. The truck drives way better than stock and I have seen maybe .5 mpg less.
    equin, aperezsh, crochetjohn and 11 others like this.
  2. Mar 8, 2018 at 8:42 AM
    Vendeta2k
    Montana
    2018 Limited Cement CM
    Looking good!
    Js18tundra [OP] likes this.
  3. Mar 8, 2018 at 8:59 AM
    zcarpenter92
    zcarpenter92 Yotas, Coronas and 'Merica
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I like the look of that size, had no idea Duratracs came in a 285/75R18?
    mr_souc likes this.
  4. Mar 8, 2018 at 10:21 AM
    parker44
    parker44 New Member
    Keith
    Columbia, South Carolina
    2008 Tundra - Desert Sand Mica
    Must be a pretty new addition to their size lineup.
  5. Mar 8, 2018 at 10:24 AM
    NoMoTaco
    NoMoTaco New Member
    2018 Tundra DC TRD OR Silver
    Good looking truck! Nice job
  6. Mar 8, 2018 at 10:26 AM
    Js18tundra
    Yes, the ridge grapplers also come in that size, but they were back ordered:-/
    zcarpenter92 likes this.
  7. Mar 8, 2018 at 10:35 AM
    ToyotaTundraMike
    2015 Tundra
    Can you post some more pics of different angles?
    Ted4311 likes this.
  8. Mar 8, 2018 at 10:56 AM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    3/2 lift, Tuff 2"AAL, BULLY DOG TUNED, LED headlights, rough country side steps, tint job, rigid industry led fogs, 30" heise led bar, rugged tri-fold cover, console organizer, stubby antenna, LED interior take over, shift knob, color match everything, PRO grille MORE TO COME
    Yes I want to see a full frontal of your truck ;)! I am still stewing the idea of new rims and tires or just adding bigger tires
  9. Mar 8, 2018 at 11:01 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    Looks great, how did they balance out? One of my friends has had some issues keeping his Duratrac 315/70/17s balanced.
  10. Mar 8, 2018 at 12:53 PM
    Js18tundra
    Yes, I will take some when I get home
    ToyotaTundraMike likes this.
  11. Mar 8, 2018 at 12:55 PM
    Js18tundra
    So far so good, they may have to be road forced at a later date
  12. Mar 8, 2018 at 3:36 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Looks good! That's a nice tire size.
  13. Mar 8, 2018 at 4:23 PM
    Js18tundra
    Here’s a few moreDF17DDAA-1BBF-4866-AAEE-7B160BB39E89.jpg2B23907B-675E-4CFB-9B3C-291E21EF07FC.jpg
    equin, aperezsh, Wrongside and 5 others like this.
  14. Mar 8, 2018 at 8:52 PM
    Watt maker
    Watt maker Keepin' the lights on!
    Ronald
    NM
    2017 TRD Pro Tundra DC Cement
    1 of 255
    Looks great! That's a perfect size as well. Probably the size I'll go with next. Keep us updated on those Duratracs.
  15. Mar 9, 2018 at 4:37 AM
    Js18tundra
    I couldn’t agree more! The pics don’t do it justice, these things are beastly!
    Watt maker likes this.
  16. Mar 9, 2018 at 7:27 AM
    shockinyall
    shockinyall Hillbilly
    West Virginia
    2017 TRDOR CM
    In Queue...
    Awesome. If you only knew how much debating I have done over this exact tire. Had duratracs on my tacoma and absolutely loved them. Ever since I seen they had this size I have wanted them for the tundra. How is your clearance on the UCA's and are they stock? I have the Toytec/Eibach 3" coilovers so I may be very close to your same lift, and had concerns they would fit. Thanks for sharing the info and pics.
  17. Mar 9, 2018 at 8:55 AM
    RangerBP
    RangerBP SC Expat
    CO
    2017 SSM 4x4 SR5 DC and stuff
    It looks like you were able to get those in there without spacers?
    Looks great. Well done, sir.
  18. Mar 9, 2018 at 9:11 AM
    Js18tundra
    I have a good amount of clearance all around, the guys at the tire shop didn’t think they were going to fit... but they did! I just trimmed the skid plate about 2”, and took off the front flap
  19. Mar 9, 2018 at 9:29 AM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    TC LT w/ king 2.5 C/O and bypass, ADS bypass rear, Toytech shackles, TRD dual exhaust dumped, KM3 37s on Method standard +18. N_Fab front bumper, Westin rear w/ hitch relocate, RCI skids, Desert Eagle tranny skid, All Pro sliders, ARB dual compressor, 5.29 gears and ARB rear locker
    Those look great. I'm curious how much space you have between the tire and UCA?
  20. Sep 17, 2018 at 10:10 AM
    912 Mountain lover stuck in a sandbox
    Cape Coral, FL
    DC 4x4 Ltd
    Any update after having this size in regard to power, rubbing, or mpg now that you've had them for a few months now? thanks
  21. Sep 17, 2018 at 11:15 AM
    COTundraRoamer
    COTundraRoamer New Member
    Dustin
    Denver, CO
    18' Platinum CM
    Fox 2.5 DSC front, Fox 2.5 DSC rear. JBA UCA. SCS Ray10 custom powder coated on 285/75r18 Duratracs.
    I've had them on mine for close to 5k miles. Just ran 3500 miles to Banff/Jasper and back to CO. Had some rubbing with Fox 2.5 DSC and JBA UCAs. But all good now. What pressure do you run?
    912 and zcarpenter92 like this.
  22. Sep 19, 2018 at 3:44 AM
    Js18tundra
    I’m averaging 15mpg so far, no rubbing still, and I honestly didn’t notice a large drop in power, maybe a smidge, but not a lot.
    Watt maker, zcarpenter92 and 912 like this.
  23. Sep 20, 2018 at 5:35 AM
    shockinyall
    West Virginia
    2017 TRDOR CM
    In Queue...
    Had mine on for about 3k miles so far. Toytec/Eibach 3&1 with stock UCA's. Alignment in spec. Slight loss on power, but not very noticeable. Had to remove the little front flap and trim skid plate corner. Very slight rub full lock in reverse, but that is all. Finger width clearance on UCA. MPG is 12, but I live in the mountains and climb 3 on my way to work everyday. Definitely recommend and wouldn't go back. Need to get pics uploaded at some point.
    Edit: Pic below.
    Luckydog, aperezsh, Wrongside and 2 others like this.
  24. Sep 21, 2018 at 9:57 PM
    goffredo
    goffredo Grease Nipple
    Lake Tahoe, California
    2018 Tundra Limited Double Cab Magnetic Gray
    This looks great! I'm hoping to install OME BP-51 and the SPC UCA, with a Dakar spring pack, on my 2018 LTD. Hopefully the tolerances are close enough to yours, that I can pull off putting the same 285/75R18s on with only slight mods.
  25. Sep 21, 2018 at 11:15 PM
    RangerBP
    RangerBP SC Expat
    CO
    I’ve had the 285/75 duratrac for 4k now. I’m on 6112 coilovers (top setting). Also an Expedition 1 front bumper and RCI skids so no issues with the rub and no trimming. I’m on stock UCAs and have less than an index finger’s width between tire sidewall and UCA.
    It’s a little less peppy than with the little tires, but still has plenty of pep. I don’t have a speedo calibrator and am still registering 15.2mpg.
    Good luck.
    equin, zcarpenter92 and Watt maker like this.
  26. Sep 24, 2018 at 3:42 PM
    Brocksw
    Brocksw New Member
    I'm a newbie but from what I'm seeing here I'm wondering if these 285/75s would work on a 12' DC with 5100 bilsteins on the top 2.5" setting?
  27. Sep 24, 2018 at 6:45 PM
    Watt maker
    Ronald
    NM
    1 of 255
    I'm not 100% sure but I would think they would fit depending on what wheels you're running. Some tire shops will mount one up so you can try before you buy.
  28. Sep 25, 2018 at 8:49 AM
    Brocksw
    Brocksw New Member
    Stock 18" TRD off road wheel
  29. Oct 2, 2018 at 5:50 AM
    GlobalGuy
    GlobalGuy GlobalGuy
    Buffalo, NY
    2018 Silver TRD Double cab
    Hey Js18tundra, truck looks great! What's the name of the running boards, are you happy with them?
    Thanks
  30. Oct 3, 2018 at 4:15 PM
    Js18tundra
    Thank you! They are go rhino rb 20’s other than the front brackets on either side being bent from the factory, they are great!
    GlobalGuy likes this.
